#1 Posted : 07 December 2014 02:30:31(UTC)
Having heaps of a problem on changing the language from German to English.
So would like a Button by button, blow by blow process to do this. lost count of getting the English selection surrounded by black, pressed the BIG Round Button ( throttle) and it still stays in German.
HELP Scream
Nev
Edited by user 10 December 2014 22:42:29(UTC)  | Reason: Not specified
#2 Posted : 07 December 2014 03:25:19(UTC)
You need the MS2 for seniors edition.. LOL
If you have a look on the forum you will see that Tom (H0) has already done a guide, complete with pictures, just for you.. Tom tells me that all money will be gratefully accepted by his wallet.. LOL
Here is the link.. https://www.marklin-users.net/forum/yaf_postst17822_Marklin-Mobile-Station-2--60653---TRIX-66950.aspx
#3 Posted : 07 December 2014 03:31:39(UTC)
ANd here I thought that you had snaffled the lot.
Flapper LOL
#4 Posted : 07 December 2014 03:50:38(UTC)
Still no luck, there is a vital step on how to select english and how to save it.
Crying
Nev.
Another Question:
Will the MS2 recognise Selectrix???
I do not think it does.
nn
#5 Posted : 07 December 2014 04:21:22(UTC)
Is Sprache a clue? See picture #2.. You might have missed the options (Optionen) menu item? RollEyes
Then you select English.. See picture #3..
Perhaps you need the video entitled, "MS2 for Seniors"... It is recorded at high speed and played back at normal speed.. LOL
#6 Posted : 07 December 2014 09:46:34(UTC)
No.
MäTrix make neither controllers nor decoders with support for Selectrix (N gauge decoders with Selectrix still come from third parties).
Re MS2 language setting:
I don't recall which buttons have to be pressed - but since there is no check mark on my screen shots I presume that the big green one (throttle) should be correct.
#7 Posted : 07 December 2014 23:06:51(UTC)
Thanks Tom , have tried that , maybe I have a faulty MS2 or rather a stubborn one that will not leave the family Language.
Nev
#8 Posted : 07 December 2014 23:24:09(UTC)
I tried it: you have to press the button on the left side of the screen - the one beside the language you want (one of the two inner buttons on the left). With the buttons on the right you can scroll down to other languages (I presume Nev prefers English, but others may prefer other languages).
#9 Posted : 07 December 2014 23:29:55(UTC)
Thanks Tom,
another one why is stop on the screen, does that mean you have to press Stop to save?
Offline baggio
#10 Posted : 08 December 2014 01:52:20(UTC)
baggio
Page 4 of the manual (link is Tom's long step=by-step very helpful post) gives you in English the steps to change the language. You will need to rotate the page, however.
Hope this helps. If not, I will attach it in PDF form.
#11 Posted : 08 December 2014 02:17:55(UTC)
Thanks, there is a step missing somewhere, this sucker is staying Strictly German and does not want to leave the homeland. tried all suggestions, even reading the manual, following toms instructions etc. May have to take it back under warranty.
Crying
Nev
Offline franciscohg
#12 Posted : 08 December 2014 03:50:18(UTC)
franciscohg
Chile
Hi Nev, i am out on a trip, will be back home on Tuesday, if you have not solved it by then, we could connect trough skipe for live step by step. Will have to be looking at the ms2 too
#13 Posted : 08 December 2014 08:06:45(UTC)
Thanks will be in that, will have to check I think tat will be a Wednesday here.
I think best time is about 7-8 PM your time or a bit later. then 8-9am here. Just looked at diary maybe 6-30pm-7pm tuesday would be good. have to go out at 9am here which is 8PM tuesday night.
#14 Posted : 08 December 2014 17:28:51(UTC)
Delete...
Edited by user 11 December 2014 18:06:46(UTC)  | Reason: Not specified
Offline 3rail4life
#15 Posted : 09 December 2014 16:54:10(UTC)
3rail4life
Hi Nev,
Hope you get things sorted out with your MS2. If the language stays German even after changing it to English you may experiencing a similar software bug to what was discussed in this post:
MS2 will not change language
An update from another MS2 fixed it...
Gordon
Offline franciscohg
#16 Posted : 10 December 2014 17:49:11(UTC)
franciscohg
Chile
So.....Nev, did you solve the problem?
I will be at home around 1800.
It is now 1342.
Drop me a message trough Facebook if you can
#17 Posted : 10 December 2014 22:41:38(UTC)
It looks like that my MS2 requires a software update to cure the problem, so into the local provider of out favourite addiction and get the beast upgraded.
When trying to change the language I never got an Auto restart.
SO if that does not cure its stubborn behaviour Out comes the ECOS.
Thanks for all help and suggestions.
The Ecos will also solve a power dilemma that I had in my mind.
nev
thanks 3 users liked this useful post by nevw
Offline Charlie
#18 Posted : 11 December 2014 13:31:29(UTC)
Charlie
Nev, I had made a video, just for you 2 years ago :-)
thanks 3 users liked this useful post by Charlie
#19 Posted : 11 December 2014 21:56:29(UTC)
Charlie, what foresight, you knew 2 years ago That I would get a MS2 this year, marvelous. I will give it another go later and report back.
Thanks, Charlie
At least it was not a Pink one LOL
This page was generated in 0.532 seconds.
