Offline Iamnotthecrazyone
#1 Posted : 25 July 2013 15:21:04(UTC)
Iamnotthecrazyone
Since this week I've got to look and play with my trains I have another question for the people who do it more regularly.
I have bought recently a couple of trains where the owner was overly enthusiastic about oiling and sometimes spraying wd40. Is there anyway to get rid of it without having to dismantle the whole thing apart? What about those ultrasound cleaners are they suitable for this?
thanks!
Alex
Offline Davy
#2 Posted : 25 July 2013 17:12:50(UTC)
Davy
No and ultra sound destroys more then its benefit.
M-track with a CS2.
#3 Posted : 25 July 2013 17:53:55(UTC)
Hi Alex,
I use a spray wash intended for eletronic equipment. You can get it from any electronics shop. Just spray liberally in all the nooks and crannies and the old oil washes off.
For the maximum benefit, though, I prefer to open up the motor and give the commutator and brush plate a good clean.
#4 Posted : 25 July 2013 17:55:30(UTC)
By the way, WD40 doesn't do as much harm as the recommended oil, as it tends to evaporate away and only leaves a very light residue. The thicker oil gets mixed up with the sooty deposits from the carbon brushes making a paste that gums everything up. If the loco is very badly jammed I might give it a good spray with WD40 first, and then wash that off with sparay cleaner.
Offline Yumgui
#5 Posted : 25 July 2013 20:05:16(UTC)
Yumgui
Alex,
My two cents: No quick fixes (lol @ spray the loco with some magic fluid and poof, it works ... nah) ... take 'em apart (WD40 is good only for loosening rusty parts), brush all parts down with lighter fluid, then reassemble, spray with electronic cleaner on electrical connections only and oil carefully with Labelle 108 only where needed ...
... at least you can sleep at night knowing exactly what's up with each machine !
Yum Cool
thanks 2 users liked this useful post by Yumgui
Offline Danlake
#6 Posted : 25 July 2013 20:58:36(UTC)
Danlake
Just a worth of cautions - I have managed to destroy 2 sets of gears on locomotives by using plastic safe electrical contact cleaner.
It's extremely efficient to clean the gear and motor block, but it makes everything bone dry and the quick evaporation makes all the gear briefly very cold. I suspect this does some damage, because despite some oiling or grease I cannot get the gears to run without a terrible squeaking noiseCrying
Brgds - Lasse
thanks 3 users liked this useful post by Danlake
#7 Posted : 25 July 2013 22:47:57(UTC)
Well... When I have had such issues, I have dismantled the loco & motor and washed the non electrical parts with plain dishwasher liquid or "Ajax" with a proper rinse with lukewarm water afterwards... Of course proper drying with eg a hair-dryer or empty airbrush power afterwards is mandatory.
Once tried to soak a chassis in alcohol, but that dissolved the red paint on the steam loco chassis & wheels so they got pink instead... Scared
#8 Posted : 26 July 2013 03:52:37(UTC)
Iamnotthecrazyone
I don't mind taking apart the brush plate and cleaning around there but when is all around the gears it seems like a nightmare to clean, I can never get it off. I can't think of the idea of dismantling everything.
The WD40 does evaporate but always seem to leave something behind so still worries me. It also worries me when there are plastic gears around or old plastic traction tyres. I wonder whether the wd40 may cause damage to the plastic. I also thought in dipping them in petrol (without electrics and leaving them there for a couple of minutes, I am not sure whether that will leave residues as well. My main problem is around wheels and gears. The labelle spray I never heard of it might not be available in Australia but i'll have a look later. I have a couple of electronics contact cleaners but did not help much.
#9 Posted : 26 July 2013 05:20:35(UTC)
Be careful with the plastic parts of the loco when you use WD-40.I damage the plastic light bodyof the loco.It becames misty and not working,so i have to find another one to solve the problem.
#10 Posted : 26 July 2013 08:07:31(UTC)
In my experience WD40 is quite benign compared to many solvents which are much more aggressive against plastics and paint. Of course, you must remove the plastic body and only spray the metal chassis to minimise collateral damage. The nylon gears used on locos should not be affected by WD40.
Alex, you haven't mentioned which locos you have the problem with. Perhaps if you are more specific we can help you better.
#11 Posted : 26 July 2013 12:40:05(UTC)
Iamnotthecrazyone
Ha!!! It is not so easy because there are several with that problem. It was more a general question for when I have the right state of mind to do it. However I can tell you of two I have right now on my table with the problem a 3014 and a 3047 last one is not so bad but has lots of wd40 that makes it shinny and sticky an every time I touch it I seem to spread it over the body. I'll be happy to clean them now if there is a quick way. I would really like some spray degreaser -like mentioned in prior posts- as long as it doesn't have any secondary effects.
