Offline danmarklinman
#1 Posted : 24 February 2013 23:06:16(UTC)
danmarklinman
Hi how do i go about converting this Roco DC loco into an AC one. My thinking is to put an MFX decoder into it and run it of the wires. But will it still go round the Marklin K track and go through the tight radius points with the DC wheels.
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline kbvrod
#2 Posted : 25 February 2013 01:21:59(UTC)
kbvrod
Hi Dan,all,
You'll need a place to put the pick-up shoe and run a wire to that(decoder),then wire the wheel pick-ups to the ground.
Dr D
#3 Posted : 25 February 2013 02:31:09(UTC)
Hi Dan,
there are spareparts for this loco suitable for 3 rail (pickupshoe) however what you will encounter DC locos sometimes have both bogies poweres whereas AC models have one bogy powered or 2 bogies powered but leave one axle unpowered for the provision of a pick up shoe.
to convert your DC loco to an AC loco you have 2 options:
a.) get the bogy parts so it can accomodate a slider
b.) or run it from the pantographs
there is little work you have to do take the housing off and follow the wires. DC locos have isolated axles all you have to do is combine the wires (4 of them) but make sure they are connected to the right soldering pad (track connection - slider connection) or ( - + ).
most Roco locos have an 8 pin socket and I would suggest to get an ESU decoder (V4 M4) with an 8 pin plug which is equal to an MFX decoder.
I have not found an AC version of this loco and it would take someone else to find out if an AC bogy was produced for this type of loco
I'll keep searching
good luck
#4 Posted : 25 February 2013 08:59:24(UTC)
danmarklinman
Hi Dan,
I'll keep searching
good luck
Thanks for your help. I will be running it from the overhead,so know slider will be needed. But i will need a decoder and thanks for letting me know which oneBigGrin It will be some time however before i get one as i already have a French Marklin loco on orderLOL BigGrin
Wiking fan
Offline kbvrod
#5 Posted : 25 February 2013 22:59:01(UTC)
kbvrod
Hi John,all,
a.) get the bogy parts so it can accomodate a slider<
I don't know about Roco but Piko uses the same frame/boogies in their DC models that they also produce in AC.Make two different boggies,madness,I say.Still if they do a drill and self tapping screw can secure it.Solder a wire for it to the decoder.
>there is little work you have to do take the housing off and follow the wires. DC locos have isolated axles all you have to do is combine the wires (4 of them) but make sure they are connected to the right soldering pad (track connection - slider connection) or ( - + ).<
Yep,follow the wires from the wheel 'wipers'.
Dr D
Offline kbvrod
#6 Posted : 25 February 2013 23:09:55(UTC)
kbvrod
> I will be running it from the overhead,so know slider will be needed. <
WhyConfused
Dr D
#7 Posted : 25 February 2013 23:23:25(UTC)
danmarklinman
WhyConfused
Dr D
So you dont need a sliderConfused Any way it works out to be to expensive and i want a CS2 first plus a flat iron see pic
Wiking fan
Offline kbvrod
#8 Posted : 26 February 2013 00:36:50(UTC)
kbvrod
Hi Dan,all,
>So you don't need a sliderConfused<
Well,I had a girlfriend once,...LOL
Dan,you need to tell us more about your set-up and how you plan to run trains.If your E-loks(Roco or even M) are going to get power(+) from the overhead/catenary,that is fine.The wheels(even on a DC loks) can serve as the return (-)
Your other loks(steam/diesel) will have to run from the track.
> Any way it works out to be to expensive<
Welcome to the Jungle!BigGrin
Dr D
#9 Posted : 26 February 2013 03:25:05(UTC)
Dan,
its a petty you only ordered 1 of these iron ladies because I like to get one to but they are still very expensive.
John.
P.S.
running l;ocos from the overhead system is no problem as all my locos run via pantographs. the only other thing you have to be aware of if you use contact wiper tracks (blocksystem) your DC loco wilol not be able to activate them.
#10 Posted : 26 February 2013 09:35:15(UTC)
danmarklinman
Dan,
John.
P.S.
Hi yes i am looking forward to getting it, as it not out until Sept/Oct. They were a common sight in Northern France. I spotted one but could not take any pics as i was on an overnight train heading for Milan!
Wiking fan
Guest (5)
This page was generated in 0.408 seconds.
