Offline Oliver nagel
#1 Posted : 23 September 2013 16:56:49(UTC)
Oliver nagel
I got a s88 feedback module cheap, but I need the ribbon cable that comes with it .Does anyone know the name of the plug/jack on the end ribbon cable so I can make one.Confused
#2 Posted : 23 September 2013 17:25:46(UTC)
Cable 6089 still in stock.
>S88 cable for 6088<
Offline Graham HO
#3 Posted : 26 September 2013 00:06:31(UTC)
Graham HO
If you have some basic soldering skills - get down to your local electronics store and buy a pair of 0.1" Header sockets and a half meter length of multi-coloured Ribbon Cable of at least 6 strands width - split the cable into 6 strands if wider (6 pins on CS2/S88) a suitable number of connecting pins should be supplied with each socket.
Do not twist the cable when soldering the pins on - it must remain flat so that you can check that the appropriate cable colours match from end to end. A minor modification may be need to one socket - there could be "polarising" bar moulded in - remove this with a sharp modelling knife and make a test fitting - either on S88 or CS2 - depending on which end you will fit. Insert the pins into the Header socket - make certain they are all facing the same way.
I offer no guarantees with this method, but it has worked for me - and is cheap.
thanks 2 users liked this useful post by Graham HO
Offline mancsaint
#4 Posted : 27 September 2013 13:27:20(UTC)
mancsaint
Great tip for me, if Maplins here in London, have the parts. Went there last week for this sort of parts and nobody had a clue what I was talking about.
Mancsaint
Offline Graham HO
#5 Posted : 28 September 2013 05:58:00(UTC)
Graham HO
Maplins have a selection of 2.54mm (0.1") PCB Socket/Headers [FY94C] - that could be cut down plus suitable Sockets pins [YW25C] and 6 Way White Sheath Alarm Cable [YS54J] or Brown Sheath [VK88Y] if Ribbon cable is unavailable. Some of these part numbers could be a little risky - so a personal search would confirm.
Offline mancsaint
#6 Posted : 28 September 2013 08:17:41(UTC)
mancsaint
Thank you Graham,
I went again yesterday to my local Maplins, here in Streatham, and might as well have asked for something from Mars. This is a very recently opened store so assume the staff were recruited locally and don't know their stock or their subject.
Thanks for the item numbers which I will quote on Monday when I make my third visit.
Mancsaint
Offline mancsaint
#7 Posted : 28 September 2013 08:35:50(UTC)
mancsaint
A search of the Maplins website indicates that only the FY94C header is available, I came across it yesterday but the other numbers are not recognised at all.
Will visit a different store for better knowledgeable staff.
Mancsaint
Offline mancsaint
#8 Posted : 28 September 2013 08:40:34(UTC)
mancsaint
Have come across LDT's site and this gives an option to the Marklin price for it's 6089 cable.
http://www.ldt-infocente...dback-bus/s88-bus-cable/
Mancsaint
thanks 1 user liked this useful post by mancsaint
Offline Graham HO
#9 Posted : 29 September 2013 05:40:20(UTC)
Graham HO
If Maplins have the FY94C 10 way Header Socket [which needs cutting down to 6 way] , then you could assume they also carry Socket pins of 10 piece strips? In terms of economy - a 12 way Header cut in half or a safer 17 way cut to 2 x 6 way could be an alternative.
An interesting observation - LDT are using what appears to be 6 Way Alarm Cable, maybe 3 twisted pairs - on their 6089 version cable. I have heard rumours that Ribbon Cable under certain conditions can be subject to electro-magnetic interference on this type of setup, hence the perceived limit of 2 meters with "off the shelf" lengths - are there any of our members who could clarify this - thanks in advance.
Offline Graham HO
#10 Posted : 29 September 2013 05:59:53(UTC)
Graham HO
Confirmation at www.Maplins.co.uk that Header Terminal contact pins are available on YW25C at the following stores as of todays date - Streatham, Clapham Junction, Wimbledon, Forest Hill, Croydon and Putney at £1.09 per 10 piece strip - it also appears that 10 way Headers are the largest they stock.
#11 Posted : 29 September 2013 18:00:46(UTC)
Oliver nagel
Looking around I found this to update your s88 and keep Radio interference down. http://www.floodland.nl/...info_s88_kabels_en_1.htm
Offline mancsaint
#12 Posted : 01 October 2013 19:39:32(UTC)
mancsaint
Thank you Graham H0 for that info , I went today and got the parts after quoting their numbers. Do I cut the pins into single pieces for insertion into the header?
Oliver, I have looked at this site recently and written to them for a quote on 2 x S88 to S88N adapters costing €7.50 each and received a reply today quoting €7.50 postage which I think is a bit steep so will have to think on it for a while.
Mancsaiint
Offline mancsaint
#13 Posted : 01 October 2013 23:03:39(UTC)
mancsaint
I searched EBay and finally came across "5 x 6-way latching pin header" exactly what I want. The Maplins ones need soldering whereas the, I think, just clamp the wire.
I also came across 2.54mm pitch 6 core ribbon cable ( will cut ends off)
http://www.ebay.co.uk/it...trksid=p3984.m1439.l2649
Thanks for everyone's suggestions.
Mancsaint
Offline Graham HO
#14 Posted : 01 October 2013 23:09:28(UTC)
Graham HO
Separate the contact pins with a pair of snips - when offering up the bare cable ends [do not over cut the insulation] for soldering, if this is the method you have chosen. Make sure there is sufficient free cable length to spread across the Header width. Try to support the pins in a clamp of some sort - this will make for a stable and neat job.
You will observe that each pin has a "one way hook" that when fitted will engage with a pre-formed slot in the Header - make sure you take care with this part as any misalignment will result in a poor fit. If this happens you will almost certainly have to start again and remove the offending pin - with difficulty - be warned - good luck.
Offline mancsaint
#15 Posted : 02 October 2013 09:58:48(UTC)
mancsaint
Graham,
Thanks for this last bit of advice. I have managed to put a lead together that fits the feedback and will test the connections at the earliest opportunity.
Mancsaint
Guest (4)
This page was generated in 0.539 seconds.
