Offline Moritz-BR365
#1 Posted : 03 June 2015 08:41:49(UTC)
Moritz-BR365
for a friend I replaced the standard fx decoder of the Ludmilla with the Hobby mSD sound decoder set. The mtc21 adapter bord is ready to connect a buffer capacitor which is very usefull for this loco. There is plenty of space inside the loco. I decided to use a 1.200µF capacitor and glued it directly under the roof.
I realized, that the distance of the two connectors is the same like the distance between three connectors of the pin connectors, I bought in the past. Therefore, it is very easy: Just cut the connectors of the capacitor in the correct length and prepare a connector on the cables. Now You can plug the connector directly onto the capacitor.
As always, I used the standard charging circuit, which is fitted into the black shrinking hose:
The loco drives very smooth and without stutter on my test M-rail.
Edited by user 04 June 2015 08:47:21(UTC)  | Reason: Not specified
thanks 4 users liked this useful post by Moritz-BR365
#2 Posted : 03 June 2015 11:21:47(UTC)
Thanks Moritz. What is the value of R1, and is D1 a common diode such as a 1N4001?
1.2µF seems an unusual value, my local electronics store only seem to list a 1.0µF then a 2.2µF electrolytic capacitors.
#3 Posted : 03 June 2015 11:24:54(UTC)
Moritz-BR365
Next, I will test the Doehner&Haass SD21A-4 Sound decoder with the Ludmilla sound from Matthias Henning in this loco. I will create a video with this sound project. Stay tuned!
thanks 2 users liked this useful post by Moritz-BR365
#4 Posted : 03 June 2015 11:30:46(UTC)
Moritz-BR365
R1 = 100 Ohm
D1 = SB140 (Schottky Diode)
A schottky diode is preferred, because the reverse voltage is only ~0.5V, a 1N4001 has a reverse voltage of ~1.0V.
The capacitor has a capacity of 1.200µF, not 1.2µF.
Greetings, Moritz
#5 Posted : 03 June 2015 20:30:51(UTC)
Moritz-BR365
thanks 5 users liked this useful post by Moritz-BR365
#6 Posted : 03 June 2015 22:44:37(UTC)
Hmmm, must be a European decimal notation thing.....
Here in NZ, 1.200 and 1.2 means the same thing - it is all to do with where the decimal point is.
However, I see that in Europe they use the decimal point "." as the thousands separator, whereas we would use the comma "," as the thousands separator.
So, here in NZ (and Australia, the UK and US) 1200 is expressed as 1,200. In Europe, it seems they would use 1.200. And to make things even more weird, Europe uses the comma where we would use a decimal point - €123.45 is expressed in Europe as €123,45.
Confused Confused Confused
Anyway, I have the same problem with the local electronics supplier - no 1200µF capacitors, only 1000µF or 2200µF.
However, an online supplier such as Element14 (formerly Pharnell) have them....
http://nz.element14.com/...ts=true&pf=110095704
#7 Posted : 03 June 2015 23:33:57(UTC)
Moritz-BR365
Yes, it is confused!
1000µF is as good as 1200µF, or better if there is enough space available, 2200µF or 1800µF.
Important, it should be at least 25V versions, better 35V!
Offline biedmatt
#8 Posted : 03 June 2015 23:39:52(UTC)
biedmatt
Greetings, Moritz
Comma or decimal isn't the problem. The problem is the decimal is used as two separate meanings in the same sentence. Once to make reading a four digit number easier and again to show a fractional value. That is what is confusing. Had one or the other been a comma, we'd have understood.
Matt
Era 3
#9 Posted : 04 June 2015 07:51:59(UTC)
Moritz-BR365
There is only one value given:
And, yes, we use in germany often a wrong notation.
For technical values, You can read 1.2µF or e.g. 15.2mH. But, it is not misunderstandable, because:
If You want to say 1200€ then You could say 1.200€ or 1.2k€ (correct euopean notation would be 1,2k€). But 1.2€ is never a short form of 1,2k€!
Or, in general notation:
1,000,000.00 (US, UK)
1.000.000,00 (European)
1.000.000.00 (wrong European, mix of US and European notation)
But what about the Doehler&Haass Ludmilla sound?
Offline Modelleisenbahnfan
#10 Posted : 04 June 2015 10:02:35(UTC)
Modelleisenbahnfan
Hello Moritz,
I don't know the Sound of the prototype, but I find the Sound realistic. One can hear clearly that it is a diesel electric locomotive.
The additional features as the conductor whistle or the horn are also very good, I think.
Perhaps, you could improve the driving characteristics, so the loco starts smoother respectively has a minor speed in running step one.
kind regards
Robert
P.S.: What is a Kilo-Euro (k€)?
If you all want to be clear, why don't you write out the figures?Smile In this case it would be: one thousand two hundret if I have well understood.
Märklin, what else?
#11 Posted : 04 June 2015 10:11:07(UTC)
Moritz-BR365
Yes, I will spend a bit more time for fine tuning, but the speed in FS1 is really very slow. You can see in the middle of the video.
It is a common way to shorten a value bigger then 1000 with the short cut "k":
1000 m/h = 1km/h
1000 € = 1k€
Many people think, that "k" is a short cut for kilogramm, but that's wrong. "k" says "* 1000". When You are told to buy 1k apples, You should buy 1000 apples, not only 1kg!
#12 Posted : 04 June 2015 10:24:42(UTC)
Modelleisenbahnfan
Hi Moritz,
of course I know that the "k" stand for the factor thousand, but I have never seen it in connection with Euro.
Commonly, it's used for example in connection with Newton (kN), Gramm (kg), Bytes (KB) and so on.
kind regards
Robert
Märklin, what else?
#13 Posted : 04 June 2015 10:33:10(UTC)
Moritz-BR365
In business areas it is avery common to use k or M for thousand or million:
10k€
50M€
You may have a look into the balance sheet of big companies, You will find it there. I use it therefore also very often, because our calculations are done in k€, too.
#14 Posted : 06 June 2015 09:14:21(UTC)
https://www.youtube.com/watch?v=Gv5aL1b42FQ
Is it same sound volume in all functions,like Märklins?
Or is it adjustable of the volume with difference functions?
#15 Posted : 06 June 2015 12:31:09(UTC)
Moritz-BR365
the sound volume is adjustable for each sound slot seperately. You can do this by POM, so it's very comfortable to adjust and test until it fits Your needs.
CV 330 Gesamtlautstärke
CV 331 Lautstärke Fahrgeräusch
CV 332 Lautstärke Nebengeräusch
CV 333 Lautstärke Schaltgeräusch
CV 334 Lautstärke Bremsgeräusch
CV 335 Lautstärke Soundablauf 3
CV 336 Lautstärke Soundablauf 4
CV 337 Lautstärke Soundablauf 5
CV 338 Lautstärke Soundablauf 6
CV 339 Lautstärke Soundablauf 7
CV 340 Lautstärke Soundablauf 8
CV 341 Lautstärke Soundablauf 9
CV 342 Lautstärke Soundablauf 10
CV 343 Lautstärke Soundablauf 11
CV 344 Lautstärke Soundablauf 12
CV 345 Lautstärke Soundablauf 13
CV 346 Lautstärke Soundablauf 14
CV 347 Lautstärke Soundablauf 15
CV 348 Lautstärke Soundablauf 16
This page was generated in 0.511 seconds.
