Offline Thewhip1970
#1 Posted : 25 January 2013 21:33:56(UTC)
Thewhip1970
I have purchased a Maxi #5454 Central Pacific Locomotive. It was running fine and all of the sudden stopped. The lights will still operate in the forward and reverse direction, but the train will not move. Have tried another locomotive on the same track and it works fine. Has anyone ever experience a similar problem?
Offline mike187
#2 Posted : 25 January 2013 22:06:30(UTC)
mike187
Hello:
See if the switch in the cab is set for normal run. Also check that the chip is properly seated
Paul
Offline Thewhip1970
#3 Posted : 26 January 2013 15:18:42(UTC)
Thewhip1970
Thanks Paul. The only switch in the cab is for the smoke generator. I took out the chip and reseated it. It worked for about 2 seconds and stopped again. I am going to check the wiring for a short.
Offline Thewhip1970
#4 Posted : 26 January 2013 18:59:31(UTC)
Thewhip1970
Got it! A wire had come loose at the motor. I soldered it back together and it is working good as new.
thanks 1 user liked this useful post by Thewhip1970
This page was generated in 0.464 seconds.
