Offline Mike M
#1 Posted : 07 August 2013 21:14:12(UTC)
Mike M
Hi, I wondered if anyone can give me advice on where and what to purchase an accessories transformer (ie. lighting ,crossing etc.) I have a CS2 and a booster but think I need a seperate power supply for all of the accessories. Need 110 volt and at least 16VA. Doesnt look like Marklin has anything like that. Viessmann has but it is 230 volt.
Cheers Mike Any advice would be greatly appreciated
#2 Posted : 07 August 2013 21:23:58(UTC)
Hi Mike, what you need is a 60065 50VA 120V switched mode power pack. It is availble at the moment and costs about 80 Euro
https://www.maerklinshop...dd07294&anid=M060065
#3 Posted : 07 August 2013 21:44:32(UTC)
Hi, Mike, the transformer 6646 was discontinued, but maybe you can get one of those (120 V, 16 V AC, 32 VA).
The new power packs have DC outputs and some accessories may not work with DC (Märklin provide a converter that can be used to get AC from a DC power pack for those accessories).
Offline Mike M
#4 Posted : 07 August 2013 21:46:23(UTC)
Mike M
Hi Ray , I have that Transformer what I wanted is a stand alone transformer that I can hook up to distribution channels and power accessories. this one hooks up via the CS2.
Excuse the dumb Questions but I am still fairly new at this.
Offline BrandonVA
#5 Posted : 07 August 2013 21:54:06(UTC)
BrandonVA
Tom,
Does this mean Marklin no longer sell any means for analog control of locomotives?
-Brandon
Offline petestra
#6 Posted : 07 August 2013 22:41:54(UTC)
If discontinued, Märklin will come out with something better, I'm sure. They cannot disappoint
all of the analog users and 1 guage operators as well. I still have all my old blue transformers
but I stopped using most of them because I did not want to take the chance of damaging one
of my newer Loks. As I have discussed with Brandonva I've been having trouble with white
transformers I bought 1 1/2 years ago. They now only start moving the Lok after the control
knob is at the 1/2 power level. This is not good at all or acceptable to me. Märklin in Goeppingen
emailed me back and told me to send all three trafos to them but I am waiting a bit pending other
repair options. Peter
#7 Posted : 07 August 2013 22:55:31(UTC)
Hi Mike,
You can use one of these transformers with this adaptor cable 60200 to power your accessories. You get a yellow and brown wire which is what you need for most accessories.
https://www.maerklinshop...;anid=M060200&pgNr=1
As Tom mentioned, some accessories might not work with the DC that this power pack produces, but you can connect those via the 60130 invertor which gives both DC and AC outputs:
https://www.maerklinshop...;anid=M060130&pgNr=1
#8 Posted : 07 August 2013 22:59:32(UTC)
Tom,
-Brandon
The 66470 is the transformer for analogue control, though it is only currently available for 230V as far as I can see:
https://www.maerklinshop...;anid=M066470&pgNr=2
#9 Posted : 07 August 2013 23:12:35(UTC)
Currently they offer nothing for 120 V mains voltages. There is a new 66470 for 230 V mains voltage (as Ray mentioned).
I don't know if there will be a new 66460 for 120 V in the future.
I still don't know what the difference between the 6647 and 66470 is - maybe they added TRIACs to prevent back-transformation.
Should be no technical problem to do the same changes for the 6646=>66460. Maybe they shy away from FCC approvals (like they do with their locos recently).
I naïvely think that the more e-mails they receive asking for a 66460, the more likely it is that they will actually introduce a 66460 someday. RollEyes
In the worst case, buy step-up transformers 120 V => 230 V and use the 66470 ...
... and be a good boy and get an FCC approval for it! LOL
#10 Posted : 08 August 2013 03:36:42(UTC)
.........but you can connect those via the 60130 invertor which gives both DC and AC outputs:
But not at the same time - the instructions state that you can use either the DC or AC output, but not both - output is 19.5v for both AC and DC. I have 2 of these and they work quite well and I'm using them with a 19.5v DC Sony Laptop power supply.
