Joined: 04/12/2012(UTC) Posts: 5 Location: San Diego, CA
I've seen photos (like the one attached) where an E44 is clearly capable of operation without overhead catenary. Does anyone know for what approximate distance or time period can they do this? dick_in_sd attached the following image(s):
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
I'm not sure if this is meant to be a serious question. I don't mean to offend.
Electric locos have no means of moving without power. There are some types that can collect power from a third rail, much as the Marklin models do, but as far as I know this is not possible for an E44.
I'm pretty sure it found its way onto that turntable having been pushed by a small shunting loco. |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
No offense taken, but the question was a serious one. I know from drawings I have that there are batteries in an E44, and, in addition to the photo I attached the first time, here are a couple more where it seems like the locos are in service, and are in locations without catenary. I therefore came to the conclusion the batteries must provide capability for (probably limited) self-motivation. Granted, these could be static displays, but I'm still curious whether they can move at all on the batteries. dick_in_sd attached the following image(s):
Joined: 14/12/2002(UTC) Posts: 800 Location: Newcastle NSW Australia
This could be a interesting topic but I hate to inflict any hope that they can move on batteries. The batteries usually only supply DC power to the the relays associated with supply pump up the Main resevoirair supply & auxilary items such as cab lighting untill the pans are raised to supply Catenary power which will cause the Air Compressor to cut in & then pump up the Main Resovoir to supply air to all operate all contactors , relays & brake pipe functions when the engine is cut in for service. Sometimes a small auxilary compressor is used to raise the Pans or even a foot pump used.
If a Elok needs to be moved with pans down usually a small diesel engine is used or a road tractor instead, on a turntable normally a winch is used to pull dead engines into place . I should say that I am going on Australian railway experience but most railways are very similar in their operation in this regard even to the point of doing a swifty at night without prying eyes of management where a Elok due for its standard maintance check would be run down under the wire with the points[switch] set for the required dead road & the pans dropped at a cruicial moment to allow the Elok to roll in with no power available & relying on the brakes for a safe pull up.
Regards Tom in Oz with 28 years of rail experience under the belt.
Joined: 28/11/2007(UTC) Posts: 8,241 Location: Montreal, QC
Many turntables do not have electrical wires that follow the rotating platform, but do have wires that run the length of the tracks that are attached to them. This means that the pantographs have to be lowered for operation of the turntable. When entering or leaving the turntable, the lok will use the leading panto as the trailing one would snag on the loop in the middle where the wires are all attached. The batteries are there for power to the cab, lights, pantograph motors, horn, etc and maybe to the brake pressure generators, etc. There is no power to the motors Regards Mike C Edited by user 20 March 2013 21:44:21(UTC)
| Reason: Not specified
Joined: 23/11/2007(UTC) Posts: 1,828 Location: Sydney, Australia
Originally Posted by: dick_in_sd  No offense taken, but the question was a serious one. I know from drawings I have that there are batteries in an E44, and, in addition to the photo I attached the first time, here are a couple more where it seems like the locos are in service, and are in locations without catenary. I therefore came to the conclusion the batteries must provide capability for (probably limited) self-motivation. Granted, these could be static displays, but I'm still curious whether they can move at all on the batteries. A bit off topic, but was this photo taken at Leipzig? |
Gary Z Scale "Never let the prototype get in the way of a good layout" |
Electric loco's require 12,000 volts AC from the overhead wires in Germany,there is no way you can generate that voltage by means of batteries. Neither is there a way to move 100 tons of steel by means of some batteries only. Electric loco's are being pushed on the turning table (Drehscheibe in German) by a smaller diesel loco,i have seen that happening at Bochum-Dalhausen. If you find electric loco's with the pantographs down they are either static and not moving or being pulled by a locomotive under power,in Holland we call this "opzending" ("in despatch"). Edited by user 15 January 2013 18:29:56(UTC)
| Reason: Not specified |
Have more than you show,speak less than you know (Shakespeare). |
Joined: 02/01/2009(UTC) Posts: 1,067 Location: Auckland, New Zealand
To add to what has been said already, in some areas electric locos will rely on their momentum to bridge a gap in the catenary. This is done for example where bridges are not provided with catenary for clearance purposes. Enginedrivers will drop the pantographs before the bridge, coast over the catenary-less section and then raise the pantographs once there is catenary overhead. During this time batteries will take over the essential functions like lights and auxilry power.
On some border stations where two diffrent electric systems meet, the catenary system changes over halfway down the station track, and an engine would come into the station under power, drop it's pantographs while coasting to a halt undr the "foreign" catenary. A Diesel would then take away the loco, after which another loco that runs on the new system will come in and couple up to the train before departing.
