Offline mbarreto
#1 Posted : 18 June 2013 14:35:44(UTC)
mbarreto
Hi again,
This question is just curiosity as at the moment I don't have a 3015 (although I have a 36159).
Can the new white transformers easily reverse direction of a CCS800 or 3015 croc, or is it needed a blue transformer?
Thanks in advance.
Miguel
Mostly Märklin H0.
Offline abisel
#2 Posted : 19 June 2013 18:02:08(UTC)
abisel
The 3015 is an older analog loco that has a mechanical reversing relay and will not function properly on the digital white transformer system. It would require the blue transformer.
The digital system has a constant voltage at the track so the 3015 will run at full speed until you hit the STOP button for the power. You can then move the manual reversing lever on the loco to get the 3015 to reverse direction.
The old blue transformers varied the power at the tracks.
#3 Posted : 19 June 2013 18:10:43(UTC)
I think that grey transformers (e.g. 6646, 6647, 66470) should work.
BTW: there are no digital transformers.
The transformers I mention have the old-fashioned speed knob and a driving voltage ranging 4 through 16 V AC and a reversing voltage of 24 V.
The mechanical reversing unit in the loco may require adjustment as the actual reversing voltage of blue transformers can be 5+ V higher than that of grey transformers (but nominal reversing voltage of blue and grey transformers is the same).
I've never had a 3015 so I don't know if the MRU is different from recent analogue locos.
Offline mbarreto
#4 Posted : 19 June 2013 20:27:14(UTC)
mbarreto
Thanks to both for your answers.
Well, I was referring to 6647 and 66470 transformers. I don't have one and I thought they are white by what I see in the pictures.
I just checked the pictures in internet and I still see them white... BigGrin Better refer to them by the reference.
My doubt is related to the reversing pulse voltage of the blue transformers versus the new 66470 transformers and the voltage needed by the 3015 reverse unit. Basically I don't know if the mechanical reverse unit is equal to the one of most other HO locos.
After reading Tom's answer I am not sure it is, but even if it isn't, it probably maybe tuned in a similar way.
(I never liked tune mechanical reverse units and I almost forgot about it as the only analogue loco I have is my first one: a 3029 bought in December 1969 in my 5th birthday)
Miguel
Mostly Märklin H0.
Offline Soest
#5 Posted : 21 June 2013 23:53:35(UTC)
Soest
I tried my 3015 on both the beige or cream trafo and the old big blue. On the newer trafo it reverses but with more of a jump than with the big blue. I also tried my 30159 with both trafos and there was no difference reversing. Maybe the 30159 has a later mechanical reversing unit. In any event it gave me a chance to give my Crocs their exercise.
Why do grown men play with trains?
Their wives insist they are insane
But their dreams they won't let down the drain
'Cause there ain't no thing so hard to lose as those disappearing railway blues.
thanks 2 users liked this useful post by Soest
#6 Posted : 22 June 2013 08:01:51(UTC)
Thanks for the feedback.
Can the reversing unit of the 3015 be adjusted?
If it can be adjusted, an adjustment should be all that is required to reduce the jump.
Offline Soest
#7 Posted : 22 June 2013 19:13:07(UTC)
Soest
Yes, the reversing unit can be adjusted on the 3015 in the usual way by adjusting the spring tension.
This page was generated in 0.407 seconds.
