Offline Enebakk
#1 Posted : 03 September 2009 01:07:38(UTC)
Enebakk
I have an analog train that I'll like to convert to a digital train. I have never done this before, but beeing a techie I've got no problems jumping into it.
But, where do I start? Are there convertion sets I can use or am I better of doing this step by step buying individual parts?
I hope anybody out there has done something like this and can give me a bundle of good advice.
Johnnybiggrin
#2 Posted : 03 September 2009 01:36:04(UTC)
Views messages in topic : 5,382
Hi, Johnny.
Somebody will soon wake up and tell you, but in the meantime you can find many examples of different conversions on my website.
As far as I know, the 3060 has a <s>Large Flat Commutator Motor (LFCM)</s> Drum Commutator Motor (DCM), so Märklin conversion set <s>60924</s> 60921 will most likely fit. The set includes all the required motor parts to convert it to a 5-star motor, which runs much smoother than the 3-star originally fitted.
The set also includes a mfx decoder, noise supressors and some other small parts.
It is rather expencive, so there are cheaper options, like the Delta decoder 66032, which uses the original motor.
Some other manufactorers have some other solutions, but I leave it to people with more experience than me to tell you.
Edit: correction of motor type error, or maybe the 3060 has been made with both LFCM and DCM?
Offline rschaffr
#3 Posted : 03 September 2009 02:33:42(UTC)
rschaffr
Johnnie
Sorry I am late in getting to you, but I have not really had time lately to view much on the users net. I converted mine several years ago, but I did a full high performance motor upgrade and a LokSound 3.5 decoder. Total cos on a conversion like that is well over 100USD. If you are looking to just make it run digital, the marklin conversion kit above should satisfy you. I have many more things I intend to do with mine whenever get the chance...plan to make the marker lights addressable, include a MARS light, and harwire the three units (I also have a "B" unit) so all functions work in either direction. Maybe a winter project this year.
Added: Actually this is a pretty good lok to do your first conversion on. There is plenty of space in it. Some of them you really have t be creative to get the decoder to fit properly.
-Ron
Offline Philip
#4 Posted : 03 September 2009 06:56:50(UTC)
Philip
Hello Johnny
take a look at this site: http://www.digital-train.com/
have fun
Philip
Philip.
Let's keep it simple.
MFDWPL
#5 Posted : 03 September 2009 07:12:35(UTC)
Get yourself onto the internet and search ebay.de for conversion sets. around the Euro 30.-- mark.
I've used 5mm led's to fit into the lighthole.
So there are a few options available to you how to convert it.
regards.,
Offline Enebakk
#6 Posted : 07 September 2009 02:10:41(UTC)
Enebakk
Thank you very much.
I will try the 60291 converter, and keep you updated as to the progress. It will probably take some time as this is a job for the cold season.
Again thanks everyone.
Johnny
Offline rhobson1968
#7 Posted : 10 September 2009 23:24:57(UTC)
rhobson1968
I would sell it and buy a new one already converted. I had 22 analog trains that I wanted to convert, but after buying a couple of new digital ones I decided to let go... It was hard at first but once I had my new ones I was much happier. They run so much better and require less work. I am thinking of doing this with my wife too.. haha..
Never quit building.
#8 Posted : 06 October 2013 07:58:17(UTC)
Sorry to reopen this old topic, but I am slightly confused about the outcome of this post. Miss 14 and I have a 3160 Santa Fe set from 1964/65, which includes a 3060 loco. This loco is the first one that Miss 14 used, when she was Miss 3 and we thought that for its 50th birthday we would convert it to digital. I know that it will probably be cheaper to buy a nice digital Santa Fe, but the loco has sentimental value and there is not enough room to lay an analogue track in the train room/office/game room/brain room.
The problem is that the motor is SFCM (I think) and has eight teeth (I know). This is quite different to the two motors described by Intruder (Svein) in an earlier post. I have included a photo of the disassembled loco for your review in case I have not identified the motor correctly.
We would like to convert this to a soundless loco. Mfx is preferred - less hassle with updating the eCOS and WindigiPet.
What do we need? Confused
xxup attached the following image(s):
#9 Posted : 06 October 2013 08:25:44(UTC)
Adrian, get the 60944 kit, that has the motor parts for the LFCM, which includes 2 rotors for both 7 and 8 tooth engines. I don't think this is a SFCM engine.
#10 Posted : 06 October 2013 14:16:24(UTC)
Dave and Adrian,
I would try 60943. 60944 is for a large LFCM and this is definitely not a large flat commuter.
all F 7 came with SFCM and later changed to DCM.
