Offline wsscott
#1 Posted : 09 December 2012 21:10:37(UTC)
wsscott
I have setup a new layout with some turnouts from the main circle that runs into a smaller circle. One of my cars is a lighted Christmas car, and when it crosses over each of the turnouts it sparks. Is this a problem? Any suggestions on how to fix. Thanks.
#2 Posted : 09 December 2012 21:23:22(UTC)
Originally Posted by: wsscott Go to Quoted Post
Is this a problem?
Probably the centre rail pickup touches the rail (or the frog maybe). Which type of track? Which type of turnouts?
Make sure the pickup shoe is straight horizontally and vertically and parallel to the rails on straight track. Maybe it helps to reduce the pressure of the springs if it already is straight.
Offline Artologic
#3 Posted : 09 December 2012 21:33:53(UTC)
Artologic
Wsscott, do you use the very short pickup shoes, the very old ones? They tend to give problems too...
Kristof
#4 Posted : 10 December 2012 11:53:52(UTC)
Hi WS,
If you are using C track, I get this same spark effect on a few pieces of long wheel-base rolling stock.
In my case, it is caused by the back of one of the wheels touching one of the centre pukos (the centre pick-up stud). The particular puko is one that is closest to the rail. I can often solve this problem, by using a needle file.
I carefully file the side of the puko so it is not touching the back of the wheel as it goes around the curve. I find that a few tenths of a mm filing will do the trick.
#5 Posted : 10 December 2012 12:09:40(UTC)
make sure the gauge is correct, compare it with another carriage and see how far in the wheels are on the axle.
are you talking about a lid christmas car or one which respresents itself as one when driving over the turnout
Offline wsscott
#6 Posted : 11 December 2012 14:50:09(UTC)
wsscott
I"m using C-track. It only does it with this one car. The Christmas car has a pickup shoe and is lighted on the inside. You can remove the "body" of the car to access the inside stuff. The track is just a temporary setup around the tree and its on a tree skirt. The track seems to be connected ok, but it seems to spark at the transition where the track splits into the 2 directions. I guess I just don't want to do any damage to the car or its pickup shoe, the rail or somehow the engine or power supply. I didn't know if this sparking would affect any of those points.
#7 Posted : 11 December 2012 16:28:19(UTC)
Sparking is not a good sign, but can often be ignored if no other problems occur.
Curved turnouts, sleek turnouts, or standard turnouts?
Most trouble of this kind comes from curved turnouts, often the slider makes contact with the frog.
Does it spark both ways (left or right)? Maybe it helps to turn the car 180°.
Do you have left and right turnouts of this type? Does it spark on both types?
#8 Posted : 11 December 2012 16:46:22(UTC)
a photo from the underside would be an advantage for us to guide you in the right direction. it is obviously the pick up shoe and it needs to be looked at whether or not is centred, is level or has any other abnormal signs and this can be compared with another slider such from a loco.
#9 Posted : 11 December 2012 18:21:48(UTC)
I guess it´s wheels and mfx that causes problem.
I did had this problem with glaskasten which did sparks on the wheels over turnout when i did had first generation of Marklins new system.
#10 Posted : 12 December 2012 03:50:06(UTC)
The reasons of sparkings is that small locomotivs and wagons with pickup shoe makes models to lift up by passed over turnouts.
In this way it makes wheels bad contact on the rail and disturb.
Offline wsscott
#11 Posted : 12 December 2012 14:58:19(UTC)
wsscott
I think its probably because the car is light in weight and lifts up after it passes through the turnout. I'm trying to figure out how to attach to photos to this reply but not having success. Some help would be appreciated. You'll see the undercarriage of the car, which seems normal to me. Also the turnout. I have 4 turnouts in both directions and this car sparks on each of them regardless of direction of travel. You can see that right after the switch ends that controls the direction of travel, there is a dark piece of plastic in the center of the track on each turnout. It seems a bit higher than the rails. I think when the car passes over it, the car is lifted slightly and this causes the spark. I don't have this issue with the loco. I guess ultimately my question is whether or not this is damaging to anything in the layout? I'm not afraid of a fire starting, but don't want to damage the loco, the track, the car, or the power supply. Thanks for all your input.
wsscott attached the following image(s):
Offline BrandonVA
#12 Posted : 12 December 2012 15:27:27(UTC)
BrandonVA
Scott (is it Scott?),
I don't think anything is wrong with your turnout. Normally this sort of thing is more of a result of slider configuration. If you remove the locomotive from the track, set the transformer to an average speed (ignore transformer setting if digital), and slide the wagon by hand over the track, do you get the same result (sparks)? Does it happen in both directions? Does it make any unusual noise as it passes over the middle rail pukos? I can't say from the top of the slider in the picture, but I wonder if it's just out of adjustment a bit. You could remove and reattach it, just to make sure the seating is ok.
Regarding attaching images, these files are too big (in computer bytes) to be displayed in the post, they are good photos, they just need to be downsized for sharing on the web.
