Offline wsscott
#1 Posted : 03 December 2012 18:36:30(UTC)
wsscott
I"ve got 2 digital locos, the Tristan with the King Ludwig set and the #33041. The Tristan doesn't have any traction tires on it, but they are shown in the booklet on how to install. The little 33041 has a set on the rear 2 wheels but not on any others. Are they supposed to have them, and if so are they supposed to be on all the wheels or just certain ones? If so, where do you find a wrench that will fit the bolts? Thanks.
Offline Ian555
#2 Posted : 03 December 2012 19:20:39(UTC)
Ian555
Views messages in topic : 20,302
Hi wsscott,
Welcome to the forum. ThumpUp
Ian.
Offline wsscott
#3 Posted : 03 December 2012 19:31:00(UTC)
wsscott
Thanks. I"ve been on it in the past, but it looks like I had to register again with the new website.
Offline Western Pacific
#4 Posted : 03 December 2012 20:19:20(UTC)
Western Pacific
Hi wsscott.
Even if I don't have the 33041, I wouldn't think that more than one axle would be equiped with traction tyres in order to get proper contact with the track for current conduction purposes. The 3000, which is a similar size model has only got traction tyres on one axle.
Anyhow, have you taken a look at the Märklin tool kit 70900?
I'm pretty sure the hex sockets of that tool kit would fit most, if not all, Märklin models that need them.
#5 Posted : 03 December 2012 21:34:30(UTC)
Hello WSSCOTT
I have the King Ludwig train set with the "TRISTAN" loco and the "MÜRNAU" Loco (Märklin item 3797). Same loco, different tender, different electronics (TRISTAN is 36XX unregulated, MURNAU is 3797-regulated).
They both have traction tyres on both driving axles on both sides (at least on the 3 rails versions)
Here is a picture of the MURNAU:
Both need #7153 traction tyres.
Change is made by:
- poping out the cran pins on both side and both axle
- removing the underneath of the loco to remove the axles
- change the tyres
- when refitting the 2 axles make sure they are "in sync" so that the crank & rod operation is fine.
Here are pages 16 and 17 about changing tyres on this loco:
Sorry about images not properly scanned & vertical.
Cheers from Paris
Offline wsscott
#6 Posted : 03 December 2012 21:41:18(UTC)
wsscott
Great--Thanks for your help.
#7 Posted : 03 December 2012 22:10:38(UTC)
Hi Wsscott,
Offline charles Sharpe
#8 Posted : 04 December 2012 04:45:30(UTC)
charles Sharpe
Hello Wsscott.
CHARLES SHARPE
Offline wsscott
#9 Posted : 13 January 2013 19:31:54(UTC)
wsscott
Jean- I finally am getting around to the tires. I got the tool kit for Christmas. I've taken off the bottom plate, but can't figure out how to take out the crank pins. Can you help. I also notice that the wheels and the cranks don't line up as shown in the photos. Can you show me or describe the proper alignment? Thanks.
#10 Posted : 15 January 2013 15:34:09(UTC)
Hi Wsscott
- Removing the crank pins is easy: just pull them gently with a pair of tweezers, parallel to the axle and away from the wheel.
- Aligning wheel is also easy: while no crank pins are in place, insert the wheel pairs so that their wheight are oriented toward bottom (on one side) Look at the picture below.
Wheel Alignment
Attention: do not try to rotate the wheels when they are sitting "home" because of worm gear. When a wheel pair is not aligned, just pull it out and rotate it slightly before reinsertion.
Offline wsscott
#11 Posted : 15 January 2013 15:52:05(UTC)
wsscott
Thanks-I don't think I can get my tweezers on the pin to pull it. I gave it a try but this pin is really small. I'll keep working on it. Thanks.
#12 Posted : 16 January 2013 11:36:49(UTC)
Hi Wsscott
In case the cranks are sticky, you may force them out (gently) with either a little screwdriver or an Xacto blade inserted between the crank arm and the lok's side frame.
This page was generated in 0.420 seconds.