Finally, in some cases, especially in the first half of the century air reservoirs and batteries did not last as long as they do now, so hand pumps were provided to manually raise the pantographs if the loco did not have enough air in the system to operate the pantographs.
Cheers, Rick
 1 user liked this useful post by kariosls37
Joined: 16/02/2004(UTC) Posts: 15,452 Location: DE-NW
Hi! Originally Posted by: dick_in_sd  in addition to the photo I attached the first time, here are a couple more where it seems like the locos are in service, and are in locations without catenary. Looks like the museum track at Leipzig. They have so many platforms there, they can use one to display historic rolling stock. History electric locos are often displayed on tracks that have no catenary. BTW: nominal catenary voltage is 15,000 volts in Germany, Austria, and Switzerland. Motors are often operated at lower voltages and those old locos have AC/DC motors similar to those used by Märklin Here's a picture of a battery powered loco: http://home.arcor.de/akkuschlepper/42.htmThat small battery-powered orange shunter just hauled the big diesel loco out of the shed. So it doesn't seem impossible to include this in a regular loco (but AFAIK it was never done for E 44 or E 04 or other German locos of that era). "Drehscheibe" is the German word for turning table. |
WOW! What a wealth of VERY enlightening responses. Thank you all!
I've only recently begun trying to build a layout for some Märklin equipment, including a 3011, that have been in storage for years. I've cnoverted them to DCC, but at the same time am trying for as much realism as possible. But catenary is not an option ($$) at this time, so I was hoping there was a believable answer to the question: "Where do they get their power from?" -- I hoped I could legitimately say "they have batteries for short distances." Oh, well!
But I truly appreciate the info!
Joined: 29/01/2012(UTC) Posts: 1,422 Location: Montreal, Canada
@Rick Brilliant idea! ... the locos coasting over bridges and into stations where the new catenary systems start. @Tom Great photo of the little orange guy. My 7 year old girl said "Cutsey, its a baby croc."  Edited by user 18 March 2013 04:58:08(UTC)
DB DR FS NS SNCF c. 1950-65, fan of station architecture esp. from 1920-70. In single point perspective, where do track lines meet?
Joined: 15/03/2011(UTC) Posts: 1,757 Location: Auckland NZ
Originally Posted by: dick_in_sd  I've seen photos (like the one attached) where an E44 is clearly capable of operation without overhead catenary. Does anyone know for what approximate distance or time period can they do this? I believe the old adadge applies here; "dont believe anything you are told and only half of what you see " The '44 on the turntable was likely shunted there after, or before, being stored or worked on, in the roundhouse, or perhaps thay simply wanted to turn it. I was fortunate to be in Chiasso, the Swiss/Italian border town south of Lugano, in the company of a few list members of this forum, prior to the 2005 M Treff, to witness how the change over of electric systems is handled. Some trains stopped at the platform and ELoks were handled, and replaced, by E shunters as it seemed the current could be switched on some platform tracks, but the Cissalpino Express Railcar Trains, from Milan and points South, could clearly be seen lowering a panto as they came into view, coasting for a few 100 meters, then raising a different one, obviuosly connected to a different transformer, and carrying on their way into Switzerland, some bound for Germany too. We also got shunted around the platform by Uniformed Italian officials with barriers, keeping us on the "Swiss side" of the border which depended on where the train was going to. Jacques Vuye was there, if he's reading he could elaborate on this whole Elok self powered or not business. |
Glen Auckland NZ
CS1 Reloaded, Touch Cab, C Track Modules, K track layout all under construction. Currently Insider |
Yes that indeed is Leipzig. The Museum Loks are all parked on track 24. Track 25 is now an indoor car park. Track 1 and 2 on the other side of the building are being reworked for the new S-Bahn City Tunnel. http://en.wikipedia.org/wiki/City_Tunnel_Leipzigr/Thomas |
ETE  ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V |
Joined: 15/03/2013(UTC) Posts: 85 Location: South Brisbane, Queensland
Hello again; Just adding my two cents worth to this topic 1. The earlier electric locomotives used DC motors only since it wasn't until the last few decades that AC asynchronous motors were introduced these have two sets of windings so you just switch power to either set of windings, you don't switch polarity which is what they did with the DC motors 2. There is not even a battery with enough storage since it would have to supply 700 to 900 amp at 1500 Volt just to start the train from rest and around 400 continuosly to keep the train moving  . Yes to those who know about these things the question seems silly but you are entitled to ask. Also I have seen them moving them around Enfield and Chullora and you need to use a diesel if there is no catenary
Joined: 20/11/2010(UTC) Posts: 426 Location: Worcestershire, UK