-Brandon
Offline wsscott
#13 Posted : 12 December 2012 15:46:09(UTC)
wsscott
Thanks. Yes its Scott. I'll check it out tonight and get back. I'll also see if I can shrink the photos.
Offline wsscott
#14 Posted : 12 December 2012 15:53:18(UTC)
wsscott
Here are the photos shrunken.
#15 Posted : 12 December 2012 16:21:06(UTC)
Scott, it clearly demonstrates, when you look at the slider, the wearing line is not centred, so your slider must be off centre buy correcting it you will find no more sparks.
As I've mentioned before, you have to thoroughly inspect the slider.
I can assure you it has nothing to do with the tunrout and Ia dvise you to take the slider off and inspect it. you can clearly see on one side (right hand) the slider had some arcing whereas the other side is clean.
Weight sometimes is an issue but very rarely if there is too much tension on the slider and yes the weight is minimal, it could occur.
you only can compare the sliders from carriage to loco but this will not fix the problem, everything else you possess, e.g. loos and other carriages do not show this sympton so we can with some confident, eliminate the turnout. Have you checked the gauge on this axle ? have you inspected the slider?
I hope this will help to get to the bottom.
Good Luck
Offline witzlerh
#16 Posted : 12 December 2012 17:12:59(UTC)
witzlerh
I agree with John. It looks like the slider is off center. I think what happened is that the slider got bent sideways. This is a common problem with packaging when you push your loks and rolling stock sideways into the package and forget to compress the slider.
I know that packaging of these cars are different. A good bend in the other direction would help.
Also, although it is rare with Marklin products, you should check the gauge of the wheels, perhaps they are narrow and cause the car to shift too much. Probably not enough to derail but enough for the slider to be too much to one side.
Looking at the picture, it also is not quite as parallel either. These little things, on their own, would not be much of an issue but each will contribute to the slider offset problem.
To check for wheel set gauge, pop the wheels out and set them on the track. There should be little side to side motion. Also compare to a good lok as the lok would have more detailed quality control. If the gauge is out, twist and pull wheel to gauge. Keep in mind that the distance of wheel to axel point should be as equal as possible.
To verify slider performance, swap slider with one that is a good performer. If issue is resolved, compare the 2 sliders and adjust if necessary. If this is too much, replace the slider.
Harald
CS2 DB & Canadian Era 3-6
Offline wsscott
#17 Posted : 12 December 2012 23:54:54(UTC)
wsscott
There does appear to be some slop in the wheels, such that if the car is pulling to the outside as it would with centrifugal force being applied, it results in the wear streak on the slider to line up with the pukes. So it seems setting the gauge might be what's needed. How do I adjust the wheels to widen the gauge. I dont want to break them off!! Thanks.
Offline witzlerh
#18 Posted : 13 December 2012 11:14:32(UTC)
witzlerh
To adjust the wheel gauge, take the wheel set out of the truck (bogie).
The wheel that you do not what to move, grab the wheel and the axel and hold tight.
The wheel that you do want to move, grab and twist. While twisting, pull a little to get it to move to place. If we just pull, it would slip right off so that is why you want to get the wheel moving while twisting and while twisting, you can make minute sideways shifts.
Harald
#19 Posted : 13 December 2012 14:14:34(UTC)
Scott,
I appologize if I sound a bit annoying but your agenda in the first place was: You've got a problem with your carriage.
Now I have and so have others mentioned a few options you can follow up but sofar haven't heard anything from you what you have done and what advice you've taken on board.
I know it easy for us to say, this could be the problem but unless you are serious, (I have no doubt that you are) but at the same time it would be a great step forweard for you and us and see where you at it.
I've mentioned before (and excuse me as I don't know your age and your overall capabilities) but this is also important to be honest and say look I don't understand what you're talking about.
Never the less we have come a bit closer to solve your problem.
the reason I've mentioned the gauge of the wheels (in my first post ) sofar I can see nothing much has attracted you to this option or possible problem.
I'm also a bit concerned about the observation you've obtained sofar.
The slider obvious has some arcing so I don't know why you are not persuing these 2 parts (slider and the gauge of the wheels).
Harald has mentioned why a slider can be bent accidently and sometimes the 4 leaves from the slider one of them may seperate from the slider baseplate but sofar I have had no acknoledgement what you have done or haven't done,
You seem to get bogged in with technical terms and what may cause the arcing, stick to the facts, the wheelgauge has to be right and this was also mentioned in my original post and secondly inspect the slider otherwise we can go on and on with out getting anywhere.
regards.,
Offline wsscott
#20 Posted : 13 December 2012 14:47:19(UTC)
wsscott
Sorry, but I thought my follow-up questions indicated what I had tried in response. I noted above that there is some slop in the gauge of the wheels, and asked how to adjust it, and received a reply. I haven't had time to try it yet. I will let everyone know the results. I tried bending the slider, but it didn't seem to make any difference since it still has some arching. So at this point I'm trying out the wheel adjustment when I have a moment. I would describe my level of sophistication and experience as "novice", that's why I think my questions seem to me to be fairly basic. However, I am an analytical individual and have experience in overhauling a car engine when I was 12 years old, have worked on BMW's off and on for 30 years, and I'm now 63. That's not my line of work however. I'll keep everyone posted on my success or failure with this issue.