Offline 3rail4life
#11 Posted : 08 August 2013 05:37:18(UTC)
3rail4life
Hi Mike,
With our CS2/MS2 layout we use an analog 6627, 30VA to supply ac power to the lighting on a separate circuit. Since none of the power is going to the track to power the trains, we do not have to worry about it being an older blue model. I like using the track output (B) for the incandescent lights and the light output (L) for the LED's. This allows for the speed control to be used as a rheostat to dim the lights. There are several different models made for N. America that would suit your needs without having to buy a separate dc to ac converter for your crossing or other accessory requiring ac. There seems to no shortage of nice used ones being sold on US ebay these days. There is even a German seller offering 6646 models if you wanted new. If DC is all you need maybe one of the wall warts (small switched mode power supplies) with the adapter cable would be fine as well, the euro models can be had for next to nothing and work with 110, or for a bit more money there is a model for N. America too, which of course you could also use with the converter to get ac.
Gordon
thanks 2 users liked this useful post by 3rail4life
Offline kweekalot
#12 Posted : 08 August 2013 09:22:59(UTC)
kweekalot
Faller has a transformer (item 180641) for heavy use like accessories, lighting....
See here: LINK
Marco
#13 Posted : 08 August 2013 09:28:14(UTC)
Yes, but input is 230 V at 50 Hz, not 120 V at 60 Hz.
Offline Hoffmann
#14 Posted : 08 August 2013 14:32:41(UTC)
Hoffmann
Hello Mike,
Just E-mail me I have a 6646 in Stock ( new from Start-sets ).
Martin
marklin-eh
thanks 1 user liked this useful post by Hoffmann
Offline BrandonVA
#15 Posted : 08 August 2013 15:10:11(UTC)
BrandonVA
Tom, Peter,
Thank you for the answer. I hope this does not derail the thread too much. I will certainly write Marklin about it. With 66470 existing, I think the FCC thing is a pretty valid guess for why there is no 66460 (hopefully yet). I do agree with Peter, the quality of these is not that good, the wire that goes to the control knob frays and then they are useless for driving trains (still fine for accessories). I have one in this condition that I will attempt to repair shortly. At least compared to my 6627s, which work fine to this day.
The majority of MMR users these days are digital, I just hope they don't phase out analog control completely...I would still like to have transformers available, and digital decoders that support driving in analog mode.
-Brandon
#16 Posted : 08 August 2013 17:45:20(UTC)
Although many new Marklin modellers go straight into digital there are a large number of existing modellers who still like to run their trains in analogue mode for nostalgic and other reasons.
There are still a lot of older Marklin locomotives out there which have not been converted, and many which their owners would prefer to leave in original condition. These locos need analogue transformers to run them, especially as the older blue transformers get more and more worn out and start getting dangerous to operate.
In the DC world there are still many more analogue modellers than digital, and the support for them is still strong from the industry. I don't believe the AC world should be any different.
Offline 3rail4life
#17 Posted : 08 August 2013 18:10:37(UTC)
3rail4life
Well said RayThumpUp and spot on. I knew there was a good reasons to never let any of my analog trafos go. This business of Märklin not making a new North American model stinks. For now there seems to plenty left, but they won't last forever, as Tom suggested, it might not hurt to write.
Gordon
Offline Mark5
#18 Posted : 23 August 2013 03:15:00(UTC)
Mark5
In light of the value of the good number of analog trafos I plan to keep, I would like to know if Gordon or anyone also run their incandescent blubs from M-track turnouts and or older signals from an alternative trafo? And if so, how does one do the wiring, since the ground is hardwired to the track. It would look far better, in my view, if one could also dim these bright lights. One more argument in my view of continued production of analog trafos, including the notion that old collections passed on will, at times, produce new and younger enthusiasts for the brand.
- Mark
Originally Posted by: 3rail4life Go to Quoted Post
Hi Mike,
Gordon
Offline 3rail4life
#19 Posted : 23 August 2013 07:33:25(UTC)
3rail4life
Hi Mark,
We have converted to digital and and C Track, and use an analog transformer for our lighting. I kept the grounds separate since the C track lanterns have the two leads, most all Märklin systems are able to use a common ground, so using m track should not be a problem. The only problem I see is with dimming m track signals and turnouts is they need a certain amount of power to switch the solenoid which uses the same power circuit as the lamps. So you could not dim them to much unless you separate the lamp power from the solenoid which would require an additional wire to the device. When using multiple transformers on the same circuit you have to make sure they are in phase and that the B and L circuits on each transformer are kept separate from the other transformers and each other, the 0 grounds can be combined in a common circuit for the track and accessories. By using the B terminal to power a lighting circuit, you are able to use the throttle as a rheostat to dim or brighten the lights.
