#1 Posted : 06 April 2013 03:36:40(UTC)
I had my 26730 out of the box for a few minutes on my test track. I have been preparing a photo inventory of my collection and wanted to take a few shots. I noticed that the set of wheels on the slider end of the locomotive were jammed and are very sluggish to turn. I oiled the axles and the mounts for the rod as indicated in the instruction booklet, but this has not improved things. Since I acquired the unit, it has not seen much use (a test lap or two) and I do not think it was used before I bought it. The motor drive is working fine. What is my best option to find out whether it needs a cleaning or needs more oil in a specific spot to get moving again?
#2 Posted : 06 April 2013 03:50:12(UTC)
Mike, have a look at the rods as you turn the wheels, if you find them getting really stiff make sure the wheels are correctly lined up.
Offline NZMarklinist
#3 Posted : 06 April 2013 04:58:39(UTC)
NZMarklinist
Mike,
26730/28730 sets were produced in 1998, so it is very likely the old M oil has gone hard and locked up the axles in the truck chassis
I would wait and see if the oil you have applied allready soaks thru and frees things up. Meantime do not force the wheels to turn by turning individual axles with your fingures, otherwise you may bend the rods !Scared
If they dont free up the best way would be to dismantle the Lok and remove the front truck from the Lok, and the rods if you have the tools and the skill, and give the truck a deep soak, over night at least, in something like shelllight as we know it here, or some old type lighter fluid, most of these products are highly refined petrol without additives, so should not harm the paint work.
You could also use isopropyl alcohol Laugh
Anybody in the US or Canada familiar with the local product names Cool There has been threads on this subject in the forum allready IIRC, I'm sure, so a few searches may turn up somemore info ThumpUp
If this works, and you can be bothered, you may want to do the same for the rear powered truck after removing all the electrics and armature etc as well, as the famous old M oil clogging process will have been at work there too, but the power of the motor has overcome it. The powered truck has all those gears as well so extra care is needed !
Then before reassembling the Lok give each axle an oil, I use Labelles 107 Wink , with the rods still removed and check they are rotating freely, but apply gentle, only, turning forces to both wheels on each axle at the same time otherwise you'll could have them turn on the axle get them out of alignment. If there is any resistance, put the truck back in the bath Blink
The rods should be at exactly 90degrees to one another, just the same as a Dampflok Wink
Good luck Smile
Glen
Auckland NZ
thanks 3 users liked this useful post by NZMarklinist
#4 Posted : 06 April 2013 05:16:55(UTC)
Glen,
I've heard quite a few times the oil hardens up, I must say, I've never found it with my locos, maybe because all my locos have been bought new and I've never oiled my locos except the rear armature shaft.
I think there must have been misunderstandings, what needs to be oiled and some modelers over oil the gears etc. etc. and over time (if the right oil wasn't used in the first place) but as you said a lot has been written about it and some grease-oil has anti dirt characteristics.
One of the reasons I've installed ball bearings mainly because of the armature and you will find very rarely the gears will make a noise. its like a car makes a motor noise you don't put oil into the transmission but for some reason modelers don't take the time to find out where the noise comes from and than oil the whole loco, just in case.
1998 isn't a long time ago when this loco was produced and it it would also be of great importance when members indicate whether the loco was bought new, used, from a dealer etc etc. this makes it a bit easier for us to determine what could have gone wrong with the loco instead of searching in the dark for possible solutions or advise.
regards.,
#5 Posted : 06 April 2013 09:22:23(UTC)
For some time Märklin used a "motor glue" type of oil at the factory. My 26730 also suffered from hardened oil (OK, I bought third hand or so).
I've also had this problems with "new" items from dealers (items the dealer had in stock for 10+ years).
My locos from the ’70s that I had stowed away for 25+ years had no problems with hardened oil.
Offline franciscohg
#6 Posted : 06 April 2013 11:13:27(UTC)
franciscohg
Chile
I had the same problem with some locos of the period. Since it is caused by stiffened oil, cleaning is mandatory. In my case, a good dose of WD40 after removing the truck worked very well, with no need of dismantling the wheels.
#7 Posted : 06 April 2013 18:15:24(UTC)
Thanks for the suggestions. I have not seen any improvement half a day after oiling the axles.
There is only once screw on the base of the assembly, which seems to hold the outermost axle and coupler in place. Once this is removed, can I remove the bottom panel and will I have access to the main axles and the drive wheel from the inside? This is the first time i have seen this kind of problem with a Maerklin lok.
#8 Posted : 06 April 2013 19:05:17(UTC)
Unfortunately not, Mike.
After carefully "un-clipping" the bottom gray plastic part, which also secures the front "hood" (remove the centre body part first, then the "hood"), you will not see the axels.
The axels are supported in metal bushings (brass?), pressed into the chassis.
But, on the other hand, none of the electric parts in that end is secured with screws or otherwise, so everything may be lifted up "as is", except for the red wire from the decoder to the slider contact.
When you have the metal part, including the axels and the rods only, it is easy to clean, with no possibility of damaging anything.
If you like, I can make a "photo story" tomorrow, with my own 26730.
