Offline Br01
#1 Posted : 17 February 2016 15:33:58(UTC)
Br01
I have a marklin 29857 (Br 18) that has 2 sounds (whistle and bell). After playing with rocrail the loco lost the sound.
I tried to reconfigure it in CS2 and it recognises the icon for the sounds but it doesn't play. Also the volume in the config is grayed out and can't be changed. Tried to configure as manual with F1, F2, ... With same results. Lights and smoke generator are working fine.
Does anybody encountered this issues before and/or have a suggestion on how to reset/diagnose the problem?
J
#2 Posted : 17 February 2016 15:41:39(UTC)
I have a memory of several such problems a few years ago that were due to blown speakers. If you have access to a multimeter try measuring the resistance of the loudspeaker coils. You will need to desolder it for a meaningful reading.
The resistance should be very low, less than 5 ohms. If it is higher then the speaker is defective and needs to be replaced.
Offline Br01
#3 Posted : 04 March 2016 00:52:19(UTC)
Br01
Hi, sorry for the delay and thank you for your help. I'll try to get a multimeter and will try then.
J
thanks 1 user liked this useful post by Br01
This page was generated in 0.380 seconds.
