Offline jonas_sthlm
#1 Posted : 29 May 2014 10:09:27(UTC)
jonas_sthlm
Hello Cool
What’s the different between this interior kit?
Something with effect white or yellowish light image Confused
Offline Iamnotthecrazyone
#2 Posted : 29 May 2014 12:57:20(UTC)
Iamnotthecrazyone
Hello Cool
I don't fully understand your question but the two of them appear in the catalogue 2009/2010 which I have handy. The difference seems to be they are made to fit different skirted wagons. Both sets -at least in this older catalogue- have two regular light bulbs
Offline jonas_sthlm
#3 Posted : 29 May 2014 17:12:29(UTC)
jonas_sthlm
It looks to me that the difference would be the construction of pickupshoe only?
Will the yellow LED be more comparable light shade like the old lamps?
#4 Posted : 29 May 2014 18:40:19(UTC)
It´s pick up shoes that is difference,because wagons underframe is not same like other.
Offline jonas_sthlm
#5 Posted : 29 May 2014 19:14:58(UTC)
jonas_sthlm
Sorry all,
I only look under the product page instead for the latest catalog.
It same that skirted wagons can also use 72020/72021 LED lights ThumpUp
#6 Posted : 30 May 2014 04:20:02(UTC)
Iamnotthecrazyone
I doubt any currently made lighting kit will have yellow LEDs but if you are talking about old ones that might be the case. Since LEDs became popular I haven't bought any lighting kit sold separately from Marklin. I do however have a few trains that have the LED lights factory installed by Marklin and personally I think they are horrible.
Regular incandescent light bulbs produce a much nicer and realistic light. You can obtain similar looks to light bulbs by using "warm white" LED's. They have also the convenience of producing less heat that could deform the plastic.
Regular white LED's can be very good when you use them on wagons that in real life are illuminated by fluorescent tubes, the effect is quite similar.
I don't know what kind of LED's Marklin is using on the current lighting kits as if I want to add lights I'll probably build them myself. With many modern wagons you need one pick up shoe only, current conducting couplers but in most cases you do need to buy and install the wheel pick ups for all wagons, I have bought several of those wheel pick ups but to this point I haven't used them.
This page was generated in 0.262 seconds.
