Offline matthewyturner
#1 Posted : 17 April 2013 15:02:17(UTC)
matthewyturner
I am having problems inserting and using the centre rail insulators which stop the electricity running. Any advice, pictures or videos would be usefull
Thanks!
#2 Posted : 17 April 2013 16:31:09(UTC)
Welcome to the forum.
C track, I presume?
Move that red cap left and right to make sure both metal lids are in, then push it on.
The little hook must show down.
See also:
https://www.marklin-user...olator-into-C-Track.aspx
Offline aos
#3 Posted : 17 April 2013 18:35:59(UTC)
aos
Hi Matthew, first welcome to the forum. Sadly, I have ruined a few of these cursed little things by trying to wiggle them on. They tend to split. I learnt a tip and that is to actually crimp the two metal strips closer together so that the red insulator slides on more easily. Also, make sure that you test the insulation works before building any more track. It saves having to lift up loads if it has not been successful. Since you seem to be a starting member, please let us know what locos etc. you have. Alan
thanks 1 user liked this useful post by aos
#4 Posted : 17 April 2013 19:35:05(UTC)
matthewyturner
Thanks everyone!
That was really useful and im really liking this whole forum. I think its great.
Thanks again,
Matthew
#5 Posted : 17 April 2013 22:19:11(UTC)
It was much easier in the old M-track days, a piece of paper between the centre rail metal tongues...
No need for special red plastic C-track inserts that are actually quite difficult to fit until you get it how it should be done... Have myself expressed some "opinions in a foul kind of language" trying to isolate C-track centre rail during times... Wink
#6 Posted : 18 April 2013 06:47:19(UTC)
Please, I hope that you do not write and say them nasty words that we all have used over time fitting the Red Overcoats.
Crying BigGrin RollEyes RollEyes RollEyes
#7 Posted : 18 April 2013 11:17:26(UTC)
matthewyturner
Just one more question. I have a double oval and if I icolated the inner oval and ran it with a seperate controller, would the trains fuse blow when it goes over the icolated point because it picks up energy from both power supplies.
Thanks!
Matthew
#8 Posted : 18 April 2013 11:27:14(UTC)
matthewyturner
Thanks!
Matthew
Offline amartinezv
#9 Posted : 18 April 2013 12:57:19(UTC)
amartinezv
Hello
I use shrinkable tube, you can buy in electric or electronic shops. it is cheaper than original marklin isolator
Antonio Martínez
www.raildigital.es/davidruso
Offline amartinezv
#10 Posted : 18 April 2013 13:14:13(UTC)
amartinezv
Thanks!
Matthew
Hello
If you are using 2 MS or similar digital equipment the answer is yes, you blow one or both MS when a train comes throught the isolation area. In this case you should use a spaecial device called lift up slider or something like that and put it in the isolation area.
If you are using analog power, I mean 2 transformers, the you should connect both in phase, it is easy, but a little tricky to do it.
Antonio Martínez
Offline hennabm
#11 Posted : 18 April 2013 21:44:56(UTC)
hennabm
Hi Matthew
Again welcome to the forum.ThumpUp
If like the last post, you are an analogue user then phasing the transformers is not as tricky in the UK with the 3 pin plug set up. So long as the two wires are secured and match within each plug they will be phased. The problem comes if you retain the German two pin plug and use an adapter for the UK. Then the phasing can be out and a spark will be seen as the train crosses the divide.
I have changed all my transformers to 3 pin plugs to make it easy.
1957 - 1985 era
What's digital?
thanks 2 users liked this useful post by hennabm
Offline TrainIride
#12 Posted : 21 April 2013 21:54:47(UTC)
TrainIride
Märklin of the sixties was so simple, easy and reliable !
Does this world become more and more complicated ?
It is called "progress"
Blink
Best Regards
Joël
This page was generated in 0.533 seconds.
