#1 Posted : 29 November 2014 23:52:19(UTC)
wIth the N gauge Start set I got , it has a MS2 , 18V 1 Amp power supply.
I have not tested it to full type load but think that 1A would not be sufficient to run 2-4 trains, some with lit carriages, 8 Point motors and powering 2 M83 decoder boxes.
I was thinking of using a Laptop power supply in place of the original, rated at 19V 4.5 amps.
Would this be a suitable alternative?? Or a Smoke producer?
nev
Offline tulit
#2 Posted : 30 November 2014 01:49:55(UTC)
tulit
The ms2 (with the track connector box) is current limited at 1.9A so any supply bigger won't make a difference.
There is a 36VA supply, art no. 66361.
If you need more than that you'll probably need to find a alternative control station.
thanks 1 user liked this useful post by tulit
#3 Posted : 30 November 2014 02:33:59(UTC)
Thanks, most likely If the stable grows I will get another ECOS, or of real desperate a Trix CS2. ECOS is the favorite
This page was generated in 0.418 seconds.
