Offline danmarklinman
#1 Posted : 01 February 2013 16:39:25(UTC)
danmarklinman
Hi, i have a layout which is small and is a basic oval with a siding and a passing loop. I would like to turn this in to one end of a dog bone ,with one of the curves on one corner being taken apart and made into the narrow part of a dog bone .So it effectively becomes double track before splitting again into the other end of the dog bone. can anyone help me by giving me a simple track diagram with parts to make such a thing in C and K track. many thanks Dan.
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline Yumgui
#2 Posted : 01 February 2013 23:12:08(UTC)
Yumgui
Hi Dan,
Not much to go on in your description ... it's very general ^^ Mellow
Some further information would help the ppl here to help you (I will have trouble as I use only M track and VB for HO AC 3 rail )...
... like a photo or a sketch or something ?
And if you find an answer first, plz let us know. Wink
Yum ThumpUp
#3 Posted : 02 February 2013 23:27:04(UTC)
Hi Dan
? Is the existing oval track C or K
? are the existing turnouts for the loop standard (Straight/Curve) or double curve
? what is the max/optimal area the dogbone end can take up (also indicate if this might be modular - i.e. two or more transportable sections)
? do you want a symmetrical or asymmetrical return loop
? What double line spacing are you connecting into (Marklin standards are 77.5 and 64.3 for C-Track)
? Do you want to reuse the turnouts for sidings within the centre of the loop
? Do you want to retain a passing loop
#4 Posted : 03 February 2013 18:19:04(UTC)
danmarklinman
Hi Dan
Hi sorry now i was a bit vague in my question. All i need is the parts needed for a C track return loop which is as small as possible. There is a double track line sticking out the back of my layout on the left hand side,or there will beLOL The double track will need to have a small radius turnouts to creat a cross over and therefore a return loop! cheers Dan
Wiking fan
Offline LeoArietis
#5 Posted : 03 February 2013 20:19:16(UTC)
LeoArietis
Here are two tries. I usually use the second one, length of the track is +2.6 m (8½ feet) so you can fit a good sized train fitting a medium sized layout and the length of the loop including the turnout/point is approx 1.15 m.
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
Offline LeoArietis
#6 Posted : 03 February 2013 20:26:44(UTC)
LeoArietis
In the right one, numbers are : (24611 + 24172 + 24172 + 24188 + 24224 + 8*24130 + 24071 + 2*24130
Current layout:
The former project:
Offline LeoArietis
#7 Posted : 03 February 2013 20:34:49(UTC)
LeoArietis
It may look like it's not a perfect fit, but the difference is so small you, nor the track or trains will notice!
Current layout:
The former project:
Online H0
#8 Posted : 03 February 2013 20:50:34(UTC)
Originally Posted by: LeoArietis Go to Quoted Post
Here are two tries.
I cannot see your images. And I bet many others cannot either.
Never use the IMG tag for album images, the ALBUMIMG tag has to be used!
Or simply attach the images to the post.
#9 Posted : 03 February 2013 21:13:13(UTC)
danmarklinman
Cheers for that, thats great thanks. What i would also like is not to join them up but return to a double track. tar Dan
Wiking fan
#10 Posted : 03 February 2013 21:15:05(UTC)
Edited posts to show the image...
Online H0
#11 Posted : 03 February 2013 21:29:04(UTC)
Here are two simple reversing loops (one only 24130, the other uses three 24230). The turnouts are only used to get the correct distance.
If spaces allow, I'd avoid double curves without straight tracks in between.
Online H0
#12 Posted : 03 February 2013 21:42:44(UTC)
Other reversing loops (R2 on the left, R1 on the right).
Online H0
#13 Posted : 03 February 2013 21:57:55(UTC)
And two more loops (R2 on the left, R1 on the right) that really make it look like a dog bone.
#14 Posted : 03 February 2013 22:02:30(UTC)
danmarklinman
Hi thats spot on cheers, thankyou,part two of my layout coming upLOL
Wiking fan
This page was generated in 0.624 seconds.
