Offline Marklin in Oz
#1 Posted : 21 May 2014 04:09:54(UTC)
Marklin in Oz
Are the lamp posts for M Track uncouplers plug in compatible with digital C Track uncouplers?
Confused Confused
Just curious.
-Fred
Offline Iamnotthecrazyone
#2 Posted : 21 May 2014 04:19:06(UTC)
Iamnotthecrazyone
Confused Confused
Just curious.
-Fred
I believe so or they used to, I am mainly posting because C track un-couplers aren't digital, unless there is a new model I am not aware of, they do not include a decoder within the track.
thanks 1 user liked this useful post by Iamnotthecrazyone
#3 Posted : 21 May 2014 04:24:11(UTC)
Marklin in Oz
I thought they could be digitized. Don't feel too bad, I could be the one way off base. Good to know though.
Thank you.
-Fred
#4 Posted : 21 May 2014 09:43:09(UTC)
Uncoupler tracks can be made to work in digital using a K83 module (6083/60830)
Using it in this way the lamp tower will light for a short duration when the digital controller commands that address.
The K83 decoder will control up to four dual solenoid devices such as turnouts or signals. or up to eight single solenoid devices such as uncoupler tracks.
#5 Posted : 21 May 2014 12:08:04(UTC)
Iamnotthecrazyone
Thank you.
-Fred
Yes, "could be" being the keywordsWoot , that applies as well to the 1950's un-couplers. As Ray pointed out you do need to add an external decoder.
I did some checking and it seems the light mast is the same one they've been making forever. Current catalogue number is 74997 and they seem to be using an old graphic that looks the same as in 1950's catalogues, they haven't bother even taking a new photo. I would say it won't last much longer since the light part is huge when thinking for HO scale.
Offline waorb
#6 Posted : 21 May 2014 15:44:08(UTC)
waorb
Brazil
My two cents.
Adjust the time (increase maybe to the higher possible) of the signal that CS2 sends to the uncoupler. This will make the lamp stays on for a more realistic way.
Walter
#7 Posted : 21 May 2014 21:19:37(UTC)
Or use a k84....
This page was generated in 0.439 seconds.
