Offline uhwerk
#1 Posted : 31 May 2013 01:10:32(UTC)
uhwerk
Hi... I've got an outdoor gauge 1 Marklin digital layout. I also have some DC locomotives. I'd like to be able to run them all at once - DCC decoders and such seem more readily available than Marklin digital ones. Is it possible to run both Marklin Digital and DCC protocols at the same time on a 1 gauge layout?
#2 Posted : 31 May 2013 02:01:29(UTC)
Yes, you can do this if you have a multi-protocol capable controller such as the Marklin CS2, the ESU Ecos or the Intellibox.
If you have a Marklin CS1, you need to upgrade it with the ESU CS1 Reloaded upgrade, which gives the CS1 the same capabilities as the Ecos.
We run locos with different protocols quite often on our club's Istein 1 Gauge layout (search the forum for 'Istein' to see pictures) using any of the above controllers. I've also done it on my H0 layout.
In the CS2 and Ecos, you just need to enable the protocols you want to run with (I don't know the setup of the IB, just that it can be done).
#3 Posted : 31 May 2013 07:58:45(UTC)
Many modern decoders support DCC and MM. So in case you have CS1 (not reloaded) or a CU 6021, make sure to get decoders that also support the MM protocol (from ESU, Uhlenbrock, or others).
This page was generated in 0.249 seconds.
