Offline Tom Jessop
#1 Posted : 09 November 2015 21:01:23(UTC)
Tom Jessop
Playing with the idea of using a double track wye in one part of the layout , I have asked this question before & received answers but seem to have lost the plans somewhere of what tracks I need . Could any one point me in the right direction as to where something like this may be found . I have done a archive search on the archives here with no luck .
Thanks in advance ,
Tom in Oz who still has to do his report on our European holiday & thoughts on Eurospoor & the IMA show .
Offline PeFu
#2 Posted : 10 November 2015 00:24:51(UTC)
PeFu
Thanks in advance ,
Hi Tom,
What type of track?
BigGrin Peter
Offline Tom Jessop
#3 Posted : 10 November 2015 00:31:47(UTC)
Tom Jessop
Opps I put in the header but forgot about the main message . I am using K track .
Offline GLI
#4 Posted : 10 November 2015 01:48:29(UTC)
GLI
Hi Tom
If you are simply building a double Y junction, then all you should need is 2 points (both either right or left handed), a diamond crossing and a couple of lengths of flexible K track. I wouldn't waste my time or go to the added expense and complexity of trying to build it out of set pieces of K track.
In the heading, you mention a double triangular junction. By this, do you mean a junction similar to the triangular junction in Sydney located between Chester Hill, Regents Park and Bankstown. If so, then you would need 6 pairs of points, 3 diamond crossings, and a few more lengths of flexible K track. Again, I wouldn't go to the expense of trying to build it out set pieces of K traak.
I have to say I am a little puzzled by your question and hope I haven't misunderstood your query, as I would have thought the answer would have been obvious to an experienced railwayman like yourself.
Geoff
Offline Tom Jessop
#5 Posted : 10 November 2015 02:10:47(UTC)
Tom Jessop
Actually after the set track part numbers needed for this . I must be still a bit jet lagged & forgetting to ask the full question
Cheers Tom in Oz
Offline GLI
#6 Posted : 10 November 2015 03:35:28(UTC)
GLI
Hi Tom
I wondered if that might be the case as I was typing my post. Regretably, I am unable to assist you as I gave up using set track 3 decades ago.
Geoff
This page was generated in 0.241 seconds.
