Joined: 23/11/2008(UTC) Posts: 225 Location: Herning in Denmark
My turntable (7286) has begun with a humming, vibrating sound, particularly when operating continuously The sound vary on where the bridge is It works with analog and AC, and is leveled Are there any proposals to eliminate the sound |
Best regards Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/- |
 1 user liked this useful post by bygger01
Joined: 19/03/2004(UTC) Posts: 976 Location: Gorizia, Italy
Hi Joergen,
I had some suggestions but they apply to the previous turntable model.
As I do not have your model (another type of motor I think), unfortunately I am not able to help you.
Renato
 1 user liked this useful post by Renato
Joined: 23/08/2006(UTC) Posts: 2,597 Location: Beverly, MA
Originally Posted by: bygger01  My turntable (7286) has begun with a humming, vibrating sound, particularly when operating continuously The sound vary on where the bridge is It works with analog and AC, and is leveled Are there any proposals to eliminate the sound Hi Jørgen,all, First and foremost check the motor first.Also check ALL the wiring both with TT and the controller. Dr D
Joined: 04/12/2013(UTC) Posts: 2,266 Location: Hobart, Australia
Hi Jørgen, I have had this turntable for some years. It did start to make such noise some years ago but after a little oil to the moter it quietened. If you have the instruction booklet it shows you where to apply the oil. Regards, PJ
 2 users liked this useful post by PJMärklin
It seems that I need to find out how I can lift bridge. Is it "just" to loosen the screw in the center + remove items at both ends? Did not find a drawing on Märklin website / is it in?
And by the way thank you for the inputs |
Originally Posted by: bygger01  It seems that I need to find out how I can lift bridge. Is it "just" to loosen the screw in the center + remove items at both ends? Did not find a drawing on Märklin website / is it in?
And by the way thank you for the inputs Hi Jørgen,yes.You need to remove two pieces at either end of the bridge.It does not have to be a track. BTW,this TT is a FL model,not a M one. D
Originally Posted by: PJMärklin  Hi Jørgen, I have had this turntable for some years. It did start to make such noise some years ago but after a little oil to the moter it quietened. If you have the instruction booklet it shows you where to apply the oil. Regards, PJ  The booklet is not found, so is it just the shaft ? |
Copy and paste this into your browser address bar, you should be able to see the manual. -Brandon |
Originally Posted by: BrandonVA  Copy and paste this into your browser address bar, you should be able to see the manual. -Brandon Sorry I have to say that it is in the enclosed brochure ...... So I have get started. Thank you for your promptness. We will also use the removal for some wheathering + yellow painting I will also come back with a conclusion ! |
Originally Posted by: BrandonVA  Copy and paste this into your browser address bar, you should be able to see the manual. -Brandon Hello again, Interesting that the current manual warns against oiling. My turntable was actually from Fleischmann, about a year or so before Märklin started selling it (but it was still made by Fleischmann, as I believe remains the case.) The original manual indeed describes how to oil the unit (see image below) Regards, PJ
 1 user liked this useful post by PJMärklin
Hi PJ,all, Remove the bridge and apply power to the motor directly.Still have a problem?
Dr D
 1 user liked this useful post by kbvrod
I've tried to drip a little oil into both holes, and it seems to have helped, but then the sound had moved and not as powerful ( with good help from Tasmania )
The bridge is also of for giving something extra patina.
I have also made 4 screws under, so that the turntable can be completely leveled. |
My conclusion - The bridge is assembled and functioning
The oil does not seem particularly to have helped Sound output is now only in the same place (about 90 degrees) The base is leveled and supported The sound is only when the analog control is set for continuous operation So it must be the magnet that provides for "no stop" that clack
So how I come around that, I don't know, but my wife has made some good improvements with the weathering |