Some photos can already be seen on my web site 26730
Offline Janne75
#9 Posted : 06 April 2013 23:20:53(UTC)
Janne75
I had similar problems with my 3300 Swiss Crocodile from 1985 and one of my 3756. 3756 needed only oiling and then it was ok. But 3300 needed an full maintenance to bring it back to working order. In this topic is good advices how to do it. It should not be too complicated.
I have bought most of my locos second hand "like new" or "new", but around 8-10 years old. Many of them have had jammed motor or gears etc. That oil or better to say grease Märklin used back then is the cause of this jamming. I have maybe fixed around 10-20 locos from this by dismantling them, cleaned the old grease away with new lighter oil and by turning the gears/wheels and at the same time cleaning the gears to get all that old grease off. When doing these locos maintenance I have found out that almost every time that grease is jamming some gears behind them and motor frame so that the gears can not turn at all or not as easy as they should. By putting some small drops of Faller light oil behind these gears have helped me every time.
Many locos front trailing truck wheels are also not turning as freely as they should. Many BR 86's I have and Bayerische EP 3/6 for example. Some drops of oil, turn the wheels first by hand and then put some pressure (weight) on this axle(s) by pressing it lightly towards the track to get it turning. After it begins to turn then some high speed running to free the axles even more. Here the problem is with very light loco axle weight and a bit old grease (or oil).
Janne
Edited by user 01 May 2013 18:48:20(UTC)  | Reason: Not specified
#10 Posted : 07 April 2013 08:44:44(UTC)
That´s way it is much better to have drive shafts disposed between the wheels.
Not behind of the wheel like old Marklin locomotivs!
Take look at Rocos models...they have drive shafts disposed between the wheels.
So in this case it´s easier to oil on the axles of wheels and don´t mess like Marklins croco.
#11 Posted : 09 April 2013 09:00:37(UTC)
I removed the rods and was able to narrow down the problem to the drive wheel on one side. All wheels in contact with the rails turned freely although the second one did not seem to remain in contact with the rails at all times and was therefore slipping ever so often. The drive wheel worked fine when one side was reconnected to the rod, but the other side seems to be gummed up.
I have concluded that the cover can be removed by looking at the 3756 exploded view, but I am not sure how to get at it. Can somebody please provide more detail on how to open up the crocodile? I have removed the screw to remove the cab, but am not sure how to remove the rest of the shell. The instructions seem to indicate that you have to release them from the bottom, but not sure exactly how to do this.
In the meantime, i applied a little more oil to the suspected troublespot and will let that soak in overnight. I will give it another go tomorrow.
Offline Guus
#12 Posted : 09 April 2013 09:28:25(UTC)
Guus
Hi Mike,
On some models of the crocodile the front and rear part of the body shell are really difficult to remove. The body parts' slots click into the mainframe. You could try and gently push a small piece of wood in between
the body shell and the frame. Said connection is next to the main drive wheel. See pictures below. One picture is of the frame and its "wedge" shaped part that clicks into the body shell. The other picture is a close-up of the inside of one of the body shells. The pictures taken are that of my newest croc the 3956x type, however the construction of the older type like the one in the 26730 ( loc 3756 ) set is identical.
On the other hand I don't think it is really necessary to remove the body in order to get access to the axles. When you remove the plastic part which Svein already mentioned, you have better access to the axles, especially the axle that replicates the drive unit. Not only is this plastic part, that models the brakes and sanding pipes, held into position by a screw but also by eight tiny plastic wedges that click into the frame. It may prove difficult to remove this part without the risk of damaging it.
Hope this helps.
Edited by user 14 April 2013 11:47:54(UTC)  | Reason: Added pictures and text clarified
Guus attached the following image(s):
Kind regards,
Guus
thanks 1 user liked this useful post by Guus
Offline Janne75
#13 Posted : 09 April 2013 10:31:24(UTC)
Janne75
If you want to remove Crocodile front or rear hoods you dont need any tools in newer (smaller) Crocodiles. Just press the hood outwards. It can be quite stiff to remove, but should be possible without help of any tools. In older bigger Crocodiles (CCS 800, 3015, 30159, 36159, 31859 and 31860 green and white versions) there is a screw securing the hoods.
As far as I can remember the hood (front or rear body) must be removed to be able to remove that plastic part near wheels and blind wheels. It was quite simple thing to do anyway. If someone can post a exploded view picture of Crocodile it is easy to see what is needed to dismantle it.
Janne
#14 Posted : 09 April 2013 20:08:21(UTC)
Guus' photo shows the little pins that have to be pressed in to remove the snout of the crocodile. Once I can get the cover removed, I can see exactly what will be required to fix the drive wheel so that it rotates freely and allows the rod and axles to turn freely. In any case, I want to be able to remove the shell and protect the wiring/electronics before I break out the Loctite to flush the oil/dirt out from inside.
Offline Janne75
#15 Posted : 01 May 2013 18:54:11(UTC)
Janne75
Mike,
Any progress with this Crocodile project? Do you still need help from Forum to fix it?
Janne
This page was generated in 0.734 seconds.
