Offline Sandyford
#1 Posted : 01 December 2012 18:55:49(UTC)
Sandyford
I have just extracted my Marklin equipment from long-term closet exile and set them up on a permanent layout designed around the Tannenbaum. After a little breaking in, the track is fine and my two digital locomotives, 37xx, run fine. Most of the stuff even stays on the track.
BUT ... my old-time favorite of all toys, my 3514, doesn't respond to commands. Here's what I know:
The decoder is set to 02
The lights go on and off with the function switch
After disassembly, the motor works fine with a 9V battery lead
The controller bit switches are all 'off'
No wheels are binding - everything turns freely
There are no cracks or loose wires in the controller. Having determined that the blue and yellow wires powered the DC motor, I touched the leads where they were soldered to the decoder and presto it seemed to move readily
And here's what I think:
That decoder / rectifier board looks expensive and hard to get.
Any ideas from anybody???? I love these trains - and I don't want to trash the decoder. I'm hoping that I'm doing something wrong. The instruction sheet is long gone.
Thanks!!!!!!!!!!
Sandy
Offline Yumgui
#2 Posted : 01 December 2012 19:04:33(UTC)
Yumgui
Hi Sandy, and welcome to the forum ^^ !
While I have no knowledge of the decoder issues this loco may have, I can only upload the exploded diagram ...
Hope it helps,
Y Cool
File Attachment(s):
3514_explo.pdf (150kb) downloaded 80 time(s).
Offline Ian555
#3 Posted : 01 December 2012 19:07:15(UTC)
Ian555
Hi Sandy,
Welcome to the forum. ThumpUp
Ian.
Offline Sandyford
#4 Posted : 01 December 2012 19:44:33(UTC)
Sandyford
Hope it helps,
Y Cool
Wow - Thank you! I hope you're enjoying Paris!
Offline Yumgui
#5 Posted : 01 December 2012 20:43:23(UTC)
Yumgui
Sandy,
Born in LA, raised in NH, and living in Paris ... goin' east, so far so good ^^ ThumpUp
Plz let us know how your "extracted Marklin equipment from long-term closet exile" is going ... ^^
Yum Tongue
Offline arconell
#6 Posted : 02 December 2012 00:33:40(UTC)
arconell
Hi Sandy,
You said that the (delta) decoder address is set for 02. You go on saying that the "controller bit switches are all 'off'" Assuming the controller bit switches are the 4 dipswitches on a little block on the board, than it is either one or the other. For digital address 02 you need to set the following: 1 = 0n, 2 = off, 3 = off, 4 = off
Here is a list of all 15 addresses available in Delta decoders with their settings: http://www.pallund.dk/deltaadd.htm
Hope it works out under the christmas tree,
Robert
Offline Sandyford
#7 Posted : 02 December 2012 07:37:15(UTC)
Sandyford
Originally Posted by: arconell Go to Quoted Post
Hi Sandy,
Robert
Thanks Robert. This locomotive appears to be a little unusual, from what little I know. It has a DC motor, and a six-bit decoder set to address 02. The decoder is part of the electronics in the tender. The other stuff in there must be some kind of rectifier because of the DC motor. There are analog versions of the 3514 and I don't know how to differentiate them when looking for information. Something in the DC motor controller just isn't working. That's what stumps me, and I don't know where to get a new decoder board with the rectifier necessary to run this motor.
Anyhow, this locomotive used to run just fine, and it does partially respond to commands from the condroller sent to address 02. So, I don't think it's a Delta decoder. And, like I said, the motor runs when I 'jump start" it with a 9V dry cell.
The controller dipswitches I'm speaking of are on the digital controller that hooks up to the transformer. They're all off. I think they always have been off.
Anyhow, thanks for your reply. This forum looks like it's going to be a lot of fun.
Sandy
#8 Posted : 02 December 2012 09:48:27(UTC)
Hi, Sandy!
All 3514 should have been analogue "ex works", so I presume yours has been modified. Or maybe it's a 3614 (both have the operating number 2004), but that should have 8 DIP switches on the decoder.
Maybe it's a 6080 decoder - and the transistors that control the lights are still working, but maybe the transistors for the motor have died (or a wire broke off).
Offline Paul59
#9 Posted : 02 December 2012 10:56:43(UTC)
Paul59
Hi Sandy,
If it worked when you touched the solder joints on the motor leads/decoder then it would suggest a 'dry' solder joint. This is unusual but not unheard of.
Depending on your soldering skills you could try remaking the joint - but be extremely careful especially as there are often other solder joints very close.
Paul
#10 Posted : 02 December 2012 11:15:25(UTC)
The 3514 is indeed analog, so it could have been converted with a 3611/3611 board in the tender.
