Offline drstapes
#1 Posted : 02 November 2007 23:57:42(UTC)
drstapes
Has anybody converted a Marklin Hamo 2 rail loco to 3 rail AC?
wondered how difficult this would be.
Geoff (UK)
#2 Posted : 04 November 2007 00:25:32(UTC)
Geoff,
I am in the middle of doing one. THere are some things to watch. IF there is no cover between where the slider springs and wheel axels you have to either put an insulation on axles of buy the AC Bogie. (about 6 to 9 euros).
If fitting a Decoder check the Light wiring specially if it is using body as the earth return.
Apart fromm that I do not think there is much else. being Hamo you already have a DC Motor. (Ps I blew a decoder as the Slider shorted out on the Axles.)
Nev
Offline jorge_vilarrubi
#3 Posted : 04 November 2007 12:00:36(UTC)
jorge_vilarrubi
Hello Geoff,
I've converted several Hamos for my customers. The common problem is the loss of contact from the rail in touch with the insulated wheels, normally those with no gears.
Hamos have a sort of pickup which takes current from one of the rails and has to be replaced by the central pickup shoe. Therefore, you loose ground from half the wheels.
This is really important when you have isolated rails for track occupancy detection.
In some cases, insulated wheels have to be replaced by non-insulated ones.
Regarding the lights, just remove the circuit containing a couple diodes and connect the lamps in the "normal" way: gray to fwd and yellow to bkwd.
Best regards from Buenos Aires,
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline Falconrep
#4 Posted : 09 November 2007 18:26:20(UTC)
Falconrep
What Lokpilot decoder would I want to buy to do this for operation with a Marklin 6021 Digital Control?
An ESU 52610, 52612, 61600 or 52690 Basic V 1.0?
Thanks in advance
Thomas Wondrock
#5 Posted : 09 November 2007 19:43:44(UTC)
jorge_vilarrubi
Hi Tom, you need a decoder which supports Motorola protocol/data format.
52610, 52612 are Motorola compatible.
61600 is both Motorola and mfx compatible. If you plan to migrate to CS, it could be a good (and more expensive) choice.
52690 is DCC only, not usable with any Márklin digital system.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
This page was generated in 0.258 seconds.