#21 Posted : 13 December 2012 15:01:11(UTC)
Scott,
thank you very much of clearing up some of my queries.
the main aim of this game is to persue a goal by investigating it fully, by just merely bending the slider can do more damage than good. it has to be taken off. the gauge as mentioned before has to match other wheels either from an electric loco or a reliable carriage.
You've talked about a slop in the wheels or axle, this is no indication theat the wheel gauge is out, you have to physically compare it with another set of wheels, than you can be certain yes this axle has more movement it should have.
I think too it is a combination of 2 factors., a.) the wheelgauge, b.) the slider.
Good luck
regards.,
Offline wsscott
#22 Posted : 16 December 2012 15:55:57(UTC)
wsscott
I appreciate everyone's time, input and patience with this issue. I finally had time and took the wheels off the car this morning and compared the gauge with the loco's gauge and they appear to be the same with no need for adjustment. They just line up with each other. I also took the loco off the track, and just moved the lighted car by hand, and as the car comes into the turnout it rises up a bit going through the 2 turnout rails regardless of the direction the turnout is set to, and then as it comes out of the twin rails in the turnout the spark occurs. It doesn't occur if I'm pushing the car by hand, but only if the loco is pulling it. It does this for each of the turnouts, regardless of direction. I also turned the car around to see if its direction mattered, but it doesn't. The slider is solder wired to the lighting board inside the car, so its not as easily replaceable as with other sliders. I tried to lightly bend it, and it seems to be more centered over the puks, but hasn't solved the problem. And as I said it only does the sparking at the turnouts and after the car has passed through the turnout. Everywhere else in the layout it doesn't spark. I still think it has something to do with the weight of the car since when it has light pressure from my hand moving the car through the turnout it doesn't spark presumably because it maintains its contact with the puks, and the only place in the layout where the cars rises up is when it goes through the turnout. So much for my analysis.
Offline Nielsenr
#23 Posted : 16 December 2012 19:07:41(UTC)
Nielsenr
A while ago I was running a long American freight car consist behind one of my BigBoys. The train would stop and then start up again. I finally saw some sparking at a turnout and starting watching it very closely. I found one car that would spark at the turnout that would result in the train stopping and then starting again. I took the car in question off the track and observed that the couplers were not free in their movement which was causing the car to be pulled at an angle thru the turnout, almost trying to pull it off the track. It ended up that the frame of that particular freight car was warped so that it did not allow the couplers to move freely left and right. I don't know if this is your problem but it is something to check.
Robert
#24 Posted : 16 December 2012 20:33:11(UTC)
Looking at the photo of your switch track, I noticed that the first pin on the outer side of the tracks seems to have been a little bent/twisted.
As suggested by some other members, the wear marks on the slider seem to suggest uneven wear.
I am going to ask you for some additional information:
1) Does the car spark when travelling on only one of the two tracks, i.e. only on the outer track or only on the inner track?
2) Does the car spark when travelling in either direction, or only when passing in one direction?
2) If you remove the car and set it back on the track in the opposing direction, does the problem still occur?
Take the car (on it's own) and run it manually along the tracks. Observe whether the spark is coming from the wheel or from the slider.
Rotate the car 180 degrees and try the same again. Is the spark always coming from the same spot on the car or does it change when the car is rotated? (i.e. the spark is always at the same place on the slider or is it, say, at the leading edge of the left side of the slider no matter in which direction the car is positioned).
Some lighter cars may slightly tip in curves, which can cause sparking or shorts on crossings, switches or contact tracks when those cars are equipped with sliders. This happens especially when lighter cars are placed in front of heavier cars to the rear. To test if this is part of the problem, simply change the positioning of the car in the consist or test with that car alone. You can reduce the risk of this type of problem by adding a little weight to the car or using it at the rear of the consist/rake.
On older M and K tracks, the pukos are a little higher compared to the C Track ones. This may make it more likely that cars will have issues on the newer track as the slider is not lifted as much as it was on older designs.
#25 Posted : 16 December 2012 23:11:16(UTC)
And as I said it only does the sparking at the turnouts and after the car has passed through the turnout. Everywhere else in the layout it doesn't spark. ....
Hi WS,
For the spark to occur, just one of the wheels has to touch a puko (centre-stud), or the slider has to momentarily touch the outer rail (ground).
Can you observe closely when this spark occurr, perhaps by having the car very slowly pulled by the engine. Then you might be able to see exactly when/where the spark occurs, as you say the spark happens "after" the turnout (by that you mean frog of the turnout?). Of course sometimes the speed can effect whether it sparks or not, so you might have to try a few times.
This page was generated in 0.782 seconds.