These old 3611/3614 have a chip called LME03, which is an ancient piece of silicon. It only recognizes the original Märklin-Motorola protocol.
I did an investigation many years ago regarding the switches back on the 6021 controller, see https://www.marklin-user...tal/6021dipsettings.html
Offline Sandyford
#11 Posted : 03 December 2012 05:08:46(UTC)
Sandyford
Thanks. It came to me, brand new from a hobby shop here (since gone), in a box that said "3514". But there's a decoder on the board in the tender. And I remember it being rather expensive at the time, too. The conversion looks to be factory fresh, and it operated for several years up until sometime after I stored it. Do you know if the factory sold the 3514 with the 3611 conversion already installed? Hmm. Thanks so much for your information. I'll go and research the 3611 conversion to see if I can perhaps find one to install in the tender. The motor appears to work. I'll take a picture of the board sometime soon and perhaps you'll recognize it if I send it to you.
Thanks again.
Sandy
#12 Posted : 03 December 2012 07:08:46(UTC)
Hi Sandy
Definitely... a picture of the whole thing would help solve the riddle!
I'll be looking for it.
Till later!
Offline Sandyford
#13 Posted : 04 December 2012 07:37:26(UTC)
Sandyford
Hi Sandy
Till later!
Well, since I'm new here, I haven't figured out how to post a pic yet. BUT .... there are three high resolution pictures in my online gallery. The board is indeed marked 3611, so I'm starting to understand that I don't have a 3415 as stated on the box. Funny thing is though that the box says 3415 AND it indicates with a red imprint on the picture of the tender that the whole thing is digital, and that's what came in the box.
The locomotive running number is indeed 2004.
So, if it's a 3611 decoder, how might I get power to the motor???
The pictures are at this link, and thanks so much for any help: http://sandyford.smugmug...415-3615/26885154_8ZB8xt
#14 Posted : 04 December 2012 20:19:29(UTC)
Well, the decoder clearly states "3611", so it seems like my guess was spot on...
The soldering of the wires certainly also show some "layman" signs, so this is converted from a 3514 to "3614" indeed.
The driving wheels of this loco should turn really lightly compared to other M models, so if you very gently try to turn the wheels - they should turn easily.
If they don't, you may have the same problem as I had with my 3511 (converted to "3611") - a stuck gearbox...
I had some dirt & stale oil in the gearbox (wheels not turning freely), but that was fixed by cleaning it up. I even disassembled it...
If the wheels turn quite freely as they should, the motor could have died or the motor power transistors have died due to a shorted motor...
The motor is a Faulhaber 1319, which I believe is still available from SB-Modellbau...
You can add pics by pressing the "Attach" button to upload pics to your posts...
Offline Sandyford
#15 Posted : 04 December 2012 22:55:33(UTC)
Sandyford
Thanks. The motor seems to work. Your input very much appreciated. The 'layman' soldering wasn't apparent to me but that solves the mystery. There is a board I can replace - I found the part number someplace - would you suggest a place to order it???? Thanks!
Offline eduard71
#16 Posted : 06 December 2012 03:28:07(UTC)
eduard71
Chile
Hi Sandy,
This board is one of the early ones and works like a 6080 but it is specially tuned for the Faulhaber motor that this loco has. If you are going to change the board you will be surprised with the price (about 214US$) See this ebay listing:
http://www.ebay.com/itm/...&hash=item35c097cc15
A better and also cheaper solution could be buying the Luessi Hobby solution, which is a board specially made for this locomotive that allows you to connect any kind of decoder with a 8 pin connector, you can add for example an ESU decoder multiprotocol or MFX and the results will be very good, the board plus the decoder should not be more that 70$+shipping.
http://luessi.ch/shop/ca...ath=2&products_id=54
Hope this helps you repairing your locomotive.
Eduardo
thanks 1 user liked this useful post by eduard71
Offline Hoffmann
#17 Posted : 06 December 2012 04:21:42(UTC)
Hoffmann
Hello Sandy,,
Have you tried setting the Decoder to a differend Address?
Martin
marklin-eh
Offline Sandyford
#18 Posted : 07 December 2012 00:40:51(UTC)
Sandyford
Originally Posted by: Hoffmann Go to Quoted Post
Hello Sandy,,
Martin
I tried a few different ones, same outcome. Thanks though.
Sandy
Offline Sandyford
#19 Posted : 11 December 2012 01:51:35(UTC)
Sandyford
Hello Sandy,,
Martin
Sandy
Thanks to all of you - I gave up and sent the locomotive in for repair. Sure enough, the decoder board has failed. I should have it back soon and I'll post a picture!
thanks 1 user liked this useful post by Sandyford
Guest (11)
This page was generated in 0.541 seconds.