You could change the lights with led's use a lokplilot with adapter plate and you can use the 4 Aux functions for your different lights, upper, lower or both and the road number plate and interior light for the motor compartment.
regards.,
Offline DamonKelly
#11 Posted : 06 October 2013 14:24:40(UTC)
DamonKelly
Adrian, if it is an SFCM, I've probably got the bits required in my "project box".
Give me a ring after this week, and I'll have a look.
Damon
thanks 1 user liked this useful post by DamonKelly
#12 Posted : 06 October 2013 14:41:06(UTC)
Adrian could use 1200 wet and dry, drill a hole big enough to take the shaft into a wooden block, place the sand paper onto it and press the commuter into the hole and turn the commuter forwards and backwards and you will get a shine surface.
regards.,
Offline Oliver nagel
#13 Posted : 06 October 2013 15:08:24(UTC)
Oliver nagel
I have just converted a 3060, The motor is a Small Flat Commutator Motor SFCM. What I did is remove all the dirt and old oil from the gears using dish soap water and a tooth brush, then oiled the gears again , Then I cleaned the commutator with tooth paste to remove all dirt and carbon. Order kit #64631 from Loksound/Esu this contains the chokes, decoder and magnet plus order new brushes Marklin 601460. Read the instructions 3 or 4 times from loksound then put it back together. Also there are two websites I use http://www.ajckids.com/TRAINS/MAIN.ASP?nr=92 and http://www.esu.eu/en/pro.../lokpilot-digital-sets/,
Good Luck Oliver
thanks 3 users liked this useful post by Oliver nagel
#14 Posted : 06 October 2013 15:41:37(UTC)
Sorry to contradict you, but this is an *S*FCM motor, thus requiring a 60943 kit.
If you'd like MfX I suggest using an ESU Lokpilot M4 V4.0 which IMHO is definitely the best value currently and the easiest to program and obtain consistent results.
Thes is even a little "auto-tune" feature which adjusts the regualtion parameters automatically, which removes one of the main difficulties of adapting thes decoders to the motors.
In addition to that, I'd say that the "recommended value" documented in the manual are pretty close to ideal.
If you have a Lokprogrammer , you rae even going to enjoy doing this...and will play with the parameters , "just for fun"!
I'm not associated with ESU, I'm just reporting from my own experience from many years of converting locos.
My two cents
#15 Posted : 06 October 2013 16:33:46(UTC)
Thank you John, Oliver, Jacques, David and Damon,
I have ordered the Marklin 60943 Set and the ESU 64610 M4 v4 decoder. They should arrived in a couple of weeks.
I will also take up John's suggestion to use LEDs. The current one just has one large bulb, which probably will consume buckets of power.
Does anyone know the part number of the tyres - there are two missing and the other two are looking very sad.
I have a few locos and this is the first SFCM I have ever seen.
#16 Posted : 06 October 2013 16:52:30(UTC)
I prefer to do it the other way around. I buy some new locomotives, but I like very much to buy older second hand locomotives and convert them to digital, using the different Märklin conversion sets. Sometimes I swap the decoders around, so according to my statistics the total number of retrofitted decoders are 127. It will soon be even higher.
Sorry for my very late reply/comment.
Offline jeehring
#17 Posted : 06 October 2013 17:19:59(UTC)
jeehring
...Cheers
Here, they just work for themselves : ESU is proposing one single type of decoder that must fit to many many... many different types of motors . That's typically a decoder designed for DCC market. I mean : more useful for two rails market.
2 rails market = a lot of different brands = different models = different design = a lot of different types of motors...Mainly facing to the lack of information about "what kind of motor I got on my 2 rails LOK & how to to have a good tuning"... this may be a better feature to compete other DCC decoders manufacturers, I consider it mainly as a " good commercial argument"...
In the world of Marklin 3 rails users generally don't share same questioning...Marklin has published some lists of models for each kind of Marklin decoders...( actually I would like to find one for myself...;don't remember where it is...RollEyes LOL )
thanks 1 user liked this useful post by jeehring
#18 Posted : 06 October 2013 17:51:06(UTC)
Lots of different motors reminds me of the market leader in the three-rail market. I had trouble getting smooth running from a 60942 in a relatively new Märklin loco.
ESU provides useful information about setting load regulation and many suggested values for different kinds of motors (half the list is for MäTrix motors).
#19 Posted : 06 October 2013 20:56:51(UTC)
Thank you John, Oliver, Jacques, David and Damon,...
You are quite welcome.
The tires are 7154.
Have fun with the conversion!
xxupH0
Offline Hoffmann
#20 Posted : 06 October 2013 21:17:47(UTC)
Hoffmann
Hello Adrian,
One more thing to remember ( if memory serves me right ) the bottom screw on the new Brush-Plate will be to long pay attention to that.