evan.v.giles wrote:The earlier electric locomotives used DC motors only Not in Germany/Austria/Switzerland, and the E04/E44 types shown in the photos undoubtedly have traction motors fed directly with AC. There is no doubt that, until the arrival of modern high-power electronics, the best type of motor for railway traction use was DC. However, DC traction supply is expensive and high-voltage AC supply with voltages transformed down on the loco is considerably cheaper, but on-train rectification, to convert the AC to DC for the motors, was a significant problem. There is a kind of motor that will work with both AC and DC voltage but in traction use, the effects of "commutation" make this unattractive for railway use at the normal industrial frequency of 50Hz. That is why Germany/Austria/Switzerland railways went for high-voltage AC supply but with the industrial frequency converted to 16 2/3Hz for railway use, and this means that AC voltage is applied direct to the motors (after being transformed down from 15,000 volts). Modern electronics has made this unnecessary but I can't see the countries where 16 2/3 Hz is used for traction changing to 50Hz any time soon. |
Robert
Era III - IV
2 x Central Station 2 v.2 (60214 + 60215) Hardware versions 3.6 / 4.33 Software version 4.2.1 (0) |
Originally Posted by: Robert Davies  evan.v.giles wrote:The earlier electric locomotives used DC motors only Not in Germany/Austria/Switzerland, and the E04/E44 types shown in the photos undoubtedly have traction motors fed directly with AC. Those motors are AC/DC motors (similar to the Märklin AC/DC motors of analogue models). And yes, the low frequency of 16 2/3 Hz was chosen because DC would have been better for those motors. |
Joined: 19/09/2009(UTC) Posts: 841 Location: Lidingö, Sweden
Originally Posted by: H0  Originally Posted by: Robert Davies  evan.v.giles wrote:The earlier electric locomotives used DC motors only Not in Germany/Austria/Switzerland, and the E04/E44 types shown in the photos undoubtedly have traction motors fed directly with AC. Those motors are AC/DC motors (similar to the Märklin AC/DC motors of analogue models). And yes, the low frequency of 16 2/3 Hz was chosen because DC would have been better for those motors. In Sweden and Norway electrifcation of the railways started pretty much at the same time as in Germany, Austria and Switzerland and the same voltage and frequency were chosen. To add to Tom's comment. It is correct that DC would have been better. When electric railways first came about, the electric equipment industry*) had a couple of decades of experience from electric trams. At that time it would have been less complicated to feed also railway lines with DC. However, there is an important difference between a tram network in a city and a railway line and that is the distance between where the electricity is consumed**) and where it is fed into the catenary system or combined catenary and power line system. With DC distribution over large distances, the transmission losses would have been too large. With an AC transmission you can transform the electricity to a higher voltage for transmission and given that the losses are related to the square of the current, the lower current you transmit the better to keep the losses at bay. So the requirement that the electric industry faced when going into electrification of long railway lines at the beginning of the 20th century was to have an electric current that could be transformed, in other words it needed to be an AC, and at the same time be as similar as possible to DC in its behavior. And the latter was related, as Tom pointed out that the electric motors were similar to DC motors where industry had "long" experience from electric trams. This explains in part the "strange" frequency of 16 2/3 Hz, which isn't so strange if you think about the fact that it is one third of the 50 Hz that was becoming the European standard and to build rotating converters was relatively easy - in principle just a large 50 Hz electric motor directly coupled to a generator for 16 2/3 Hz. ____ *) Companies like ASEA in Sweden, BBC in Switzerland and Siemens in Germany to name a few. **) Strictly speaking, the electric energy is not consumed but converted into motion energy (and heat) in the tram or electric engine.
Joined: 24/12/2008(UTC) Posts: 422 Location: Niagara, Ontario
I was in Nice France recently. As I drove through a construction area I was alongside tram tracks. In places it had no catenary, in others it did. Trams went by. They would lower the catenary and carry on normally. There was no third rail. I did notice a part of the track where there was a trench dug in the centre between the two tracks. From that I assume the must be an underground third rail. It cannot be dangerous as the track area is to fenced off. People were walking on it. What is the secret? Maybe we can run our electric loks with the pantograph s down and still be realistic!
Originally Posted by: Dreadnought  From that I assume the must be an underground third rail. It cannot be dangerous as the track area is to fenced off. In Nice the trains have batteries to pass sections without catenary. http://en.wikipedia.org/wiki/Nice_tramwayIn other towns they use third rails in the middle of the track. Only small sections under the train are on power. Used for street cars only in old towns where they do not want to have catenary. See Bordeaux: http://en.wikipedia.org/wiki/Bordeaux_tramwayClass E 80 of Deutsche Reichsbahn already had batteries and pantographs. Many others had batteries but no pantographs. It was said before: it would be technically possible to equip an E 44 with batteries to have it run short distances without catenary. But AFAIK E 80 is the only German electric loco with that capability (batteries are heavy and will be avoid if they are not used rather often). |
