#1 Posted : 15 January 2013 07:21:48(UTC)
I did noticed that severals new models from Trix has symbol DCC/mfx.
Does anyone nows why this sign symbol?
Has this to do about cab control in CS2 as new from Marklin...???
Confused
#2 Posted : 15 January 2013 08:30:25(UTC)
No. I'm surprised it comes so late as they include the new MS2 in Trix starter sets since it was released.
The cab control requires mfx+.
I hope mfx can be disabled with the Trix locos. I wonder if they include DCC in Märklin locos.
We'll find out when items have been shipped and reviews have been written ...
The Trix new items brochure tells that 9 functions can be controlled with mfx using a Mobile Station 60653 (16 with a Central Station). It's sure they need a better proof reader.
Offline pn
#3 Posted : 15 January 2013 09:57:42(UTC)
pn
Yesterday, while navigating through the Trix brochure I was also wondering if they also support DCC on Märklin's locos.
To me it seems that they just use the same decoders now in Märklin and Trix locomotives. If that holds true then DCC should (theoretically) be available in Märklin's locomotives. Unless they have a way of disabling DCC. That would serve two purposes. On one hand, avoiding that 3 rail fans adopt DCC easily with Märklin's help and, om the other hand, invite Trix 2 rail fans to start using mfx more and more. Having invested in improving mfx with the "+" version, the strategy seems to be clear...
Offline Lollo
#4 Posted : 15 January 2013 11:06:22(UTC)
Lollo
I was informed by a Marklin dealer that they use the same decoders in the new Trix & Marklin models. This makes sense for production purposes. Remember also the new Marklin decoders are multi protocol, (MM)mfx/fx & DCC. With CV 50 you can turn off Analog AC & DC, MM-fx & mfx, but DCC is always on (cannot be disabled)
Easy to convert a new Trix loco for MM 3 rail, turn on MM-fx & mfx protocol, fit a slider and a bit of rewiring of the power pick up from the wheel power contacts. But conversion from AC toTrix DCC not so simple because of the AC wheel sets. ??
New info:
I have just compared parts list for the BR 94, Marklin 37165 & Trix 22160
The decoder part No is listed for 37165 but not for the 22160, but would suggest same decoder for both.
Now this is interesting. There is a power pick up for both sides of the wheels on both frames, the only difference with the marklin model is the addition of the slider. This suggests to me they are the same production model both with isolated wheels for DC/DCC pick up, and they just add a slider for the Marklin model, and change the wiring of the pick up.
This is most practical for production line purposes. Basically thats what ESU do with their Engineering Edition Locomotives. If you want to run the AC version DC, you just remove the slider. This is despite the fact that they sell DC & AC versions.
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
#5 Posted : 15 January 2013 11:58:57(UTC)
Originally Posted by: Lollo Go to Quoted Post
......and a bit of rewiring of the power pick up from the wheel power contacts.
You don't even need to go that far! With my 2 Trix Br44's, I didn't bother changing the wiring, as those locos have good earthing as it is. I haven't had any problems with running them as yet, but if I did I can modify the wiring to earth them on both sides. As they are now, it would be real easy to convert them back to 2 rail DC running should that be needed.
The Br44's already had wiring from the slider contact point under the loco to the 21 pin decoder plug, so there was no need to change that. All I had to do was remove the 2 rail DC pickups. Of course, other Trix locos might be different, but that was my experience with the Br44's.
Edited by user 15 January 2013 21:20:03(UTC)  | Reason: Not specified
#6 Posted : 15 January 2013 11:58:59(UTC)
Märklin Magazin wrote years ago that they use the same decoders for Märklin and Trix. 39390 (BR 39) and 39230 (BR 23) were the first locos with these new decoders.
But so far they have used different firmware: one for Märklin (no DCC), one for Trix (no mfx), one for mLD and mSD (DCC and mfx).
I would not be surprised to find that Trix locos now come with DCC+mfx while Märklin locos continue to come with MM+mfx.
Will be interesting to see what they do about mfx+ in mSD decoders. Will there be mfx+ with DCC and MM? Or will there be different firmware versions for mfx+ with MM or the "classic" mfx/DCC/MM? Or will they restrict mfx+ to factory-installed decoders only?
But that's a bit off topic here.
With mLD/mSD sold separately, you can disable any protocol (incl. DCC). You cannot disable the protocol used for programming.
Using MM you can disable mfx and DCC. Using DCC you can disable mfx and MM. Using mfx you can disable MM and DCC.
