marklin-users.net community
| Forum
Home
Community Forum
Login
Forum
Active Topics
Login
OK
General topics
Digital
Problems with Märklin 74490 turnout motors
2 Pages
1
2
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Johnvr
#51
Posted :
14 July 2013 09:17:23(UTC)
Retweet
Originally Posted by: Joe Meiring
Thanks Janne! You were brave to even "fix" the new ones!!
John VR very kindly took 2 of my "only working one way" 74991's and did the shorting out of the switches - and hey presto, they are both working now - both ways, all the time...so now, (don't tell John), but I have another 8 or so of 74490/74491's, and even a box of five new 74491's for him to do!!
Thanks John...:) see U this weekend?!?
Joe
Joe,
Yesterday I had to lift part of my own track to extract the faulty mechanism from one of my turnouts.
I soldered across the micro-switch. Now it is working perfectly again and track has been returned to layout - all working fine now !
One must just remember that the purpose of the micro-switch was to switch the current off when the mechanism had switched, so this safety feature has effectively been disabled.
2 users liked this useful post by Johnvr
Joseph Meiring
Janne75
User Profile
View All Posts by User
View Thanks
sikardon
#52
Posted :
14 July 2013 13:26:51(UTC)
Retweet
Hi John,
Is there any impact if I use 74460 turnout decoder?
Hi Janne,
Are you using 74460 on your turnout?
Thank you.
Sony
User Profile
View Thanks
eroncelli
#53
Posted :
14 July 2013 15:39:42(UTC)
Retweet
No impact when using digital control; only in analogue you might burn some solenoid (depending on how you control the solenoids)
3 users liked this useful post by eroncelli
sikardon
Joseph Meiring
Janne75
User Profile
View Thanks
Janne75
#54
Posted :
14 July 2013 17:24:38(UTC)
Retweet
Hi John,
Hi Janne,
Thank you.
Sony
Hi Sony,
Yes, I use 74460 in them if I remember right. Turnout motor switching time is adjustable at least with CS2 so no damage like burning them. I have 200 ms (milliseconds) switching time in them.
Janne
1 user liked this useful post by Janne75
Joseph Meiring
User Profile
View Thanks
MikeR
#55
Posted :
21 July 2013 10:42:37(UTC)
Retweet
Hi Everyone
As a result of this thread I decided to change all my 74490 turnout mechanisms by shorting the switches to prevent future frustration on the layout I am building. All the 'fixed' 74490 turnout motors work fine and I hope that I will reduce any future problems, as access to some of the turnouts is difficult.
I am using a CS2 to control my layout and while testing the 'fixed' 74490 mechanisms I noticed that after the mechanism has thrown there is a short buzz. To me this indicated that I may be able to shorten the pulse length to eliminate this buzz. However I was unable to reduce the pulse length below the 200ms default on my CS2. It is possible to increase the pulse length. I was working on the Settings screen for the specific point used for testing on the Keyboard screen of my CS2.
Is 200ms the shortest pulse length possible? or is it a limitation of the 60830 decoders? Alternatively has anyone an alternative solution to eliminate the buzz?
Member of ETE
1 user liked this useful post by MikeR
Joseph Meiring
User Profile
View Thanks
Posted :
21 July 2013 10:56:54(UTC)
Retweet
Marklin should double test the 74491 before left the factory.
1 user liked this useful post by steventrain
Joseph Meiring
User Profile
View Thanks
waorb
#57
Posted :
22 July 2013 16:44:58(UTC)
Retweet
Originally Posted by: MikeR
Hi Everyone
Hi Mike!
Congratulations!
I don't have that courage.
I don't realized that... I'll pay attention on that...
Same "issue" here. Which CS2 do you have?
Here is a 60215, with lastest firmware from Märklin.
Probably it's a software limitation... Maybe a standard from Märklin to guarantee that all solenoids will work...
Walter
WWW
BLOG
User Profile
View Thanks
MikeR
#58
Posted :
23 July 2013 21:57:21(UTC)
Retweet
Hi Walter
Thanks for confirming that you are also unable to reduce the length of the pulse. I am using a 60215 with version 3.0.1 (1) of the software. I am not sure whether this is the latest version but I did do an update some weeks ago. I have not tried using the RailRoad & Co Traincontroller software to see if I can reduce the pulse length. I will test this approach in the next day or so.
