#1 Posted : 04 May 2014 20:12:02(UTC)
I only have one Italian dialogue. Maybe the community can provide more.
Dialogue #1:
"sono" should come after the second number and there should be a full stop at the end.
It seems they have the same error in several languages (Italian, Swedish, French - maybe more).
Offline Renato
#2 Posted : 05 May 2014 00:25:50(UTC)
Renato
Hi Tom,
I do not have a CS2, but could give a hand if Italian screenshots are provided.
Renato
#3 Posted : 05 May 2014 07:56:22(UTC)
Hi, Renato!
Thanks for that offer. If Märklin is open for suggestions, I may get back to you.
#4 Posted : 05 May 2014 20:50:40(UTC)
I am actually seriously thinking about suggesting that this international forum should go into a cooperation with M to sort out their language problems in products...
Am I asking too much?
Offline andreasapo
#5 Posted : 11 May 2014 14:32:04(UTC)
andreasapo
I can also helpt with Italian translations.
#6 Posted : 25 May 2014 21:35:08(UTC)
Dialogue #2:
The Italian keyboard.
The "é" key produces "è" characters and there are two keys for "§".
#7 Posted : 25 May 2014 21:36:41(UTC)
Dialogue #3:
The new Italian setup screen.
#8 Posted : 25 May 2014 21:39:20(UTC)
Dialogue #4:
The long Italian text causes the horizontal scrollbar to appear which in turn causes the vertical scrollbar to also show.
The important information is now hidden.
So a much shorter Italian phrase (with abbreviations maybe) would be needed here.
#9 Posted : 25 May 2014 21:40:55(UTC)
Dialogue #5:
I find the combination "Giorno", "Giorno", and "Notte" irritating.
What do native Italian speakers think about it?
#10 Posted : 25 May 2014 21:43:10(UTC)
Dialogue #6:
The new setup tab "empo Modell".
Is "Modello" with upper-case "M" correct in "Ora di inizio Modello"?
Offline Renato
#11 Posted : 26 May 2014 00:10:27(UTC)
Renato
Hi Tom,
Here there are my corrections:
Dialogue #2:
The simbol over the number 3 must be the simbol £ (Pound)
At the right of letter P on top the symbol must be é (with the SHIFT key) and on the bottom the symbol must be è (without the SHIFT key)
At the right of letter L on top the symbol must be ç (with the SHIFT key) and on the bottom the symbol must be ò (without the SHIFT key)
The symbol § is at the correct place
This is the standard Italian keyboard layout
Renato
Edited by user 26 May 2014 12:02:18(UTC)  | Reason: Added: This is the standard Italian keyboard layout
Offline Renato
#12 Posted : 26 May 2014 00:28:43(UTC)
Renato
Dialogue #3:
Dialogue #3:
Daten: Dati:
Sichern Salvataggio (Backup)
Wiederherstellen Ripristino (Restore)
Update: Aggiornamento:
Netz Rete (Network)
Sound: Suono:
Update Aggiornamento
Neustart Riavvio
Beenden Fermata (Stop)
For some words it could be better to use the English translations as they are common in Information Technology environment.
I am not able to translate the 2 "FS" over "0" red circled (I do not know their use).
Maybe for the a.m. terms it could be better to use the verb instead of the noun.
Now I go to sleep and will continue tomorrow
Renato
Offline Renato
#13 Posted : 26 May 2014 00:40:54(UTC)
Renato
Dialogue #5:
My suggestion is Modo (for Giorno e Notte) as the first Giorno should refer to the background brightness.
So Giorno has a brighter screen and Notte the opposite.
Renato
#14 Posted : 26 May 2014 07:39:45(UTC)
Hi, Renato,
The "FS" stands for speed step. The number showing next to the green speed bar is subject to perpetual changes.
IIRC it used to be a percent value, then changed to prototype speed, and now it shows speed steps.
I hope they make it adjustable with the next release. I like to be able to see the speed steps, but many others want the scale speed back.
This page was generated in 0.697 seconds.
