Offline waorb
#1 Posted : 18 March 2015 15:41:43(UTC)
waorb
Brazil
Hello!
I'm particulary interested in the upcoming BR 24 (#36243), promised to 3Q/2015.
The description says that the smoke generator is always on, even being a lok with MFX decoder an plenty of sounds on board.
No possibility to turn the smoke off digitally, just insert the oil and go. It's supposed to be smoking until the end of the oil.
Older loks (analog ones) have this 'technology' because at that time, the concept design/engineering doesn't permit this feature.
My question, it's really reliable?
It will be "hot" all the time, or the oil is the trigger of the electric connection inside the generator?
Thanks for the coments.
Walter
#2 Posted : 18 March 2015 15:49:54(UTC)
And the function table indicates the smoke generator can be controlled digitally.
I presume it's just another copy'n'paste error by Mother M.
Smoke generator was always on with 36240, but AFAIK it can be controlled with later versions of the loco with mfx.
Offline waorb
#3 Posted : 18 March 2015 19:06:55(UTC)
waorb
Brazil
Thanks Tom!
Since the text and the functions table have this conflict, I was in doubt why Märklin create a lok without this feature even with MFX decoder... doesn't seem to worth it....
Meanwhile, both english and german websites have the same "error" in this description... Even in the catalog the text is the same...
Even if the description is correct, it's bad to the generator stay on all the time?
Walter
#4 Posted : 18 March 2015 20:08:38(UTC)
Seuthe write: "Achtung: Wenn kein Dampfdestillat eingefüllt ist, sollten die Dampfgeneratoren - wenn möglich - abgeschaltet werden. " and "Das verlängert auf jeden Fall die Lebensdauer."
They advise to switch empty smoke generators off if possible.
They write the smoke generators can withstand the constant voltage even if they are empty, but they will last longer if you turn them off when they are empty.
Offline waorb
#5 Posted : 18 March 2015 20:42:40(UTC)
waorb
Brazil
Hello Tom!
Thanks again for the clarification. Good to know what Seuthe says 'officially'.
I don't believe that Märklin will drop on the market, these days, a lok without this control _with_ a MFX decoder...
Even so, I don't feel comfortable to let this on all the time - without oil.
Walter
#6 Posted : 21 March 2015 10:28:49(UTC)
Hello Tom!
Walter
The worst that could happen is that the coil in the smoke generator will blow and it will no longer work. If you're not using the smoke anyway it's no great loss....
Offline waorb
#7 Posted : 23 March 2015 13:31:49(UTC)
waorb
Brazil
I agree with you Ray, unfortunately in Brazil it's very difficult even exchange parts (need to send it to Germany), or buy a new one (need a traveller to/from Germany). The last option, send by mail from overseas, it's a pain... 60% of import duties plus various taxes, and minimum of 2 or 3 months to arrive... Crying
So, we need to take care a lot of the parts we have...
Walter
#8 Posted : 23 March 2015 14:04:54(UTC)
The loco comes without smoke generator. Don't install a smoke generator if you don't need smoke at all.
Don't forget to order a smoke generator if you want smoke.
Most likely the smoke generator can be controlled digitally.
Offline NZMarklinist
#9 Posted : 05 April 2015 08:50:42(UTC)
NZMarklinist
Hello Walter,
The Marklin description in the product database : http://www.maerklin.de/p...SetNew=1&bShowLogo=0
(you might have to type in 36243 Wink) has the "Smoke Generator Contact as a switchable function in the normal Marklin no 1 position (No1 makes it available to analogue users) Wink
so I would be fairly confident in ordering a 36243 and a 72270 Marklin Smoke unit, (or a Seuthe #20 smoke unit.)
To save $$$ order Suethe E20 then it comes without the accessories, even order two, you'll use it somewhere in the end Woot
If a list member has a 36242 which is the Wagner smoke deflector version of 2013 with MFX decoder and switchable smoke,, they may like to confirm this feature ??????
If it were not switchable then a Seuthe #24 would do the trick.
I bought 36241 off ebay a few years ago at a good price Wink because I prefer the Witte smoke deflectors on this model ThumpUp
I have it on my short list for a digital upgrade to full sounds with switchable smoke function, and I bought it with this in mind !
It is funny how if a Marklin Model's specification doesn't exactly suit you, if you wait a year or five, maybe eight or ten, they will reproduce it with a better suite of decoder functions at least ! Wink
see; https://www.marklin-user...14-11801.aspx#post486364
Edited by user 07 April 2015 11:22:27(UTC)  | Reason: correct Seuthe part number
Glen
Auckland NZ
#10 Posted : 05 April 2015 09:07:01(UTC)
If it were not switchable then a Seuthe #21 would do the trick.
#24, not #21.
#11 Posted : 05 April 2015 09:51:51(UTC)
Hello!
Walter
Hello!
It seems strange about smoke generator permanent on,when it´s an mfx decoder and like others steam locomotive they do have digital functions off/on.
I believe it´s misprints of Märklin,because they show up with an diagram of digital functions and it stand smoke as digital function.
#12 Posted : 07 April 2015 10:54:57(UTC)
NZMarklinist
#24, not #21.
Correct Tom, well spotted, apologies to Walter Wink
Glen
Auckland NZ
Guest (6)
This page was generated in 0.524 seconds.