Having watched the video (see post #3 from Greg above) the shorting of the 2 switches was not as difficult as I imagined and I was able to complete the task on 24 point motors in about 4 hours. This included accessing all points to remove the point motors (unplugging the connections), opening the point motors, doing the required soldering, closing the point motors, testing and then reinstalling the point motors. The most difficult part was accessing 1 of the points for removal and then reinstallation of the point motor. I guess that Sod's law dictates that this is probably the point motor that will give problems in the future. The switches on all further point motors will be shorted before installation.
Member of ETE
2 users liked this useful post by MikeR
Janne75
Joseph Meiring
User Profile
View Thanks
waorb
#59
Posted :
24 July 2013 04:16:18(UTC)
Retweet
Hi Walter
Hi Mike!
I have the 60215 also, with updates from some (few) months ago. As I remember, the version it's the same (need to check, but 99% sure).
I have a little more than 40 turnouts (and 5 spare 'broken' motors) and after saw that video, I soldered all broken, and now they are ready to operate normally. On the layout, more or less, 8 motors was substituted by the soldered ones.
No issues till them. And happy not to need to send them to Germany.
Walter
ps. Meanwhile, I'll solder each one that isn't operating as they are supposed to.
(do not fix that do not need to be fixed)
WWW
BLOG
3 users liked this useful post by waorb
Janne75
MikeR
Joseph Meiring
User Profile
View Thanks
Danlake
#60
Posted :
08 January 2014 17:28:44(UTC)
Retweet
According to one user on this Danish forum he manage to get a reply from account manager Markus Schurr in Marklin service (in mid Dec 2013) acknowledging that they are aware of problem with the turnout mechanism and they are presently developing new ones that should be better than the old and is expected to be ready in half a years’ time.
The link to the post is (in Danish only):
http://www.sporskiftet.d...s-sporskiftedrev-7449091
Brgds - Lasse
4 users liked this useful post by Danlake
Joseph Meiring
waorb
Janne75
User Profile
View Thanks
Posted :
08 January 2014 18:34:31(UTC)
Retweet
I installed sixteen 74490 decoders 14 years ago and they are worlking fine all these years.I installed four 74491 twenty days ago and one of them is allready broken.
3 users liked this useful post by foumaro
Janne75
Joseph Meiring
User Profile
View Thanks
Janne75
#62
Posted :
08 January 2014 20:58:30(UTC)
Retweet
My Finnish Märklin dealer told me earlier that the oldest one are more reliable. I don't know why. So I suppose you have got these good old ones from the late 90's. Lucky you! So this is one proof again that 74491 are not better than 74490. I have opened many of these and have seen that both versions can have the very same version PCB.
Janne
2 users liked this useful post by Janne75
Joseph Meiring
User Profile
View Thanks
Danlake
#63
Posted :
03 May 2014 18:42:02(UTC)
Retweet
I had my first 74491 failure
The usual issue with the turnout getting stuck in one position...
I removed the small component and shorted the terminals.
Enclosed a few photos below (before/after).
Not being an electronic buff, why can’t we just remove the micro switch? What actually happens when we short the terminals?
I guess what I am asking is, instead of fiddling around with soldering, what would happen if you instead broke off the little plastic tap on the micro switch, in that way the switch would never be activated when the tong moves?
Brgds - Lasse
2 users liked this useful post by Danlake
Janne75
Joseph Meiring
User Profile
View Thanks
Janne75
#64
Posted :
03 May 2014 22:51:03(UTC)
Retweet
Hi Lasse,
I'm not an electronics genius either... As far as I know those tiny micro switches are needed for use with control boxes or other switching controllers where you can not limit the switching time. With at least Central Station 2 and Mobile Station 2 and (I believe) with many other controllers they are totally useless. You can limit programmable the switching time in ms (milliseconds) with these controllers.
I have shorted all my turnout motors by removing those micro switches and soldering them like in your very good photos. If I will install a new turnout I will open the turnout motor and modify it before it gets in use. I don't trust to the 74490 or 74491 turnout motors anymore with their micro switches. When they are shorted, the problems are gone
Janne
Joseph Meiring
User Profile
View Thanks
Posted :
04 May 2014 07:53:42(UTC)
Retweet
They are not totally useless since the off command from the controller might get lost on its way to the decoder, the decoder will not turn off the turnout motor and it might burn out.
They are totally useless with modern decoders that handle the switch off internally.
