Offline PierreGILLARD
#1 Posted : 16 February 2008 23:10:31(UTC)
PierreGILLARD
I have started to assemble sometimes ago the Walthers' kit # 933-2909.
I should later post a complete report, but I am facing a little problem at the moment : if I have found some Preiser figures to put inside the diner, I lack of accessories such as dishes, plates, glases, etc.
Does someone here have an idea where I can find or scratchbuild those kinds of accessories ?
Here are some pictures of the empty diner :
Pierre.
Offline jonquinn
#2 Posted : 17 February 2008 01:37:51(UTC)
jonquinn
I knows there's lots of that sort of stuff in 1:35 scale to accessorize but I don't recall seeing anything in HO 1:87.
for glasses, maybe you have some clear pastic spruce from some other model kit - heat it and get it to the right general size for glasses. you can tint it with dye (like rit dye for clothes) in warm water. I suppose theres lots of ways to make plates. if you could find some sort of hollow punch of the right/approximate diameter that would be the easiest way to make a whole mess of dishes or bowls.
I think you'll need a clear display case for pie and cake too.
#3 Posted : 17 February 2008 04:44:36(UTC)
I suggust paper plates
I made mugs from cutting a section of small tube
Two red mugs in 2nd picture here: http://layout.mixmox.com/1/Roundhouse-Christmas
Beer stein made with clear tube in 4th picture here: http://layout.mixmox.com/1/restaurant-night
For bottles I cut some bottles of a crate of bottles (Faller) - you can see the crate in the next image
Offline Rowan
#4 Posted : 17 February 2008 22:04:53(UTC)
Rowan
Plates and "stuff " are shapes at that scale.
Could you make some shapes with plasticene?
Good looking diner!
Smile
Offline Pianne
#5 Posted : 18 February 2008 19:13:01(UTC)
Pianne
You could also print out table tops with napkins, plates, forks & so on and glue then on the tables. Only glasses and such are of significant hight and will have to be modelled in 3D.
Or, print the plates (with food) on heavy paper and cut out before glueing.
Just a thought...
Kind regards,
Pieter-Jan
Bruges, Belgium.
Offline kbvrod
#6 Posted : 19 February 2008 02:47:12(UTC)
kbvrod
Hi Pierre,all,
Where on your layout will this be places.That IMVHO,will select you level of interior details.And,if I might add is a very good/great model,be proud to show it off!biggrin
Dr Dirt
#7 Posted : 19 February 2008 19:50:57(UTC)
The Bettie's Diner look like about year 1960 or late.
Offline ulf999
#8 Posted : 19 February 2008 21:43:54(UTC)
ulf999
It will be perfect next to your engine terminal Smile
Offline hmsfix
#9 Posted : 19 February 2008 21:47:14(UTC)
hmsfix
You might try etching techniques for making plates, spoons, forks, knifes etc.
Take a piece of electronic card board with a 50 or 70 micron copper layer, cut it in the shape of the table cloth, paint the plates etc. on the copper side, and etch the card board applying the usual methods when making PCBs (e.g. using india ink). Afterwards, paint the table details in their respective colors.
50 microns times 87 corresponds to prototypical 4.4 mm. Not exactly in scale with the actual hight of a plate, but you'll certainly recognize the profile on the table.
Just an idea...
Hans Martin
#10 Posted : 19 February 2008 22:07:59(UTC)
The HAG Catalogue show a set for a McDonalads Restaurant. Figures, Food BOxes Drinks etc.
May be of some help.
#11 Posted : 20 February 2008 00:55:16(UTC)
PierreGILLARD
Thanks to you all for all those suggestions ! Smile
I will be back on this in a couple of weeks.
Pierre.
Offline jonquinn
#12 Posted : 20 February 2008 02:02:55(UTC)
jonquinn
most diner food is pretty good. you certainly wont find their food delivered in boxes like Mickey D's - I've never seen any that serve on trays like the fast food chains do. many operators take pride in what the offer and serve, and there are a lot that serve much more than burgers or roast beef sandwiches with gravy.
there's probably several seated figures that would work well. the idea about printing the tables out with a spread was pretty good, but these places typically also have stacks of porcelain dishes, bowls and cups ready to go.
the exteriormight be a good place to try buffed out alclad paint, to get more of the polished stainless gleam, or maybe an applique of "bare-metal foil" - an adhesive backed real metal sheet that is mostly used by some model airplane builders for a really authentic metal look.
#13 Posted : 08 March 2008 18:48:07(UTC)
PierreGILLARD
<br />The HAG Catalogue show a set for a McDonalads Restaurant. Figures, Food BOxes Drinks etc.
Do you have any reference ?
I have not found it with Google.
Thanks.
Pierre.
#14 Posted : 09 March 2008 01:19:17(UTC)
Pierre,
Hag part number 547 and 548 Under Accessories and Spare Parts. PAge 92 in the 2007 Catalogue.
ALso http://www.berchersternlicht.ch/index.php
In their HAG Listing as 305-0547
Nev
#15 Posted : 22 March 2008 14:42:20(UTC)
PierreGILLARD
Thanks Nev.
In the meantime, Preiser has released exactly what I am looking for to complete the diner. Smile
At this point, I think the inside of the kit will cost me more than the kit itself ! [}:)]
Pierre.
#16 Posted : 22 March 2008 15:43:52(UTC)
yes the interior details do add up. Fast.
#17 Posted : 22 March 2008 16:05:23(UTC)
Very good, Pierre.
We are looking forward for the progress.
Offline kbvrod
#18 Posted : 22 March 2008 21:42:05(UTC)
kbvrod
Guest (6)
This page was generated in 0.831 seconds.
