Offline drbob01
#1 Posted : 20 January 2014 01:49:32(UTC)
drbob01
I have a ESU 50200 command station and presently have two locos running. The Marklin NYCentral loco diesel (29576) runs fine with all sounds operational. However, I cannot seem to find the PRR 37624 diesel in the database of locos on ESU and therefore not all of the digital sound functions are operational. I have tried several different choices but none are quite the right one. There is no listing for a 37624 loco on the database. Any ideas?
Thanks!
#2 Posted : 20 January 2014 02:33:36(UTC)
Most likely the 37624 was produced after the Ecos database was last updated, so does not appear in the database. After Marklin and ESU parted company over their collaboration, the Ecos database stopped being updated - no information updates provided by Marklin.
The best thing for you to do is to pick another loco that is in the database that has similar functions to your loco, and use that as a basis to define the settings for your loco.
Offline biedmatt
#3 Posted : 20 January 2014 04:14:57(UTC)
biedmatt
It's an MFX decoder right? Didn't the ECoS auto register it?
Matt
Era 3
#4 Posted : 20 January 2014 05:00:42(UTC)
Correct!
I was operating under the assumption that the loco has a FX decoder. As Matt points out, the mFX decoder should register with your Ecos (I assume the Ecos is up to date software wise?)
Offline drbob01
#5 Posted : 21 January 2014 19:38:11(UTC)
drbob01
Yes, its FX decoder. Somehow, when I have the loco on the track and try to find it manually, it just says, no loco on track. There are some similar ones that have some of the functions, but not the bell and sqealing brakes, etc. Just the basic light, horns, and engine sound. I did have it at one time, but have not lost it and don't know how to get all the functions back.
#6 Posted : 21 January 2014 20:50:01(UTC)
Do you know the loco's address?
You can then set it up as I previously explained. If there are then missing functions, these can be added by editing the loco parameters in the Ecos. You can also select an icon to suit the function.
Check the Ecos manual for details on how to do that.
If the loco has an FX decoder, you will only be able to define 4 functions plus the lights, so it shouldn't be too hard to do that. Check the loco's manual which will list what the functions are.
Offline drbob01
#7 Posted : 22 January 2014 22:23:23(UTC)
drbob01
I found this on a previous post on locos reviews :Märklin 37624 - F7 Pennsylvania
37624 F7 A-B-A Pennsylvania.
Lenght - 520 mm.
Sounds - Diesel operating sounds, horn, bell, letting off air, squealing brakes off.
Decoder + Motor = MFX with high-efficiency propulsion.
Detailment - No Issue on C-tracks.
Childen? - Age 14 and over.
Coupling? - Hook in front and rear. Can be changed with NEM or snowplows with hooks.
Headlight? - 1 in front with lighted numbersigns.
Loco body - Metal.
6021 address coding - 07.
60212/3 Name at factory - F 7 #9654.
Traction Tyres? - Eight.
Functions
F0 Headlights and signboards front.
F1 Sound effect: Short Horn.
F2 Operating sounds.
F3 Sound effect: Horn.
F4 ABV.
F5 Sound effect: Squealing brakes off
F6 Sound effect: Letting off air
F7 Sound effect. Bell
However, I cannot find address 60212 or 6021 or F7 #9654 on my command station. It's weird, because at one time, it was working, but now I cannot recall what the address was...
#8 Posted : 22 January 2014 23:10:45(UTC)
That post indicates that the default address is 07. However, the loco is mfx so it should register with your Ecos. Check to make sure mfx is enabled on your Ecos.
Offline drbob01
#9 Posted : 22 January 2014 23:59:15(UTC)
drbob01
Ok! Will do and will report! Thanks!
#10 Posted : 23 January 2014 02:58:44(UTC)
6021 refers to Marklin's older 6021 digital controller (max 80 addresses, no mfx). 60212 refers to the Central Station 1 and 60213/60214/60215 refers to the current Central Station 2.
Offline drbob01
#11 Posted : 28 January 2014 02:05:35(UTC)
drbob01
It sure is nice to have smart people on this forum! As was suggested by Bigdaddynz, it is the mfx issue that prevented the identification of my locos! on page 9 of the manual, paragraph 7.1.1.7 M4 I realized that I had not checked to see if M4 was checked on my command station. After I found it, I checked it and re-ran manual installation. Viola! it found both my locos and ALL of the decoder functions! They now work great! Thanks for all the input and help!
thanks 1 user liked this useful post by drbob01
#12 Posted : 28 January 2014 02:14:04(UTC)
Not so sure about the smart bit! I'm well aware of this problem, having had a few brain fades and 'Doh' moments myself! Glad to be of help.
This page was generated in 0.485 seconds.
