Offline jacqvw
#1 Posted : 19 July 2014 18:37:50(UTC)
jacqvw
I have some old tin plate cars which are causing a short circuit on the 24711/12 turnouts.
As far as I can see, the wheels are touching the middle studs just after the metal frog at the intermediate railpiece. This would suggest that the distance between wheels is smaller than it should be.
I measured between 13.88 and 13.97, while wheels on newer tinplates cars are 14.3mm.
What is the standard distance between wheels on Marklin and is it possible that this changed over the years? My old tinplate cars date from the sixties!
(arrows indicate damage from sparks)
jacqvw attached the following image(s):
Marklin C 110m on 500 x 200 cm; CS2; North America era III
thanks 1 user liked this useful post by jacqvw
#2 Posted : 19 July 2014 20:22:46(UTC)
The current standard distance is 14.0 mm through 14.1 mm.
I have no experience with such old items, but I presume wheels are much narrower now and the distance between the wheels is in turn larger.
Sorry, but I cannot suggest a solution (but probably others will).
Offline Yumgui
#3 Posted : 19 July 2014 20:24:44(UTC)
Yumgui
13.8mm from inner sides of flanges was standard Märklin ... dunno about newer models (Tom, 14.0mm since when ?), but some wheel movement may have occurred on your older models over the years ...
A good tool for checking here : http://www.fohrmann.com/...ahner/rail-gauge-h0.html
Hope it helps,
Y Cool
thanks 3 users liked this useful post by Yumgui
Offline Janne75
#4 Posted : 19 July 2014 23:01:40(UTC)
Janne75
I had the same problem with some of my older coaches or cars, but only with these wider radius turnouts 24711 and 24712. Thank you for posting this topic and to all from answers. Now when I know the reason for these problems I will use only newer type on this layout. Older wheels don't cause any problems with "normal" turnouts 24611 and 24612 though. Nowadays I don't run older rollingstock often on my digital layout, so this problem is kind of solved by this.
Janne
Online cookee_nz
#5 Posted : 20 July 2014 02:46:39(UTC)
Janne
Interesting topic and very clear photos.
I wonder, would a change of wheelset help with this issue and if possible, what would be the correct part numbers to obtain for a retro-fit?
Alternatively, could this be as simple as the flange diameter on these older wheels been too large and if you had the equipment (ie a lathe) could the flange be turned down a little to remove the interference?
Steve
#6 Posted : 20 July 2014 03:38:13(UTC)
My question to you is whether the tinplate coaches you are having problems with are equipped with lighting?
The usual problem is that the inner wheels touch the centre stud, causing a short with the axle.
The reason why I asked about lighting is because on coaches equipped with slider (interior lighting/taillights), the raised studs can cause the slider to retract and bring it in contact with the axle. If you do have sliders mounted, ensure that they can move without contacting the axle and that the wires/connections do not cause a short.
The older coaches had a slightly different flange diametre, which was designed for M Track. You may be able to replace the original axles with newer ones that were designed for the most recent productions of tin plate coaches which may improve operation.
Offline Hoffmann
#7 Posted : 20 July 2014 04:03:37(UTC)
Hoffmann
Can You please post a Picture of the Boogie from the Car ( upside down ) . It is possible that the Frame of the Boogie is bend and therefor the Wheels move at a Angle to the track.
Other then that the Flange of the Wheel may also be worn or not run true.
Martin
marklin-eh
Offline jacqvw
#8 Posted : 20 July 2014 20:29:08(UTC)
jacqvw
Thanks for your suggestions and replies.
I had some old wheels left and measured them all, substituted the smallest ones (the less than 13.9mm ones)
I also put some acrylic nail polish around the studs closest to the metal frog, to insulate the sides of the stud (sand the top a bit after it dries).
See photo, the six closest to the frog.
Et voila, my train and cars are running around for 15 min now, without drawing sparks on the 24711 and 24712 turn outs. Simple solution, a bit of insulation.
thanks 8 users liked this useful post by jacqvw
Offline nmbssncb
#9 Posted : 28 July 2014 12:13:25(UTC)
nmbssncb
If increasing or decreasing the wheel distance does not help, put some heat shrink tube over the studs that are closest to the rails.
Willy
Offline jacqvw
#10 Posted : 28 July 2014 20:57:10(UTC)
jacqvw
Willy
I used acrylic nail polish. Also does the job.
Offline Tom Jessop
#11 Posted : 28 July 2014 23:23:48(UTC)
Tom Jessop
Should one ask what colour nail polish you use ?? Signal red or maybe some go faster green >
Cheers Tom in Oz. [with 3 weeks to go to retirement .]
#12 Posted : 29 July 2014 00:46:51(UTC)
Hi Tom,
Congratulations on your forthcoming retirement. ThumpUp
Mind you, according to your profile you are now 112 years old, so I guess it's about time! BigGrin
Offline Tom Jessop
#13 Posted : 29 July 2014 06:08:46(UTC)
Tom Jessop
Well that oversight has been fixed , & Ray just so you don't have to look up my profile I can proudly say I commenced gunzelling on Oct 1 1948.
Cheers Tom in Oz
#14 Posted : 30 July 2014 08:54:53(UTC)
OK, that makes more sense! BigGrin
This page was generated in 0.960 seconds.