But if there is no easy way they'll have to wait a few weeks. I am concentrating now in fixing/restoring a very early crocodile and I don't want to end up opening a lot of locos during this week otherwise none will be done. If interested I have a thread going on about that crocodile in the collectors corner
Offline biedmatt
#12 Posted : 26 July 2013 13:33:34(UTC)
biedmatt
I usually dip them in paint thinner for a few seconds and then blow them off with compressed air.
Matt
Era 3
#13 Posted : 26 July 2013 14:05:52(UTC)
Iamnotthecrazyone
I think I might try that on a model without plastic bits and see. Thanks
Offline biedmatt
#14 Posted : 26 July 2013 14:26:00(UTC)
biedmatt
Nylon gears should be okay for a short dunk. Paint doesn't affect them so the thinner is good for a short time. I do not let them soak though unless there isn't any plastic.
Matt
Era 3
#15 Posted : 26 July 2013 14:41:38(UTC)
Iamnotthecrazyone
Yes that's one of my worries because some of the ones I need to clean have the old style plastic tyres on the wheels. I am not too keen on exposing the nylon gears either but I imagine is not big deal. The plastic tyres are specially important because I can't replace them that I know.
Offline Chook
#16 Posted : 27 July 2013 06:11:16(UTC)
Chook
I personally would not use paint acrylic thinners on my models.
I think that is using a "sledgehammer to crack a nut".
Methylated spirits and a paint brush would be my limit. The metho won't upset any coil windings or electronics either.
Regards........Chook.
thanks 1 user liked this useful post by Chook
#17 Posted : 28 July 2013 00:58:38(UTC)
I also use this methode, including an old toothbtush. It Works Perfect, after adding very small amounts of oil to the gears and Axels.
I use the Märklin oil (Do not remember the article number).
#18 Posted : 28 July 2013 01:19:01(UTC)
Iamnotthecrazyone
Chook, I don't think anyone had plans for cleaning any of the electrical or electronics with paint thinner.
#19 Posted : 28 July 2013 03:16:03(UTC)
What is the issue with Ultra-Sonic cleaning? I have a small personal unit for about 10 years and have used it for cleaning many items including Faller Slotcar chassis, and Marklin motor parts - never had any problem.
Have you had a different experience?
Steve
#20 Posted : 28 July 2013 08:42:46(UTC)
It can turn small paint damages into big paint damages.
It seems that most locos won't get damaged.
Offline Chook
#21 Posted : 28 July 2013 13:44:52(UTC)
Chook
When cleaning things with tooth brushes it is usual for the liquid to flick everywhere no matter how careful I am. Metho is just safer in this regard.
REgards......Chook.
Offline kbvrod
#22 Posted : 28 July 2013 17:06:48(UTC)
kbvrod
Isopropyl alcohol
thanks 1 user liked this useful post by kbvrod
Offline Janne75
#23 Posted : 28 July 2013 19:51:19(UTC)
Janne75
Views messages in topic : 2,556
Hi Alex, all,
I have bought some of my second hand locos from Finland. One seller was over oiling his locos with WD40 or at least it smelt like it. Locos rubber traction tyres get very loose from oil and I had to replace all of them... Cursing
Best way is to take motor off and clean everything. I don't ever use anything else than paper and cotton sticks (normally used to cleaning ears etc.). When motor is off it is quite easy to wipe excessive oil (WD40) off from the sides of gears etc. There is not so many parts in these locos. I never take any pressed axles or gears off from my locos and have used this "method" succesfully.
PS. It is interesting to read your Crocodile project. You are making good casting parts.
Janne
#24 Posted : 29 July 2013 15:42:49(UTC)
Iamnotthecrazyone
Hi Alex, all,
Janne
I am not surprised the WD is affecting the rubber, I use the cotton sticks too. In this particular case they are not enough. Luckily the 3047 since it's been sitting for a few days on my table while I admire it seems to be drying out and there is very little wd40 left although still looks glossier in the areas that was sprayed on.
Yes, there is plenty going on in the background with those parts for the crocodile. I 've been doing several things, made some mistakes but I am learning a lot. I'll be buying some machinery very soon to be able to do a more accurate job. By the time I finish I don't know whether the part would be any good but it would have cost me what one of those crocs in excellent condition would costLOL but I am hopping all my new skills and equipment will allow me to do other projects in future. Thank you for the comment.
Tom, the paint damage is a very good point which I did not consider but I suppose it will only affect the locos that already show bad signs of paint flicking off.
