Offline nelson77
#1 Posted : 04 January 2016 23:52:19(UTC)
nelson77
Should I make a thumb drive back up for my main Cs2 and also my slave CS2 for can the main CS2 be used for both?
Nelson
Offline sjlauritsen
#2 Posted : 05 January 2016 06:33:44(UTC)
sjlauritsen
You can backup the one CS2 and restore the backup on the other. It might be a good idea to have the same configuration on both CS2's, I guess it depends on what you want with your setup.
I have several backups with different configurations that I use from time to time. E.g. I have my exhibition layout on a backup, so I can restore it whenever I go to exhibitions. When the exhibition layout is packed up in storage, I have a "clean CS2" backup that I use as a sort of "custom factory reset". That way I can "reset" the CS2 when I come home, and use the CS2 for other stuff in the time between exhibitions.
I also use the clean backup to help others that have messed something up. It is much easier.
Søren from Denmark
#3 Posted : 05 January 2016 10:04:21(UTC)
When you buy an new CS2,there is no need to reset CS2 before to start.
CS2 are factory prepare to start.
Right?
This page was generated in 0.301 seconds.