They are not normally needed with modern controllers that turn off after a period. But there were reports from users who heard a permanent buzzing sound from their turnouts because the off command had been ignored.
a high level of quality
, the
, and
absolute precision
. You will see that
in all of our products
2 users liked this useful post by H0
Danlake
Joseph Meiring
User Profile
View Thanks
Janne75
#66
Posted :
04 May 2014 09:50:28(UTC)
Retweet
Tom, all,
I will at least continue to use my 74490/74491 turnout motors modified as shorted = removed micro switches as I have not had any issues after this modification. Before there was many problems with failing turnout motors. It is not a nice feeling when it is needed to take turnout away from the layout when there is already scenery stuff around of it
. My Märklin dealer told me that the micro switches are not needed with CS2 or MS2, but you have a valid point why they may be needed in some rare cases.
Janne
Joseph Meiring
User Profile
View Thanks
Posted :
04 May 2014 09:56:09(UTC)
Retweet
Better safe than sorry.
Some folks use separate boosters for accessories. This prevents micro-shorts caused by wheels or centre rail pick-ups from disturbing the solenoid decoders. If you don't have new decoders with automatic switch-off, this can also help reducing the risk.
, the
, and
absolute precision
. You will see that
1 user liked this useful post by H0
Joseph Meiring
User Profile
View Thanks
Posted :
04 May 2014 12:56:24(UTC)
Retweet
Let's hope that Märklin come out with a new motor soon that has eliminated this problem. I thought that they had addressed it with the 74491, and I installed some of those in my small layout extention. They do seem to work better, but I may just have been lucky.
The 74490 I have on my layout are very hard to get to because of the way I have ballasted between tracks. I can get them to work by dribbling a bit of oil down the turnout lever, which seems to make its way to the microswitch and makes the contacts conduct again for a while. If I have to rip up the track for some other reason I will certainly short out the switches, even though I use manual control boxes. I'll just have to be careful to ensure that the button is not left in a depressed position.
2 users liked this useful post by RayF
Danlake
Joseph Meiring
User Profile
View Thanks
Danlake
#69
Posted :
04 May 2014 17:21:11(UTC)
Retweet
I am still trying to figure out the electronic circuit of the mechanism when used with an external decoder like K83.
From my basic understanding:
1. A command is being sent to K83 to open one of the output ports for e.g. 250ms.
2. The K83 briefly energize the circuit
3. As one part of the solenoid gets energized it gets magnetised and draw the steel plunger toward it
4. Towards the end of the travel the plastic part of the plunger hits a mechanical switch on the micro switch.
5. The micro switch cut off any power to the solenoids to avoid accidental burnout.
6. The micro switch is also being activated a bit earlier to stop the plunger in its travel to avoid a bounce back?
Question remains then, when we bridge the contacts we basically disable the switch? And will bridging and physical remove the switch have the same result?
And finally when the internal contacts inside the micro switch gets exposed to sparks (predominantly in 74490 and attempted to minimize in 74491 by using a varistor) what actually happens then? The switch will always be on or off or cannot turn off because the contacts are dirty?
What I don’t understand is what is preventing the plunger to travel back when the other part of the solenoids gets magnetised. Everything seems loose and friction less so why would a faulty micro switch somehow prevent steel and magnet to meet up as it should do???
I am just trying to understand the electronic circuit of it all...
Brgds - Lasse
1 user liked this useful post by Danlake
Joseph Meiring
User Profile
View Thanks
Posted :
04 May 2014 20:34:46(UTC)
Retweet
Hi Lasse,
The micro switch contacts become oxidised so that when the plunger returns to the other end the switch does not close as it should do. When you try to activate that solenoid again there is no connection to the coil.
Danlake
Joseph Meiring
User Profile
View Thanks
pn
#71
Posted :
05 May 2014 22:26:54(UTC)
Retweet
Hi All,
According to Viessmann's new items 2014 brochure, they will be reeling this year a point motor for Märklin C track. From the description it is already bundled with a digital decoder (can also work in analog mode). It's item number 4558.
Perhaps this can be a good alternative to overcome this long lasting issue with the 74490 turnout motors. Only time and experiments with Viessmann's new motors will tell. At least there's some hope...
Pedro
2 users liked this useful post by pn
Danlake
Joseph Meiring
User Profile
View Thanks
2 Pages
1
2
Go to Page...
General topics
Digital
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.712 seconds.
