Offline BrandonVA
#1 Posted : 12 December 2012 20:23:41(UTC)
BrandonVA
Hello all,
What's the minimum bridge clearance that will allow a train to pass underneath, assuming no catenary is used (say all steam and diesel locs)?
I realize this will vary by track (C, M, K). With K, I have always used the approximation of about 3 inches (76.2mm) from the ground to the bottom of the bridge. So, what fits in this space is the track plus the loco/stock height-wise. I don't think I could get away with too much else. I could measure all my locs/stock, but I'm interested in a somewhat universal number in case I get something new later that's a bit bigger for some reason. I am most interested in C or M track, as I will probably use one of these for a simple play layout, maybe even a retro layout!
I am working to design a somewhat simple super compact layout for the kids to play with that is a bit easier to reach all the parts than mine. I'm still interested in having some dimension. Thanks in advance for any help. It may not be possible, but I am considering at the moment building it on a hollow core door, which I can get cheaply at the hardware store. The largest are about 36x80 inches (91.4x203.2 cm)
-Brandon
Offline kbvrod
#2 Posted : 12 December 2012 20:34:09(UTC)
kbvrod
Hi Brandon,all,
Loading gauge,....smaller in Europe than the US,...
1) track used(i.e. roadbed)?
2) largest and longest lok?
3)Get going! Laugh
Dr D
Offline Joseph Meiring
#3 Posted : 12 December 2012 21:15:25(UTC)
Joseph Meiring
Hi Brandon - i have 65mm clearance (one area only 60mm!): measured from the top of C track rail to bottom of bridge supports - a bit tight, i know, way less than M recommends!! But it works for all my rolling stock, and Steam n Diesel locos. They all pass easily.......
Joe
thanks 2 users liked this useful post by Joseph Meiring
#4 Posted : 13 December 2012 00:20:26(UTC)
Edited by user 16 January 2013 14:08:15(UTC)  | Reason: Not specified
Offline Hoffmann
#5 Posted : 13 December 2012 00:38:40(UTC)
Hoffmann
These are the clearances recommended by Marklin
M-Track/C-Track= 74.5mm for Steam and Diesel Locos 80.5mm for E-Locos Pantos lowered 104.5mm for E-Locos with Catanery
K-Track = 68.5mm " 74.5mm " 98.5mm "
all measured from bottom of the Track
Martin
marklin-eh
thanks 5 users liked this useful post by Hoffmann
Offline BrandonVA
#6 Posted : 13 December 2012 17:08:56(UTC)
BrandonVA
Thanks all, I have an absolutely clear answer at this point!
-Brandon
Offline Yumgui
#7 Posted : 13 December 2012 20:13:14(UTC)
Yumgui
Brandon, AK,
... I recall that in one of the Maerklin catalogues the minimum clearance was defined in the bridge and ramp section ...
Clear heights for M and K track have appeared in others too, but see here from the 1988-89 ENG catalog ... (see uploaded high rez scan too, for printing on A3 [or 11"x17"] format ^^) :
Yum Tongue
This page was generated in 0.427 seconds.
