Offline weissbahn
#1 Posted : 05 September 2013 18:05:11(UTC)
weissbahn
According to the 3748/3448 booklet, this loco can be run on conventional analogue system as well as digital. The problem is there is no clue in the booklet how to set the loco digital control switch for conventional running. I have tried it with a 6629 controller, having set the panto/track button to track, but no go, not even the lights come on. Have I missed something fundamental here. There are 80 different addresses, but address 70 is highlighted for some reason. I have tried this ,but still doesn't work. Any advice please?
#2 Posted : 05 September 2013 18:35:47(UTC)
Have you try all eight dip swtch to off on decoder for controller analog layout?
But I am not sure, Some members can help you.
Offline eroncelli
#3 Posted : 05 September 2013 18:43:08(UTC)
eroncelli
Yes, all dip-switches set to 0
Here a useful file to select the addresses:
File Attachment(s):
DecoderAdressen.xls (122kb) downloaded 23 time(s).
thanks 1 user liked this useful post by eroncelli
#4 Posted : 05 September 2013 19:00:50(UTC)
The loco should have a 6090 decoder. With most locos, the 6090 has automatic system detection, so loco should automatically work in analogue mode no matter which digital address was set.
Some 6090 require all DIP switches to be off for analogue operation.
IIRC lights will be off while running in analogue mode.
Does it run in digital mode? Maybe there is a general problem (hardened oil, locked gear).
#5 Posted : 09 September 2013 21:29:32(UTC)
Any news on 3748, weissbahn?
This page was generated in 0.413 seconds.
