Offline viragoLDR
#1 Posted : 14 November 2007 11:23:36(UTC)
viragoLDR
I've recently received the first parts for a 1:24 scale all brass/cast iron building kit I'll be building over the coming years. Just gathering the parts will take about 2 years alone, and then there's the building and painting etc. I will keep a report on the whole thing once I get started, which probably won't be until I have a lot more parts.
Anyway, since the kit is all metal, several of the main parts are screwed. However, all the small parts and even those screwed ones will need to be glued. For this I need 2 types of superglue, one that's really thin flowing and will get into all the little cracks, and a gel type superglue that I can smear on larger parts and takes a while to dry.
Neither of those are a problem to get, Faller for example makes both types, as do several hundred other companies. However, most of them leave white spots when dry, which is something I'd prefer not to have happen.
Any tips for superglue that dries up clear, and which is easily available in Europe? (more specifically, Norway, or possibly Germany or The Netherlands)
Thanks ;)
- Martijn
#2 Posted : 14 November 2007 13:16:38(UTC)
Hi Martijn
For the time being my liquid one is Tesa Lynlim, a Danish product available in all kinds of stores. I have not seen any white marks after drying up.
For the gel type, I don't remebmber, as I just threw it away, empty. Also bought in a normal store, like Jernia or Maxbo.
I do remember that it left no white traces.
Locktite normally makes good products, so does Tesa and Casco and probably many others.
Offline viragoLDR
#3 Posted : 14 November 2007 14:42:17(UTC)
viragoLDR
Thanks for the tips. The manufacturers of the building kit actually recommend certain types of Loctite, but I haven't been able to find those specific ones. The only ones I found were those that turn white when drying up, which doesn't look good. I'm not sure it matters that much really, since I'll be painting the whole thing anyway, so it might be covered, or I might be able to sand off the excess glue. Better safe than sorry though =)
- Martijn
Offline frankie
#4 Posted : 14 November 2007 15:25:56(UTC)
frankie
You may want to look for Zap products here:http://www.hannants.co.ukthere is also an accelerator which comes quite handy when you are gleeing different media.
Alessandro
I have a CS1 Reloaded!
Offline Pianne
#5 Posted : 15 November 2007 22:34:47(UTC)
Pianne
I have used the zap glue and the "zap-kicker" accelerator spray. It sticks very well and very fast, but the kicker fumes are worse than smoke oil!
Kind regards,
Pieter-Jan
Bruges, Belgium.
This page was generated in 0.217 seconds.
