Offline Mike M
#1 Posted : 27 August 2013 18:09:26(UTC)
Mike M
Does the wire from the S88 module get connected to the contact track(24995) on the "B" or the "O: terminal??
Do I need both tracks for one contact area? (Instructions show 2 pieces)
Offline Mike M
#2 Posted : 27 August 2013 21:10:44(UTC)
Mike M
Does anybody out there have an answer to this question ???????????????????????
Offline waorb
#3 Posted : 27 August 2013 21:48:59(UTC)
waorb
Brazil
Hey! Come down! Flapper
Sometimes you only receive answers from guys around the world... far-away of your longitude... BigGrin BigGrin
Well, contact tracks need to be connected to the "O" terminal (ground of the track). NEVER on "B"!!! "B" is from Bahn in german, or the positive middle rail.
Always should be connected on the outer rails...
http://medienpdb.maerkli.../1/pdf/24995_betrieb.pdf
Walter
ps. the cheapest way to create contacts-tracks is to pickup your existing tracks, cutting the metal above, and insulate the terminals; your rolling stocks do the rest.
Offline Mike M
#4 Posted : 27 August 2013 23:12:39(UTC)
Mike M
Walter
I'ts calm down, But it was not meant to be nasty That's why it was bold italics LOL
Cheers Mike
Offline waorb
#5 Posted : 28 August 2013 04:06:51(UTC)
waorb
Brazil
Cheers Mike
Cool no regrets! LOL
The question is: your question was answered? Smile
Walter
Offline Mike M
#6 Posted : 28 August 2013 06:11:05(UTC)
Mike M
Cheers Mike
Walter
Half of my question was answered. Curious about the link you attached,it is not opening??
#7 Posted : 28 August 2013 08:24:13(UTC)
Mother M* doesn't allow direct links to her PDF files.
Copy URL to the address field of your browser:
Code:
http://medienpdb.maerklin.de/product_files/1/pdf/24995_betrieb.pdf
When using a pair of 24995 you don't have to use the 74030 insulator caps.
When you do it as Walter suggests, you don't need 24995 - instead you need a pair of 74030. No visible marks on the tracks and can be used between any pieces of track.
Offline Mike M
#8 Posted : 28 August 2013 17:23:20(UTC)
Mike M
Code:
You mention using a pair of 24995 does that mean 2 for each siding on my shadow line? plan attached
#9 Posted : 28 August 2013 18:52:37(UTC)
The 24995 is a 24094 with a cut in one rail:
http://www.lokshow.com/s...terial/bilder/24995b.jpg
For a contact track, you need two cuts in the rail (start and end).
With normal tracks and 74030, you have more flexibility (any lengths can be used) and it gets cheaper.
For two adjacent contact tracks, three pieces of 24995 can be used - or four for three adjacent contact tracks.
This page was generated in 0.313 seconds.
