Offline Carim
#1 Posted : 30 December 2015 13:10:28(UTC)
Carim
You have been a member since:: 15/09/2014(UTC)
My 88680 loco (Br 101) has a 3-Pole motor and was a really good runner but it needs new brushes. The brushes specified are part #8989; however, these brushes are no longer available. My 5-Pole versions of this loco need brushes #89891 and from the parts diagrams they look like the #8989. But I read elsewhere that the 5-pole brushes are similar to the 3-pole ones but not the same. Can I substitute #89891 for #8989? (What is the difference between the two?).
Carim
#2 Posted : 30 December 2015 13:45:48(UTC)
Hi, Carim,
I don't remember where I read it, but I recall reading that "five-pole" brushes can be used for three-pole motors, but not the other way around.
Here's a dealer page that confirms this (with reference to Märklin Magazin 6/2012):
http://www.modellbau-tru...atzteile-m%C3%A4rklin-z/
Offline Carim
#3 Posted : 30 December 2015 16:14:12(UTC)
Carim
Hi Tom,
Thanks for that info and link; very helpful.
Carim
#4 Posted : 30 December 2015 20:47:00(UTC)
Hi, Carim,
I suspect the brush is slightly 'shorter' in the circumference measurement to accomodate dealing with a 5 segment commutator instead of a 3 segment one, so I would suggets it would work. A 3 pole brush would probably bridge segments on a 5 pole armature, resulting in problems for the motor.
Offline Poor Skeleton
#5 Posted : 05 March 2020 23:24:56(UTC)
Poor Skeleton
Hi Carim,
For the sake of closure can you confirm whether of not the substitution of the 5-pole brushes was successful? Do you feel the loco ran any better or poorer afterwards?
Chris
Offline Carim
#6 Posted : 06 March 2020 11:05:14(UTC)
Carim
Hi Chris,
I am afraid that you are really pushing my memory on this one. I think I followed Tom's advice and they worked. But after some time, if I remember correctly, the motor packed up and I replaced it with a 5-pole motor. I do remember that I just accepted that the 3-pole was old (it was a second hand loco), rather than thinking it had anything to do with the brushes. I think that I thought that the run-in 3-pole motor gave better performance than the 5-pole motor.
Kind regards,
Carim
This page was generated in 0.329 seconds.
