Offline bygger01
#1 Posted : 23 February 2014 18:28:44(UTC)
bygger01
My turntable (7286) has begun with a humming, vibrating sound, particularly when operating continuously
The sound vary on where the bridge is
It works with analog and AC, and is leveled
Are there any proposals to eliminate the sound
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
thanks 1 user liked this useful post by bygger01
Offline Renato
#2 Posted : 23 February 2014 18:36:29(UTC)
Renato
Hi Joergen,
I had some suggestions but they apply to the previous turntable model.
As I do not have your model (another type of motor I think), unfortunately I am not able to help you.
Renato
thanks 1 user liked this useful post by Renato
Offline kbvrod
#3 Posted : 23 February 2014 18:41:54(UTC)
kbvrod
Hi Jørgen,all,
First and foremost check the motor first.Also check ALL the wiring both with TT and the controller.
Dr D
#4 Posted : 25 February 2014 11:31:25(UTC)
Hi Jørgen,
I have had this turntable for some years.
It did start to make such noise some years ago but after a little oil to the moter it quietened.
If you have the instruction booklet it shows you where to apply the oil.
PJ
Offline bygger01
#5 Posted : 25 February 2014 17:41:42(UTC)
bygger01
It seems that I need to find out how I can lift bridge.
Is it "just" to loosen the screw in the center + remove items at both ends?
Did not find a drawing on Märklin website / is it in?
And by the way thank you for the inputs
Offline kbvrod
#6 Posted : 25 February 2014 18:09:32(UTC)
kbvrod
Hi Jørgen,yes.You need to remove two pieces at either end of the bridge.It does not have to be a track.
BTW,this TT is a FL model,not a M one.
D
Offline bygger01
#7 Posted : 25 February 2014 18:30:37(UTC)
bygger01
Hi Jørgen,
PJ
The booklet is not found, so is it just the shaft ?
Offline BrandonVA
#8 Posted : 25 February 2014 18:43:36(UTC)
BrandonVA
Copy and paste this into your browser address bar, you should be able to see the manual.
-Brandon
Offline bygger01
#9 Posted : 25 February 2014 20:43:13(UTC)
bygger01
-Brandon
Sorry I have to say that it is in the enclosed brochure ......
So I have get started.
Thank you for your promptness.
We will also use the removal for some wheathering + yellow painting
I will also come back with a conclusion !
#10 Posted : 27 February 2014 12:00:53(UTC)
-Brandon
Hello again,
Interesting that the current manual warns against oiling.
My turntable was actually from Fleischmann, about a year or so before Märklin started selling it (but it was still made by Fleischmann, as I believe remains the case.)
The original manual indeed describes how to oil the unit (see image below)
PJ
Offline kbvrod
#11 Posted : 27 February 2014 16:16:39(UTC)
kbvrod
Hi PJ,all,
Remove the bridge and apply power to the motor directly.Still have a problem?
Dr D
thanks 1 user liked this useful post by kbvrod
Offline bygger01
#12 Posted : 01 March 2014 22:09:00(UTC)
bygger01
I've tried to drip a little oil into both holes, and it seems to have helped, but then the sound had moved and not as powerful ( with good help from Tasmania )
The bridge is also of for giving something extra patina.
I have also made 4 screws under, so that the turntable can be completely leveled.
Offline bygger01
#13 Posted : 21 March 2014 21:35:53(UTC)
bygger01
My conclusion
  • The bridge is assembled and functioning
    The oil does not seem particularly to have helped
    Sound output is now only in the same place (about 90 degrees)
    The base is leveled and supported
    The sound is only when the analog control is set for continuous operation
    So it must be the magnet that provides for "no stop" that clack
So how I come around that, I don't know, but my wife has made ​​some good improvements with the weathering
This page was generated in 0.578 seconds.