#7 Posted : 15 January 2013 20:37:49(UTC)
So what has happened to the Trix Selectrix Protocol??
Nev
#8 Posted : 15 January 2013 20:53:30(UTC)
Märklin/Trix make no decoders with SX. For N gauge they buy third party decoders for SX and DCC AFAIK.
People with SX only controllers cannot buy digital Trix locos any more (but they still offer analogue locos).
BTW: ESU make decoders with SX, DCC, MM, and mfx. So it can be done, but for Märklin it's probably not worth the effort.
#9 Posted : 15 January 2013 22:18:18(UTC)
If Marklin offers to customer with cab control at update CS2 with mfx+...they should do it same for DCC customer.
If not less ESU do it at ECOS 50200 for DCC.
By the way...Marklin BR39 and BR23 don´t have same motors like in Trix...!?
Marklin has SDS motor in those models while Trix have maxon motor so it´s not possible to have same decoders.
#10 Posted : 15 January 2013 23:17:13(UTC)
It's possible to have same decoders (hardware) with different settings.
#11 Posted : 16 January 2013 18:34:30(UTC)
But still not the same decoder since SDS motor did disturb DCC decoder.
You can set same way but not using same decoder.
Back to topic...I don´t think DCC customer can use cab control with Trix locomotiv at CS2 upgrade from Marklin.
#12 Posted : 16 January 2013 18:52:43(UTC)
Same decoder. SDS does not disturb DCC.
For cab control you need mfx+ and the Trix new items only show mfx, not mfx+.
#13 Posted : 19 January 2013 09:48:48(UTC)
Wrong!
I did had one Trix with SDS motor and DCC sound decoder.
For cab control to 2 rail customer Marklin must offer do that too in CS2.
So i suppose Trix new models with mfx symbol are for cab control even if there is no symbol like +.
Maybe it´s an missing point here from Marklin for 2 rail customer...
#14 Posted : 19 January 2013 10:09:05(UTC)
Wrong!
Which loco was it (ref. number)?
I have one Trix loco with SDS and soundless DCC decoder, no problems at all (with my controller at least).
I presume my loco has a D&H DCC decoder and not one of the new el cheapo "Universal Genius" type. You cannot blame the motor if the decoder is crap; maybe the problem was with the controller.
#15 Posted : 20 January 2013 10:02:49(UTC)
Wrong!
It doesn´t matter what kind of model since other customer did hade same problems with own locomotivs with SDS motor and DCC decoder.
No wonder why Marklin did stop SDS motor since customer did complained.
The problem was SDS motor so of course i can blame it!
By the way...it seems Trix new locomotiv with mfx sign has to do about cab control.
#16 Posted : 20 January 2013 10:32:11(UTC)
No mfx+ symbol in the Trix brochure - and mfx+ is required for cab control.
I continue to disagree - but OTOH I don't care who you blame. It works on my layout (one Märklin loco with Compact C-Sine and ESU decoder, one Trix loco with SDS and original decoder - both operated using DCC).
#17 Posted : 23 January 2013 05:37:36(UTC)
Nope!
Rocos Z21 allows all type of locomotivs even Marklin too.
Yet you can have cab control for that.
Why not for 2 railer with CS2 since it supports DCC too...?
So to get cab control in CS2 via only mfx+ don´t make sense!!!
I beat that cab control in CS2 will also supports DCC locomotivs.
#18 Posted : 23 January 2013 08:38:37(UTC)
Makes perfect sense for Mother M - they want to sell CS2s and new locos.
With mfx+ the loco decoder stores the available sand, fuel, coal, water, whatever - can be done with DCC, but not with third party decoders or old decoders.
#19 Posted : 23 January 2013 09:32:54(UTC)
I don´t care of what you say about aunt M since they will get trouble with customer who problamy to choise Rocos Z21 instead.
As i did said...Marklins technology don´t make sense for customer who are using DCC and 2 rail.
There is an common of why Trix have sign symbol mfx too in 2 rail locomotivs.
It´s for cab control too.
But that is up for Marklin to been smart.(which i don´t think so)
#20 Posted : 23 January 2013 10:41:35(UTC)
It's a fact that the Märklin new items brochure says that mfx+ is required for cab control.
It's a fact that the Trix new items brochure announces mfx (and not mfx+) for new Trix models.
Errors in their new items brochures are not unusual, but I wouldn't rely on them providing more than they promise.
Let's just wait for a corrected new items brochure or for the items to be shipped. Time will tell.
Z21 has a much nicer cab control that works with any decoder. No need to wait for MäTrix ...
This page was generated in 0.632 seconds.
