Offline Motley
#1 Posted : 01 August 2014 07:44:57(UTC)
Motley
Hello, I'm new to Marklin never owned any of their locomotives before. I want to buy this loco here:
Manufacturer: Marklin
Item: 39017
Gauge: HO
With MFX digital sound decoder.
Express Locomotive BR 01 150 DB MHI Wooden Box
I have an NCE Power House Pro 5amp DCC system.
Is this MFX digital decoder compatible with my system? Will all the funcions work?
I want to make sure before I buy this.
Thanks for all the help.....
#2 Posted : 01 August 2014 08:22:57(UTC)
Welcome to the forum!
The Märklin 39017 understands the protocols MM and mfx, but not NMRA DCC.
Does your controller support the MM protocol? Probably not.
Märklin 39017 is a three-rail loco.
Trix 22250 is the same model, but as a two-rail version and with NMRA DCC decoder.
Märklin are able to put mfx, MM, and DCC into a single decoder. They use this with 1 gauge models and decoder upgrade sets only, but not with H0 gauge models.
If you have two-rail track, the Trix loco should work nicely.
Offline sjlauritsen
#3 Posted : 01 August 2014 08:36:28(UTC)
sjlauritsen
As Tom states the #39017 is a three rail locomotive. The Trix version #22250 is a two-rail version with a DCC decoder.
I have a review of the model on my blog: http://www.bahnfan.net/p...Steamer-01-150-From-Trix
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#4 Posted : 01 August 2014 09:57:49(UTC)
Item: 39017
Gauge: HO
Yours digital system have only DCC protocol and don´t support mfx/MM protocol.
If you shall buy an Märklin train,i suggest you change digital system that supports mfx/MM.
If not less in cheaper way...change out Märklins mfx decoder to ESU multiprotocol sound decoder,which supports DCC protocol too.
Just in case to remember...you must have 3 rail tracks to use Märklin trains.
Offline Motley
#5 Posted : 01 August 2014 15:53:32(UTC)
Motley
Oh wow, I had no idea the Marklin locomotives were 3 rail, I assumed it was two rail because of the HO scale designation.
I have code 83 track. Will the Trix passenger cars with lights work on my track and system? Part # T23446
I will look into the Trix locomotive then.
I appreciate the help!
Offline Motley
#6 Posted : 01 August 2014 16:17:35(UTC)
Motley
Well shoot, they don't have the Trix 22250 in stock.
Will the Trix 22393 have a DCC decoder? They have that one in stock.
#7 Posted : 01 August 2014 18:39:11(UTC)
Yes, it has.
Trix locos will have a DCC decoder (sometimes with support for either SX or mfx) or will be analogue with a NEM (or non-NEM) decoder socket (decoder can simply be plugged in).
Trix product database:
http://www.trixtrains.com/trix_pdbs.html
According to the German database, the 22393 has a motor with bell-shaped armature (from the good ol' days before they economised loco propulsion).
English text says "maintenance-free can motor".
The lights of the coaches 23446 should work with your rails (red rear lights of one coach - interior lights must be bought separately).
The set contains one coach in length scale 1:87 and five shortened coaches (1:93.5).
Offline Motley
#8 Posted : 01 August 2014 23:36:49(UTC)
Motley
Thanks Tom, I appreciate all the help!
One more question. Couplers. Are the couplers that come with the locomotive and passenger cars good? Or is there a Kadee replacement for them?
I prefer using Kadee couplers on all my equipment.
#9 Posted : 02 August 2014 08:17:12(UTC)
The Märklin/Trix close couplers work fine with Trix items. No need to replace them if you buy a complete Trix train.
When buying Märklin coaches, ask the seller to swap the wheelsets (wheelsets are normally the only difference between Trix and Märklin coaches - sometimes they have different road numbers and you can buy both to get a longer train).
I have no experience with Kadee couplers. Locos and coaches have NEM pockets for couplers and other couplers can be used.
Märklin/Trix couplers often cause problems with scale models (Märklin and Trix do not have scale buffers to make room for the couplers).
See also:
http://blog.mailez.de/eblog/?p=65
#10 Posted : 02 August 2014 08:43:32(UTC)
Yes you can use Kadee couples on the Trix wagons and locomotivs.
But you must use Kadee couples for NEM pockets.
Kadee have 4 of them:short,medium,long and extra long.
I recommend you try with short and medium couples.
It fits good.
Offline DamonKelly
#11 Posted : 02 August 2014 10:41:10(UTC)
DamonKelly
This bit's important:
Märklin coaches (and locos) have wheelsets that are conductive between the two outside rails i.e. they will cause a short circuit if you use them on a 2-rail setup. Generally, 2-rail (i.e. insulated) wheelsets are available for all coaches.
Damon
Guest (6)
This page was generated in 0.475 seconds.
