Offline LeoArietis
#1 Posted : 25 February 2008 19:57:45(UTC)
LeoArietis
I have bought a class 482 Swiss cargo loc, its from a starting kit. Decoder in the picture.
I would like to have a red light (LED) at the rear end. Sugestions?
At 1 there is ground.
3 and 5 holds 4.75 Volts to ground.
L1 and L2 are the connections to the head-lamps at each end. Only on and off possible, no red-light at reverse end. The 3 LEDs are in series at each end, and they are SMD on a small circuit-foil. Unfortunatetly the L1 and L2 just have 2 connections, not 4, since they are shorted together by the circuit-foil and also soldered together.
4 can be controlled by setting the decoder as another locomotive and then 4 is the accessory light controlled from MS. It gives out 4.75 V, but how much mA (current)?
What are the 6-8 and 2? 2 seems to have something to do with changing direction or not changing direction.
Current layout:
The former project:
Offline LeoArietis
#2 Posted : 25 February 2008 20:09:49(UTC)
LeoArietis
Also, I would like a tip on what catalog number to use to register the loc in the MS, with the added functions, are there a few "generic" numbers to use for the Mobile Station?
Current layout:
The former project:
Offline LeoArietis
#3 Posted : 25 February 2008 23:40:11(UTC)
LeoArietis
Thanks, I have done some more testing with the articl number 37780 corresponding to ICE406.
The MS will show the symbol of extra interior light 1 at button 1, and when activating that button, I get +4,75V on the number 4-pad towards ground at pad 1.
When activating the F-function on button 5 I get 18 Volts between pad 6 and 8 so I guess I am activating some function here as well?
Is there a locomotive in the database that has the following buttons activated?
* Button 1 for interior light
* Button 4 for disabling the slow acc/dec
*button 5 for F-function
Or some other sugestion that might work?
The problem with using the f0 is that it's has a resistor before beeing grouded via the Transistor. The two transistors can be seen at
Left of L2 and left of L1 respectivly, they are marked + VS and two dots under the V.
The two resistors R1 and R2 are 5.6kOhm and they are just above and below L2/L1, seems they are marked 56Z or 562, you can see the one just above L2 but its up side down regarding with the text.
Current layout:
The former project:
Offline mmervine
#4 Posted : 26 February 2008 00:40:06(UTC)
mmervine
Interesting discussion....I am hoping that some of the electronics wizards out there will help solve all of the mysteries of these decoders!
r/mark
Offline LeoArietis
#5 Posted : 26 February 2008 02:32:59(UTC)
LeoArietis
I found some more info at
http://www.x-train.de/
Go to the submenue
Lokomotiven-Umbauten / Elektro-Lok / BR 185 / BR 185-CL 009
There is a description of the decoder and some futher tips.
If anyone can find out how to get that nifty little "Beleuchtungsmodul BR185/46-RF" please tell me. My german isn't good enough.
Current layout:
The former project:
Offline frankie
#6 Posted : 26 February 2008 18:45:24(UTC)
frankie
I haven't understood if they sell the PCBs or you have to made them yourself.
Alessandro
I have a CS1 Reloaded!
Offline mmervine
#7 Posted : 27 February 2008 00:55:50(UTC)
mmervine
The photo of the ICE decoder reveals the secret of sound for the hobby loks. Although Marklin has never offered these with sound, the frame is milled for a speaker. The three connections (6,7,& 8) must of been where they planned to attach the sound effects board as on the ICE.
Interesting...
r/mark
Offline frankie
#8 Posted : 27 February 2008 11:49:09(UTC)
frankie
BTW also Hobby series, 3685X, have a speaker fitting complete with everything and there are available PCB with NEM plug...
Alessandro
Offline mmervine
#9 Posted : 28 February 2008 03:02:55(UTC)
mmervine
I looked at the x-train webite and it looks pretty interesting. Can one of our German speaking members tell us if Mr. Bobzin actually sells these circuit boards?
r/mark
Offline frankie
#10 Posted : 28 February 2008 10:31:39(UTC)
frankie
I wrote him, let you know.wink
Alessandro
Offline frankie
#11 Posted : 28 February 2008 11:01:36(UTC)
frankie
BTW the more I am in this hobby, the more I think a German language course would have a big ROIbiggrin
Alessandro
Offline Caplin
#12 Posted : 28 February 2008 12:48:59(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
<br /> ROIbiggrin
confused (for the dictionary)
Benny - Outsider and MFDWPL
Offline frankie
#13 Posted : 28 February 2008 13:16:24(UTC)
frankie
Return Of Investementbiggrin
Alessandro
Offline mmervine
#14 Posted : 14 March 2008 02:35:55(UTC)
mmervine
Any news from Mr. Bobzin ?
r/mark
This page was generated in 0.681 seconds.
