Offline Brakepad
#1 Posted : 02 February 2013 22:02:28(UTC)
Brakepad
France, Metropolitan
Recently I bought a second hand 29855 set.
It is in very good overall condition. Everything works except the sound in the BR18 loco.
I would like to know if this is a common issue, or if there's something to "try" before letting it like it is or replacing the decoder.
Lights, smoke and motor works as they should.
Thank you very much.
Offline obxbill
#2 Posted : 02 February 2013 22:59:06(UTC)
obxbill
You have been a member since:: 20/12/2008(UTC)
I bought a second hand BR18.4 a couple years ago that has the bell and whistle sound effects. Mine didn't work either. Turned out the speaker was blown which I was told is common. Mine has the manual adjustment for the sound and I had to turn it way down when I replaced the speaker because I instantly blew the first one I replaced. It's pretty easy to replace the speaker as I did it twice! :) I believe it's a 5ohm but check it to be sure. The clip above show's mine after I fixed it.
Bill
thanks 2 users liked this useful post by obxbill
Offline mbarreto
#3 Posted : 03 February 2013 00:57:41(UTC)
mbarreto
I have one green BR18.4 Ep. II that has the same problem. I think even when it is good the original sound is below acceptable. Mine also has a problem of starting to move very fast without I change the speed knob. I will change the decoder with an ESU or Märklin mSD. The later is a lot cheaper and if the sound is acceptable I will go for it.
Miguel
Mostly Märklin H0.
Offline Brakepad
#4 Posted : 03 February 2013 08:10:31(UTC)
Brakepad
Thank you very much Bill. I did not know speakers could be bought separately. If they are available and not very expensive I would give them a try.
Best regards.
thanks 1 user liked this useful post by Brakepad
#5 Posted : 03 February 2013 10:04:01(UTC)
I have 29855 for nearly 10 years ago and I see BR18.4 find no problem since with 6021 and CS2.
Offline Brakepad
#6 Posted : 12 February 2013 21:44:13(UTC)
Brakepad
Is it possible to know which kind of loudspeaker should I look for?
I can not find any ref or part number on it. I would like to try to replace it and see if it sounds again.
Thanks.
Offline obxbill
#7 Posted : 12 February 2013 23:42:59(UTC)
obxbill
I replaced my speaker with a Miniatronics Corp. 8 ohm 3/4 inch speaker. Part number is 60-075-01. Hope that helps ya!
ill
thanks 1 user liked this useful post by obxbill
Offline Brakepad
#8 Posted : 16 February 2013 08:42:47(UTC)
Brakepad
ill
Thanks! After removing the old speaker I have seen there s an inscription on its backside:acoustec LD20/08, 8 ohm, 0.1 watt.
I have found nothing about this part on the web. I assume any similar part will do de job.
#9 Posted : 16 February 2013 09:33:05(UTC)
8 ohm or more to protect the amplifier, 0.1 watt or more to protect the speaker.
Offline Brakepad
#10 Posted : 01 March 2013 14:14:31(UTC)
Brakepad
thanks Tom! That's very useful information!
Offline Brakepad
#11 Posted : 22 April 2013 00:01:13(UTC)
Brakepad
Thanks Bill and Tom. Some time ago I purchased some "equivalent" speakers on eBay- 8 ohm, 0,25 watt, 20 mm diameter for less than 3€ the set of two- When they arrived from Hong Kong, 3 weeks after, they turned out to be somewhat thicker than the original one, but for the BR18 tender this was not an issue as there is plenty of space behind the PCB.
Yesterday I had the time to replace the loudspeaker, "just in case" the issue came from there...and today I have tested the loco. It works OK and the sound has come back. So thank to your useful advice my BR18 works as it should again for only 1,4€. The other option was to change the decoder or replace it with a Loksound...but this is not really a worthwile option.
This page was generated in 0.425 seconds.