Thank you everyone for your input and if you have any other ideas keep them coming, everything is useful!
thanks 1 user liked this useful post by Iamnotthecrazyone
Offline abisel
#25 Posted : 30 July 2013 15:02:36(UTC)
abisel
I am surprised no one has mentioned the use of automotive brake clean spray. It works great to blast away years of grime and leaves behind nothing. Just spray the area and follow up with blasts of air from your compressor until dry. Spin the gears/wheels and repeat as necessary. It will not attack paint, plastic, or rubber. I have not had any issues using the brake clean on my 3048. Once the gears/axles are cleaned, apply only two or three drops of the proper oil, run the engine for a few minutes and reapply another drop or two to the gears/axles. Then wipe up all excess.
WD40 was originally designed as a Water Displacement lubricant for use on missiles to combat corrosion. Although it has many uses such as a penetrating oil for rusty parts, it will attack all petroleum based products such as plastic, rubber and wiring insulation. Once the propellant dries, it leaves behind an oil film. Don't use it.
thanks 2 users liked this useful post by abisel
Offline BrandonVA
#26 Posted : 30 July 2013 15:11:35(UTC)
BrandonVA
I agree brakeclean will work, just keep in mind to use it in a well ventilated area - it is potent stuff. :)
-Brandon
Offline Mark5
#27 Posted : 31 July 2013 20:31:53(UTC)
Mark5
Here is a tip from a painter...
Forget about using an old toothbrush flicking around solvent.... Confused
Most art supply stores will have hog's hair brushes Love from China for a couple of bucks... rather cheap.
Hog's hair is a very strong bristle and will clean with thinner or iso or whatever other "poison" you feel is best, but the point is brushes of various sizes can be cut down and made to fit any corner or cranny. Keep in mind it must be hog's hair... because, other acrylic or plastic brushes will just dissolve slowly with aggressive solvents. Its a very stiff bristle, and not the soft brushes you might know from your model/hobby shop.
Note that Hog's hair will not leave hair or lint behind like cotton from Q-tips. Mind you, a lint-free rag may be need to wipe solvent/oil/grime.
I might add, (off-topic) hog's hair brushes are great for weathering brick and roofs on your Faller/Vollmer/Heljan models... especially if your painting the mortar in between the bricks. Acrylic paints work great for this, as they can be easily wiped or dabbed off the surface, leaving the paint behind in the grooves. I use brunt umber, I feel black is too strong and overbearing. Will have to post some of our beauties one day!
BTW ... great thread!! I have to clean several locos!! Mellow
- Mark
REgards......Chook.
thanks 5 users liked this useful post by Mark5
Offline kbvrod
#28 Posted : 31 July 2013 22:03:27(UTC)
kbvrod
White vinegar.
#29 Posted : 03 August 2013 22:50:42(UTC)
Iamnotthecrazyone
A little update on this is due. Yesterday I just couldn't take the greasy smelly locos anymore. I've took two for sacrifice in the name of knowledge. One a 3048 which wasn't perfect but not too bad and should have probably been spared. The other one a 3005 in terrible condition and much more up to the task.
First one was the 3048 immersed in a methylated spirits bath, other than the brush holder, lamp and a couple of cables all electrics were removed.
After a couple of minutes it was lightly brushed and dried out. My results: it was cleaned but still some of the oil and possibly wd40 linger in some crevices.
There was a light white staining residue left on the black areas of the chassis which later on was cleaned by using some car polish and that ended up looking quite neat. The main problem was that it did affect the red paint of the wheels and the rods. It made it go a bit lighter in colour in some place it started to come off.
Since I wasn't convinced about that the 3005 was bathed in turpentine instead in this one the wheels were removed as well, the rest was the same as the 3048. Results: the turpentine turned dark almost immediately and the loco was cleaned by far more effectively. It has also softened the red paint of the wheels and the rods. However it didn't cause as much damage to the red paint as the metho produced on the 3048.
It was interesting to see the effect the turps caused on the toothbrush used for cleaning LOL which made check immediately the brush cover, 2 nylon gears and the few cables left. To my surprise none of them were affected but the toothbrush is a very good warning for removing all plastics. This method didn't leave stains behind.
My conclusion: while I am not disappointed because the two engines were not presentable the way they were. I will only repeat this on locos that have serious problems or that I am considering to refurbish quite extensively. No good engines should be put through this. After this I am more keen to try the ultrasound method.
Just a brushing with hog hair or plain plastic wouldn't have done. There was oil in the brushes cavities, in between the contact plate and the sky pick up and everywhere else you can or can't imagine. Below you'll find a couple of photos of the 3048 with the stains and after the car polish you can partially see one of the wheels and some of the damage. If I repeat this I'll go directly for the turpentine because it caused nowhere near as much paint damage and it was a much better cleaner.
Iamnotthecrazyone attached the following image(s):
thanks 4 users liked this useful post by Iamnotthecrazyone
Guest (5)
This page was generated in 1.279 seconds.