Martin
marklin-eh
thanks 1 user liked this useful post by Hoffmann
Online seatrains
#21 Posted : 06 October 2013 21:33:58(UTC)
seatrains
Adrian, I would like to convert my BN F7 to sound like thisFlapper
Good luck with the conversion and update us on your progress.
Thom
thanks 1 user liked this useful post by seatrains
#22 Posted : 07 October 2013 11:19:20(UTC)
Seems a bit nuts to have a SFCM in such a large loco. When Adrian mentioned 8 teeth on the anker, I immediately thought of the 60944 kit, as I've just fitted one to my 3021 V200 (that uses the 7 tooth anker - both are included in the kit).
My F7 is a 33622 Delta loco which I brought off 5HorizonsRR. That has a DCM motor, and I've converted it with a 60941 motor kit and msD sound decoder. I also have a 4060 Dummy 'A' unit, and a 4063 'B' unit.
#23 Posted : 07 October 2013 14:10:26(UTC)
Oliver nagel
thanks 1 user liked this useful post by Oliver nagel
#24 Posted : 07 October 2013 17:08:48(UTC)
My contribution to this topic,I converted my Santa Fe 3662 which have two motors with two 60941 motors and one 60942 decoder.Runs like a dream and pulling everything I put after her.No sounds but who cares?
#25 Posted : 22 October 2013 08:19:23(UTC)
An update. The digital conversion parts arrived last week, but today was the first time in ages that I could get started on the conversion.
Of course, I stripped down the loco and washed all the parts in Kerosene with a brush and then soaked in a white spirit to remove the kerosene. Assembled all the bits with minimal lubrication, and then disassembled and swapped the orange and grey wires so it would run in the correct direction. ESU say grey wire to right side of motor, but it works the other way around.. Must be a northern to southern hemisphere thing.. RollEyes
Configure the decoder with my new Lokprogrammer and V4 of the software. Set for a five pole motor, switch off all the DCC stuff and give the decoder a mFX name.. Very smooth running.
All working well on the roller test stand, so off to start the calibration using WindigiPet. Hits the first turnout and shorts out.. Scared Reset - hits another turnout and it shorts out again. It turns out that the leading edge of the slider is shorting on the front axle - this has clearly been an old problem as I see that there is pitting on the front axle from the shorting. I had assumed it was rust, but it was clearly shorting on turnouts when it was run as a analogue loco.. I fixed this by placing some electrical insulation tape on the upper part of the leading edge of the front slider.
So here is the question. I measured the slider to be 5cm. Is this the same length as the one on the normal 3060 Santa Fe?
Here is the speed profile from WindigiPet. I think that the top speed of 243km/hr in reverse might be a tad too fast. What was the maximum speed of a Santa Fe?
The upgrade is not finished yet. Two new horns and a fuel tank are on their way from the USA and should get here next week. Smile
#26 Posted : 22 October 2013 10:18:15(UTC)
AHere is the speed profile from WindigiPet. I think that the top speed of 243km/hr in reverse might be a tad too fast. What was the maximum speed of a Santa Fe?
Hello Adrian
GM EMD F-units were delivered with various gearing depending on the RR company requirements and the service (freight or passenger)
Santa Fe had them re-geared several times through their careers, when they shifted them from one type of duties to the other.
These changes happened so many times that it would probably very hard to track and document all of them.
But, to keep things simple we'll say that in freight service they were geared to 75 MPH, in passenger prime service ( "The Chiefs") to 100 MPH
Does that answer the question?
Now for the pick up shoe:
All my F-7s have been outfitted with the 60 mm "asymmetrical" pick up. (after I observed exactly the same phenomenon as you did)
The hole for the little mounting screw is located 35 mm from one edge, 25 mm from the other
The long part goes towards the nose.
Should not bother you ever after!
#27 Posted : 22 October 2013 10:24:42(UTC)
Hello Adrian
Thanks - I will settle for 120 Km/hr..
This is awesome information.. Do you have a part number for this part?.
#28 Posted : 22 October 2013 11:11:56(UTC)
Yes, the "old" number was 7185, must be something like 71850 today.
xxupH0
#29 Posted : 22 October 2013 11:34:09(UTC)
It's still 7185 (they keep the four digit numbers until they come with an improved version - so 71850 could become the Märklin whisper wiper number ...).
Five digit spare part numbers were extended to six digits when they introduced five digit ref. numbers for locos, coaches &c.
#30 Posted : 22 October 2013 13:32:01(UTC)
Thanks Tom.
Since Dr. Eisenbahn retirement, I haven't followed the details too closely.RollEyes
Feels good to know BigGrin ThumpUp Wink that you are there to fill the blanks!
This page was generated in 1.092 seconds.
