Offline Z-nerd
#1 Posted : 29 August 2013 08:48:30(UTC)
Z-nerd
I did a test yesterday. I cleaned the tracks and the loco Märklin 8800.
Started the loco and let it run at ca 75% speed with 2 waggons on a T2 SET outer oval (see photo.)
The loco ran for 9 minutes and 27 seconds before it stopped
It took that time to collect enough dirt on the wheels to stop (in a turnout)
For how long is it possible to run a 3 axle loco before it stops due to dirty wheels/tracks ?
thanks 1 user liked this useful post by Z-nerd
#2 Posted : 29 August 2013 09:36:59(UTC)
Originally Posted by: Z-nerd Go to Quoted Post
For how long is it possible to run a 3 axle loco before it stops due to dirty wheels/tracks?
Where does the dirt come from? Eliminate the dirt and the problem is solved.
Use a clean room (filtered air) to set a new world record.
Dirt on the wheels can come from the rails or from the air or from the loco (or was already on the wheels). Or it could come from electric sparks.
#3 Posted : 29 August 2013 09:41:06(UTC)
I have no experience of Z gauge, but my HO locos will run until they need oiling. The longer they run the cleaner the tracks and wheels seem to get. Of course Z gauge is 2 rail DC and much smaller, so different mechanical factors apply.
Have you made just one test? I would carry out the test at least 5 times and get an average duration of run to have any scientific meaning to the results. You might find that your one test is much shorter or longer than the average.
Offline Z-nerd
#4 Posted : 29 August 2013 13:05:41(UTC)
Z-nerd
I did a second test on my Blumenau layout. Same loco & 1 waggon.
Loco and tracks cleaned before start.
P8296904 by Joner1769, on Flickr
P8296906 by Joner1769, on Flickr
Result: The 8800 loco ran for 62 minutes before it stopped. After 45 minutes it slowed down remarkably, then it continued to slow down until it stopped.
When I picked up the loco it was very hot, so I think it stopped because of unsufficient lubrication, not because of dirty wheels. I will do another test after cleaning and oiling the loco agian.
thanks 2 users liked this useful post by Z-nerd
xxupH0
#5 Posted : 29 August 2013 13:58:23(UTC)
Oil on the collector can lead to slow running while the motor gets very hot.
A drop of oil at the right place can solve running problems - at the wrong place it will cause problems.
Too much oil is a problem - it will always end up at places where it does harm.
Offline Wal
#6 Posted : 29 August 2013 14:13:39(UTC)
Wal
First ever post...but I value the comments on this forum. I run Marklin Z locos digitally using Velmo decoders and a trix mobile station. I run for hours at a time without any major issues. Trains run at prototypically slower, smoother speeds rather than flat out using analogue control. Best thing I ever did was to update to digital. And I agree with the comments re oil.
thanks 2 users liked this useful post by Wal
Offline 79sunrunner
#7 Posted : 01 September 2013 05:47:39(UTC)
79sunrunner
If these little engines are getting hot after a short while of running, then how did maerklin do thier famous world record z scale run back in 1978? The engine run non stop for almost 1000km if I remember correctly. Maybe Maerklin knows something that we dont Flapper
#8 Posted : 01 September 2013 09:28:50(UTC)
Maybe they know how to grease the loco - no oil were it shouldn't be.
"In 1978, a Märklin Z scale locomotive pulling six coaches made its entry into the Guinness Book of World Records by running nonstop 1,219 hours, and travelling a distance of 720 km before the train stopped due to failure of the motor."
Source: http://en.wikipedia.org/wiki/Z_scale#History
#9 Posted : 01 September 2013 11:15:55(UTC)
I have the same problem with running stop after 5-6 minutes so I cleaning wheels and tracks before running stop again few minutes later.
I return the Z starter set 81564 for refund and I am happy stick with HO scale.
Offline Z-nerd
#10 Posted : 01 September 2013 11:51:06(UTC)
Z-nerd
I have my doubts about this publicity stunt. If they recommend lubrication and "service" after 20 hours, how could this loco run for that long ?
P9016910 by Joner1769, on Flickr
I avoid all kinds of oils now. I have realized that Moly grease is better. Oil tends to get stuck to the cogwheels and it splashes on the tracks so they get dirty.
P9016912 by Joner1769, on Flickr
#11 Posted : 01 September 2013 12:11:11(UTC)
Lubrication requirements for any given machine are different depending on many different factors, such as temperature, operating speed, durability, etc.
I have no doubt that, for the record attempt, Marklin engineers worked out the best type of lubricant for working longer at one fixed speed, and that that lubricant was very likely not the one they recommend to customers for general use.
Other than when I have overdone the oiling (my fault) I usually find that the Marklin oil works OK for my HO models. Sadly I have no experience of Z scale.
#12 Posted : 01 September 2013 13:13:29(UTC)
If they recommend lubrication and "service" after 20 hours, how could this loco run for that long?
How long would it run if you were allowed to make maintenance after 20 hours (or once a day)?
In the past, Märklin offered oil only and therefore they recommended to oil the worm drives. Oil is too thin and won't last long.
In recent manuals they recommend Trix grease for worm drives (at least with H0 models).
Who knows what special greases they used to prepare that world record loco. And who knows how much noise the loco made on the last rounds before the motor died ...
Offline Z-nerd
#13 Posted : 01 September 2013 18:25:35(UTC)
Z-nerd
No, it would be a pity if you returned your z train.
Z-scale trains are more demanding, cleaning of tracks and wheels is of course more important than in H0-scale.
To solve your problem:
Disassemble the loco and put the wheels and cogwheels in some kind of alcohol. I used fluid for windscreenwipers.
Assemble the cleaned parts.
Put a tiny blob of grease on one of the cogwheels, apply with a needle.
Clean the wheels and tracks with spirits.
Offline Dimi194
#14 Posted : 01 June 2021 01:40:09(UTC)
Dimi194
Reviving a dead thread here but I have encountered the same issue with my starter set BR 89 - it runs for a few mins before slowing down and stopping! Who knew it was so fiddly! I have a decent amount of N Scale Thomas stuff from Bachmann and Tomix and they run fine for hours on end before needing cleans :/
Offline wildstix
#15 Posted : 01 June 2021 11:46:46(UTC)
wildstix
Indonesia
I have an old 8800 BR 89, probably from the early 80s and because of that reason, I will not do this experiment 🤨 . But...
I revived my locos this year and my BR 89 is actually a fighter! It needed a push when it's cool, but once warmed up, it just seemingly run faster and faster, making me happy and worry at the same time. The longest I let it run was 20 minutes, without any signs of slowing down, and after that, I can't even touch it because it was so hot!
Oka aka W. Kapriandi
Märklin Z scale (mini-club) purist but not a modeler!
This page was generated in 1.044 seconds.
