Offline jorge_vilarrubi
#1 Posted : 07 February 2015 00:39:42(UTC)
jorge_vilarrubi
Does anybody know any way for connecting a SUSI device (a sound module in this case) to a Lokpilot V4.0 M4 with 21MTC interface?
The Lokprogrammer shows an option to enable SUSI, but I couldn't find any information about how to connect the module to the decoder.
Any help will be welcome.
Thanks in advance.
Jorge Vilarrubi, Buenos Aires, Argentina
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#2 Posted : 07 February 2015 08:13:23(UTC)
Some locos have a SUSI socket on the loco board.
Otherwise you can always cut off the plug and solder the connections.
#3 Posted : 07 February 2015 13:02:45(UTC)
jorge_vilarrubi
Hi Tom, thanks for your reply.
My question is related to a Decoder-to-SUSI connection.
SUSI standards establish both a protocol and a wiring scheme.
Pin1 - black - Ground
Pin2 - gray - Data
Pin3 - blue - Clock
Pin4 - red - Power (Unregulated + track voltage)
Whay I need to know is to what pins of the 21MTC I have to connect the four SUSI wires.
Soldering the wires to the decoder is not a problem.
Jorge.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline biedmatt
#4 Posted : 07 February 2015 13:46:21(UTC)
biedmatt
I would think your best place to find an answer is here:
http://www.esu.eu/en/dow...anuals/digital-decoders/
If the maker of the decoder can not tell you what you need, I do not know who could.
Matt
Era 3
#5 Posted : 07 February 2015 15:02:47(UTC)
jorge_vilarrubi
Hi Matt,
I belive I've found the solution.
21MTC has four pins that should provide both voltage and info to the SUSI sound module.
16 - V+
20 - GND
5 - clock
6 - data
Will try that and see what happens.
Jorge.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
thanks 1 user liked this useful post by jorge_vilarrubi
#6 Posted : 08 February 2015 12:41:50(UTC)
jorge_vilarrubi
Hi Matt et al, my solution has worked.
CV124 must be set accordingly.
Jorge
Jorge Vilarrubí
Buenos Aires
ARGENTINA
This page was generated in 0.273 seconds.