I hope that all made sense, and that production of analog transformers will continue. As much I like the new digital era with switched mode power supplies and fancy controllers, there will always be times for m track carpet bahns and running classic Märklin loks with analog transformers.
Gordon
#20 Posted : 23 August 2013 09:01:05(UTC)
Phase matters only when you have locos passing between different circuits (thus connecting two Bs during the transition). Phase does not matter when only the ground (0) is ever connected.
When accidentally connecting two Ls that are not in phase, you will get a big spark. If they are in phase, nothing will happen - but if you disconnect one transformer you will have full voltage in its main plug!
So with only two transformers, having them out of phase helps to make sure you don't have accidental connections between them.
Offline DumbGuy
#21 Posted : 01 October 2013 11:10:25(UTC)
DumbGuy
RE: "We have converted to digital and C Track, and use an analog transformer for our lighting." -- Originally Posted by 3rail4life
Hello Gordon,
This November, I’ll begin setting up a new digital C-Track / CS2-controlled layout. My approach to provide separate power for rail & accessories will be similar to yours: (1) a #60055 60 VA transformer for rail power; (2) either a newer digital #6001 42 VA or an old analog #6153 30 VA blue-box transformer for accessories using their L outputs; and (3) a common ground for both rail and accessory power thru the track. That approach works well on a small test loop, but . . . . .
I have a question about phasing & polarity. My main #60055 transformer has a large blade & a small blade on its wall plug, while both blades on the accessory transformers are the same (small) size. I had previously run an analog layout with separate circuits & multiple transformers where phasing & polarity mattered (per Tom’s post above); i.e, proper blade orientation of transformer plugs into their respective wall sockets was important to assure that all power outputs were in-phase and with the same polarity.
On my test track, phasing & polarity (orientation of the accessory transformer’s wall plug) does not appear to be an issue. From your experience, is it something I should be concerned about? Do you have any other related advice; e.g., on using a common ground, etc.?
I may be overly cautious, but I’d hate to fry something expensive because of a simple phasing or grounding mistake.
Thanks & best regards -- Richard
Long-time analog user, collector & tinkerer.
Discovered digital & began conversion a few years ago.
C-Track, CS2 Carpetbahn built, taken-down, rebuilt, etc.
Username reflects how much I still have to learn.
thanks 1 user liked this useful post by DumbGuy
Offline Western Pacific
#22 Posted : 01 October 2013 17:03:21(UTC)
Western Pacific
Regarding the phase difference. That is only an issue if you feed tracks from different trafos and the layout is designed for trains passing from a track connected to one trafo and then to a track connected to another trafo. The fellowing can be found in an instruction booklet for Märklin trafos:
"Checking the Polarity
When two or more train control transformers for different
track circuits are used on a layout, it may happen that
different polarities for the transformers may cause a strong
spark on the pickup shoe of a locomotive passing over the
separation point between two track circuits. In this instance
the plug on the power cord for one of the transformers must
be removed from its outlet, turned 180° and plugged back
into the outlet."
Another way than detecting sparks is to connect for instance a lamp of the type used for light in buildings between the yellow contacts of different trafos. The trafos are in phase if the bulb remains dark. They are out of phase if it lights up, in this case turn the plug of one of the trafos 180 degrees.
Offline BrandonVA
#23 Posted : 01 October 2013 17:47:29(UTC)
BrandonVA
Attached for reference are the Marklin instructions for doing this procedure with analog transformers.
-Brandon
Offline DumbGuy
#24 Posted : 01 October 2013 18:58:37(UTC)
DumbGuy
RE: Polarity & Phase Difference for Transformers
Thanks for your clear explanations & illustrations on phase difference & polarity-checking for an analog system. It was an important task, and pretty much what I’d done when I used multiple trafos to provide running power on an analog layout.
