Offline ria
#1 Posted : 04 April 2008 14:13:09(UTC)
ria
Yesterday I posted a question in another topic about wiring tracks in order to make a shuttle train with CS and Viessmann 5217 s88 but since I feel like a dummy I open this new topic cause I'm lucking of basic kwnolege in wiring and I didn't want to continue to a topic that wasn't really relaited to my problem.
I connected the ground the mass exit of the S88 with the rail mass of the central station (0) that is something that I read many times in the forum.
My problem is were the wire from the port go? And the blue wire from 24994 ? Should I isolate some trucks ?
For example starting from one end I have 24088-24188-24994-24188-24188-24188-24995-24188-24188-24188-24188-24995-24188 and so on
In central I thing I know what to do
a)Have multi ownership enabled
b)Configure s88 module 16 ports
c)Configure shuttle train and then assign a lok to that
As you can see I need step by step instuction in wiring. If anyone has a picture or a diagramm it would be very helpfull
Thank you in advance for your help and again forgive me if my questions look stupid to you [:I]
Ria
Offline mascagni
#2 Posted : 05 April 2008 13:47:53(UTC)
mascagni
Ria: I have made a shuttle train myself using the CS and VM 5217 for my Xmas layout, but that is put away. So let me suggest a couple of things.
1. You can independently check that you have working occupancy detection with the s88 bus. Can you, in fact, see that little boxes in s88 mode change when you run a wagon over the detection region.
2. Once you have two detection regions that work, you need to define a shuttle route with a start and end detection.
3. Then you start a train in the region and stop the CS, and switch it into the shuttle mode.
If you are not detecting the s88 signals, your shuttle train will surely not work. Make sure the signals are sensed by the CS. Once that is in place, the manual describes how to set up the shuttle train pretty easily. If your problem is really wiring the track, then that is another issue.
Good luck.--MM
Michael Mascagni, Tallahassee
Offline Caplin
#3 Posted : 05 April 2008 14:35:53(UTC)
Caplin
Hi Ria,
Like Michael I have packed my layout away, so I can't add much, but did you see this topic: https://www.marklin-user...ult.aspx?g=posts&t=9107.
One thing I remembered doing wrong was that, quoting Michaels 3rd line:
"3. Then you start a train in the region and stop the CS, and switch it into the shuttle mode" - I stopped the loco a few times before I realized that it was the CS that had to be stopped - hitting the STOP button.
It is also important that you stop the CS <u>after</u> the loco has reached the 22994 or 24995 in the other end.
One other thing from your line of tracks. You only need one 24995 at each end (or 24994 if you prefer). You have listed 3 items on your line. On my test setup I had a 24994 in one end and a 22995 in the other end to get the feel of it, and it works.
Good luck.
Benny - Outsider and MFDWPL
Offline ria
#4 Posted : 05 April 2008 15:37:36(UTC)
ria
Thank you very much for your replies and help.Finally I got it with a combination of 2 24994 (one at each end) and works perfect!!! Smile
The best forum in the world !!!
Ria
Offline mascagni
#5 Posted : 05 April 2008 16:11:58(UTC)
mascagni
Ria: Just a little question: was the problem that the occupancy detection required more fiddling about?--MM
Offline mascagni
#6 Posted : 05 April 2008 17:51:16(UTC)
mascagni
Ria: One other comment: if you are using C-track, it is trivial to modify any single (non-turnout) to be an occupancy detector. The idea is to use the red insulators to insulate the rails from the tracks on either side. Then, with a Dremmel tool, you isolate both rails from one another. Then you put a wire on on one of the rails to your s88. When an AC wheelset passes the track, it closes the circuit you have opened, and the s88 detects the change. I actually used my CS to make sure I could do this to a track, and then, for fun, thought that the shuttle train would be a good application.--MM
Offline ria
#7 Posted : 05 April 2008 18:13:52(UTC)
ria
[size=1" face="Verdana" id="quote]quote:Originally posted by mascagni
<br />Ria: Just a little question: was the problem that the occupancy detection required more fiddling about?--MM
Yes it did. It was the first time that I used s88 module. Now I will try your proposal for making occupancy detectors and I will inform you about my progress. Again thank you
Ria
Offline mascagni
#8 Posted : 05 April 2008 20:13:11(UTC)
mascagni
Ria: Here is a thread I started a while ago, and it has some links (some dead unfortunately):
http://127.0.0.1:4664/redir?url=http%3A%2F%2Fwww%2Emarklin%2Dusers%2Enet%2Fapplications%2Fforum3%2Ftopic%2Easp%3FTOPIC%5FID%3D8203&src=8&schema=2&s=b-uujndGYwgC1TP1uDQw7seUv-0
Offline Caplin
#9 Posted : 06 April 2008 02:57:20(UTC)
Caplin
Michael,
the primary thread itself is dead, at least at this time stamp.
This page was generated in 0.305 seconds.
