Offline PierreGILLARD
#1 Posted : 01 December 2013 20:47:21(UTC)
PierreGILLARD
Probably a stupid question for the experts here ... Nothing is explained in the locomotive manual Mad.
Thanks.
Pierre.
#2 Posted : 01 December 2013 21:26:54(UTC)
Same procedure as for any programmable Märklin loco. Do you have instructions from other Märklin locos?
Or see instructions on page 11 of this manual:
Code:
http://medienpdb.maerklin.de/product_files/1/pdf/60760_betrieb.pdf
Copy URL to address field.
#3 Posted : 01 December 2013 21:40:36(UTC)
PierreGILLARD
Code:
Thanks Tom. I will do this right now. My previous Märklin locomotive address programmation change was with switches on the decoder ...
Pierre.
#4 Posted : 01 December 2013 22:11:37(UTC)
So you missed a few years.
For a few years they included programming instructions in the loco manuals.
Re step 5: after pressing GO, hold the knob in the reversing position until the loco starts blinking.
The switches on the CU 6021 should be off-on-off-off.
#5 Posted : 02 December 2013 12:37:47(UTC)
Reset your 6021. Push Off Button. Enter Address '80', while holding the throttle in the reverse position, press "on". The lights on the locomotive should flash. Enter '01" and reverse the throttle. Lights should flash faster. Enter desired address and reverse again. The lok should now respond to the new address.
On some loks, you may have to enter the actual address of the lok instead of '80'
The other way to change the address of a locomotive is to move to a new house.
Offline biedmatt
#6 Posted : 02 December 2013 13:46:30(UTC)
biedmatt
The tricky part is when holding the throttle in reverse and pressing on, hold both events (keep pressing on) until the lights start to blink. The instructions are kinda vague there.
Matt
Era 3
#7 Posted : 02 December 2013 14:01:08(UTC)
No need to hold "On" down. Just make sure you hold the reversing position before, while, and after clicking "On" until the lights are flashing.
#8 Posted : 02 December 2013 20:59:44(UTC)
PierreGILLARD
Thanks a lot for the info.
I succeded at third attempt !
Pierre.
thanks 1 user liked this useful post by PierreGILLARD
Offline biedmatt
#9 Posted : 03 December 2013 02:33:20(UTC)
biedmatt
When I held reverse and then touched on, most times the decoder would not enter program mode. Just sit there with the lights out. I found that if I held reverse and then held on until the lights flash, I could enter program mode every time. This is perhaps why it took three tries to get program mode. I found it quite frustating, hit and mostly miss, until I started to hold on.
Matt
Era 3
#10 Posted : 03 December 2013 08:15:41(UTC)
I never hold "On", I just tap it. Sometimes it takes two tries to get the loco lights flashing. It's not necessary to hold "On" and I don't think it improves the result.
Märklin uses at least four types of decoders (from different manufacturer) that are programmed this way. For a scientific examination one would have to take all types of decoders and test each type 100 times with and without holding "On" to see which methods yields better results with with type. And there are different firmware releases of the CU 6021 (at least three) and all have to be tested.
I won't do that.
Hold "On" or don't hold "On" - it can work both ways.
Offline biedmatt
#11 Posted : 03 December 2013 11:49:05(UTC)
biedmatt
I won't do that.
I also wouldn't do that. Now all my MFX decoders end up in a box.
Matt
Era 3
This page was generated in 0.376 seconds.