My concern voiced in Post #21 was if I needed pay similar attention to phase difference & polarity for a digital layout where all running power will be provided by ONE trafo, with a second trafo used only for accessory power (uncouplers & semaphores, crossing gates, etc.) – both transformers using a common ground.
From your comments, my concern appears to be a non-issue, and a polarity check is unnecessary. Am I correct?
Regards -- Richard
#25 Posted : 01 October 2013 19:41:29(UTC)
Western Pacific
Regards -- Richard
Yes you are correct.
Offline 3rail4life
#26 Posted : 02 October 2013 07:31:28(UTC)
3rail4life
Hi Richard,
It looks like WP and Brandon covered the polarity topic pretty well, I was thinking of how it was back in the day on my analog layout when I mentioned it. As Tom and WP said, it should not matter with a common ground.
I was thinking for your CS2 you may want to consider using a 60065 switched mode power supply to power your layout unless you already have the 60055. If buying new, the 60065 is a better deal.
Using the 30 VA transformer on our lay out for lighting works out really good, I like being able to dim the incandescent bulbs when using them with the B terminal and having the turnout LED's on the L side. So far we are doing OK with just the one transformer for lights, we will have to add another as the town grows.
Have fun with your new project.
Gordon
Offline DumbGuy
#27 Posted : 02 October 2013 12:01:13(UTC)
DumbGuy
Gordon,
Yes, questions answered. My CS2 came with a 60055 at a very nice combined price. With a second transformer for accessories, power should be fine. I may do something more later, but that will wait until this DumbGuy has a bit more digital experience.
FWIW -- For nostalgic value, I’ve attached a shot of my totally in-phase M-Tracked Christmas Carpetbahn “Control Center” from several years ago. A fifth blue-box (not shown) was used for lights & accessory power. I’ve kept two of them – the others, along with most of my M-Track, found new homes through eBay. Ahhh . . . . . the charming fun of heavy metal, wires, buttons and knobs!
Thanks & regards -- Richard
Edited by user 02 October 2013 22:54:00(UTC)  | Reason: A couple of typos
DumbGuy attached the following image(s):
Offline BrandonVA
#28 Posted : 02 October 2013 14:36:26(UTC)
BrandonVA
Nothing I like more than a big block of analog transformers :)
Totally OT, but I've never seen a yellow control box like that before. Is it repainted? Is it a different brand? Or Marklin?
-Brandon
Offline DumbGuy
#29 Posted : 02 October 2013 22:45:59(UTC)
DumbGuy
Gordon -- The yellow panel is marked “Marklin 7072” and is functionally the same as the standard blue ones. Not repainted & OEM, so it was perhaps made to highlight & use with especially important switches. I also have never seen another like it.
I have a bunch of 7072s, 7010s & 7011s, etc. Nearly all in excellent, non-sticky condition and they still fetch a decent price on eBay. As done with the old transformers, I’ll probably sell most of them early next year once I’m sure that control via the CS2, k83’s & Viessmann 5231’s satisfies me. But the old yellow panel won’t go away.
A related OT – I’d forgotten I had kept a photo of my old analog trafos & controls until I looked at archived files a few days ago. I like the memories and may even change my Forum Avatar to show it. But I also like my current Cat-Monster . . . . . . decisions, decisions.
Regards -- Richard
Offline 3rail4life
#30 Posted : 02 October 2013 23:06:24(UTC)
3rail4life
Very Cool Richard ThumpUp, That must have been quite the carpet bahn, there will always be great memories of my childhood associated with those heavy blue metal trafos.
The yellow control panel is actually a Primex item # 7156 made by Märklin in the 1970's, no doubt using the same mold as the 7072. Most of my control panels have gone to eBay as well but I will keep a few around for the nostalgia layout I hope to build some day.
Gordon
Offline DumbGuy
#31 Posted : 04 October 2013 04:18:06(UTC)
DumbGuy
So . . . Yellow = Primex. Nice to know & thanks for looking, Gordon. It’s still a keeper. As you have, I’ve also kept enough analog stuff to build a loop with a couple of switches & sidings if the legacy spirit ever moves me.
This thread is getting far too far OT. It’s interesting, but to be fair to others looking for on-topic advice on transformers, I’ll stop posting more here.
Nice to meet you & best regards -- Richard
Guest (4)
This page was generated in 0.787 seconds.
