#1 Posted : 19 January 2016 22:06:29(UTC)
I have encountered a problem when converting two of my locos with 5 pole conversion sets (60760) Both locos are of the same type, the Primex variants of the Br141 electric. They are catalogue numbers 3199 and 3186. Both come with the 3 pole DCM motor like later Marklin models of this type.
After fitting the parts for the 5 pole motor (magnet, armature and brush plate) the screws are no longer long enough to thread onto the motor block. The lower right screw just grips, but the upper left does not even reach the thread. In both cases I have given up and converted them to digital using, in one case, a delta decoder, and in the other a 6080, both of which retain the AC motor. I would prefer a better decoder.
Is there a Marklin screw which is slightly longer for this conversion? If so does anyone know the part number?
If this becomes too difficult for want of a longer screw I can always use a lokpilot conversion with Hamo magnet, which retains the original brush plate and commutator so must have the same dimensions.
Any thoughts?
Offline biedmatt
#2 Posted : 19 January 2016 22:55:17(UTC)
biedmatt
Since the permanent magnet is wider than the field coil, longer screws are a must. Don't these conversion kits come with longer screws? I'm thinking I've had to cut some off because they are so long they touch and bind the armature.
Matt
Era 3
#3 Posted : 19 January 2016 23:05:54(UTC)
The longer screws are sold separately. The MRR dealer of my trust was so kind to point this out when I stocked up before successfully carrying out my first analogue to digital conversion.
Offline biedmatt
#4 Posted : 19 January 2016 23:13:14(UTC)
biedmatt
M describes 60941, 43 and 44 as "...and installation hardware."
The 60944 I have on the shelf has four screws in a sealed bag with the ground ring meant to go under the screw head, two insulation tubes for the chokes and the two chokes. Unfortunately I do not have any of the other two kits to check those.
Matt
Era 3
#5 Posted : 19 January 2016 23:20:17(UTC)
Went through my trash can to find the plastic bag:
Märklin, Zylinderschraube, 785140
Last time I went there, my MRR dealer near Lisbon had them in stock.
They speak English and ship to other countries:
Web: comboioselectricos.com
email: encomendas@comboioselectricos.com
#6 Posted : 19 January 2016 23:24:32(UTC)
As I understand 60943 and 60944 contain long screws, and 60941 does not.
#7 Posted : 19 January 2016 23:47:10(UTC)
Thanks for your help.
I already checked the screws left over from my 60944 kits, but they are all of a wider diameter.
I have done many conversions of DCM motors in the past and I have only found a problem with the Br141 models. I have no idea why.
I'll see if I can get a couple of the screws mentioned by Ak.
#8 Posted : 20 January 2016 01:21:30(UTC)
Views messages in topic : 18,778
The 60760 kit doesn't come with screws, the other kits do.
This page was generated in 0.859 seconds.
