Offline tandrschaefer
#1 Posted : 11 November 2013 06:45:51(UTC)
tandrschaefer
How can I tell the difference between a Marklin F800 BR 01-097 3008 and a 3026 I see on ebay the F800 BR 01-097 is listed as a 3008 and a 3026 I would like to properly identify mine.
Offline Janne75
#2 Posted : 11 November 2013 09:02:52(UTC)
Janne75
I'm not 100% sure about this, but I just try to understand my German Koll's Kompakt Katalog 2012...
It seems like it is F 800 and maybe not 3008 or 3026? Confused 3026 has Telex. I can see from your pictures that the locomotive has traction tyres. The very first F 800 version has not them. Second version has them and it still has a metal tender with real coal load. Third version has a plastic tender...
What text there is in locomotive body and tender? Is the tender metal or plastic? I need more information or better pictures to identify it... RollEyes
Janne
#3 Posted : 11 November 2013 09:10:47(UTC)
tandrschaefer
Janne
tender is plastic for sure
#4 Posted : 11 November 2013 09:13:05(UTC)
tandrschaefer
Janne
text says F800
01-097 every where and tender says 3006
Offline Janne75
#5 Posted : 11 November 2013 10:02:59(UTC)
Janne75
Hi again,
Locomotive is a F 800, but plastic tender should have "809" or "01 097, F 809/1" if it is from F 800. 3026 tender should have these "01 097, F 809/1" or "01 097, 3026". Nothing about "3006"... Confused
Janne
#6 Posted : 11 November 2013 16:25:59(UTC)
3026 have fitted with telex at back.
Your model was F800.5 (1956) or F800.6 (1957) with wide coupling at tender.
I have a F800.1 or F800.2 with differemny tender (metal bogie).
http://imageshack.us/a/img96/4142/7zvf.jpg
#7 Posted : 11 November 2013 17:08:03(UTC)
tandrschaefer
Hi again,
Janne
Janne thanks again for your help you are correct the tender says 01-097 across the back and marklin on one side and F 809/1 on the other side so im still wondering if it is a 3026 or a 3008 or are those numbers interchangeable?
Thanks Tim
#8 Posted : 11 November 2013 17:17:16(UTC)
tandrschaefer
Thank you steventrain for your comment yes they are metal boogie with plastic covers over the boogie not die cast for sure... how do you know that there is F800.1 F800.2 F800.5 is there some sort of book, publication, that helps you with this or is this just experience.. Why do people have them listed on ebay as a F800 - 3026 or a F800 - 3008 they are about the 3008 is almost double the 3026....
Thank you
Tim
This page was generated in 0.381 seconds.
