Offline James
#1 Posted : 05 September 2012 14:15:05(UTC)
James
Hello All:
I am posting this question to the forum in the hope that I might get a solution to a digital problem I am currently experiencing.Confused
I recently purchased a couple of the "My World" red/green aspect home signals (#74391), thinking that when I go to set my layout up for computer control and therefore not needing any direct (analogue) locomotive control with the signals, that this would be a relatively inexpensive signal solution. That is... they would look the part, but they would not actually cut off any power to the track, and that it would be the computer (through a control program) that would actually start/stop the locomotives. Price wise (approx $15.00), they are the perfect fit.
However, as I have found many, many times, nothing in life is that simple... and... I have run into a "glitch" that I was wondering if any members of this forum have previously encountered.
Okay, this gets a little complicated so please ... bear with me. Huh
The signals have two (long)wires running to the actual signal mast, one dark blue and one a lighter shade of blue. These wires are matched up with a third wire which is red. The red wire does not actually attach to the signal Mast, but it is clipped to a plug along with the two blue wires, which in turn are attached to a "My World" control box (#72751). The red wire has a spade connector at it's other end which is intended to be attached to the third rail (or power lead) of a 'C' track piece somewhere on the actual layout. At the other end of the control box you run a small (3 inch) cable to be connected to a starter set control track piece (#??????), the older versions were numbered #24088. All of the plugs coming out of the control box (both those going to the signals, and the return to the 'C' track control track piece appear to be four circuit plugs. That is, there are four "female" type adapters which in turn attach to four "male" ended holes in the control box.
Unfortunately, Marklin in their infinite wisdom elected to change the control track connector box from the older round plugs to a square plug. They also elected to make the connection wire from the signal control box to the control track about 3 inches in length. Definitly intended to be used on a carpet type layout setting. In their pictogram instructions which come with the control boxes, they elected not to identify this cable.
At this point I would be willing to use said signals as they were intended, however, the control track with the newer square connection hole is not sold as a separate item (at least to my current knowledge) and... the company does not offer a longer connection cable. They do not even offer a part number for the 3 inch connection cable so that I am unable to inquire about extensions.
I have thought about trying to use my older control boxes, however, when I go to wiring the signals they only way that I can get them to light up is to take each wire from the signal (light and dark blue) and attach them to the third rail and ground circuit respectively which cause both lights in the signal to light up. however, there is no control either off or on except to attach or un-attach the wires, all of which just kills any power to the light.
I guess my biggest question right now is...does any of this make any sense to anyone? Would anybody have any suggestions on just what my next move should be?
Either way... thanks for taking the time to read this Mellow
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
#2 Posted : 05 September 2012 15:06:38(UTC)
Hi James,
I'm struggling to understand your problem. Is there a mismatch between the plug which comes with your 72751 control box and the power feeder track 24088? You say they changed the type of socket in the 24088 feeder track and your cable no longer fits?
Maybe you could post some photos so we can see the problem better?
#3 Posted : 05 September 2012 15:10:17(UTC)
Here's a page from the German Märklin Magazin:
http://www.railroad24.de...94333-09062820122250.pdf
If you cut of the plug, please note that "due to technical reasons" the wire colours do not match the standard colour scheme.
Hobby signals need the resistors inside the 72750/1 control boxes - normal control boxes will do harm unless you add resistors of your own.
A 72750 control box would do (but not available at the factory).
Offline James
#4 Posted : 05 September 2012 15:54:49(UTC)
James
Thanks for the information guys.
Tom pretty much summed it all up with the page from the Marklin magazine. I wasn't aware of the information regarding the resistors, and I will look into that. Thanks for the advice, would you be able to tell me the month and year of the magazine so that I might be able to track an English copy? I am not planning to attach the signal in any way to my lay out, I am just looking for a way to change the signal aspects.
Ray, you are correct about the change in plugs and track pieces. The new control tracks (formerly the 24088) as far as I know, is only available if one purchases a new start set or a My world set. The plugs are square and will not fit into the older 24088 track pieces.
Basically, all I wish to do is to find some way to control the red/green aspects of the signal. As I said before, If I operate my layout with a computer program (such as Rocrail) I will not need to have the signals control the stopping or starting of the locomotives as that will be done via the computer. The signals are primarily for show.
This is really helpful information guys, I really want to thank you (as always) you guys are the best.
Sincerely
James
James Bannerman
#5 Posted : 05 September 2012 17:55:19(UTC)
James, I'm glad you've found some useful information. I, on the other hand, am more confused than when you started the thread.
Are we saying that it is impossible to buy hobby colour light signals and make them work with the products currently on the market?
I noted that there are two generations of control boxes. The 72751 replaces the earlier 72750. What is the difference between these?
Maybe someone could shed some light on this problem, because I was actually considering getting some of these signals, but now I don't know how they would connect to the layout.
#6 Posted : 05 September 2012 18:00:48(UTC)
Hi, James,
I was wrong about the resistors.
Henning Voosen published plans to use the signals without the M* control box:
http://www.henningvoosen...e/Insider/Index_Tips.htm
Scroll down to "Anschlussbeispiele für märklin-Hobby-Signale"
Sorry, German again - but the schematics may still help.
#7 Posted : 05 September 2012 18:08:13(UTC)
Hi, Ray!
With MyWorld (72751) they introduced a new system: a four-pole cable runs from the track box to the first control box and to the next control box and so forth.
There are control boxes for signals and control boxes for solenoids. All plug and play.
These four poles include track power (that signals will switch off) and "power" for solenoids.
With the 72750 you did the wiring yourself with those small plugs.
Offline James
#8 Posted : 05 September 2012 20:01:00(UTC)
James
Diagram
Ray:
Here is a simplified diagram showing the wiring set-up, should you choose to use the original configuration for the signals. The cable with the label "Unknown" is the four pole connector. As I stated before, this cable is in reality approximately 3.5 inches long. If you follow this to it's logical conclusion, you have to have the control box (#72751) placed about 3 or 4 inches from your track. I do not know what the cable part number is, and as such, cannot order a longer version from Marklin. Someone might try to splice into it to extend it so that you could place the control box further away. The other difficulty is that in it's current configuration you have to use the 4 pole connectors and the connector track, which is not available separately at this time. I believe they must be included with the latest "My World" starter sets or any of the newer starter sets, but I don't know. I hope this helps shed a better light at the problem. Tom's information seems encouraging, however, I will have to find a translator before I can further determine what to do. I will try to browse past issues of the Marklin Magazine (english versions) to try to find this information. My dealer has the past issues and so I now have something to go on.
P.S. One thing that I did not include in the above diagram was a separate red wire which connects from a couple of sections before the signal to a couple of sections after the signal. Much like the older analogue signal set-ups, however, I am not going to be using the signals to control my trains.
Thanks again guys
Much appreciated
James Bannerman
thanks 1 user liked this useful post by James
#9 Posted : 05 September 2012 20:22:39(UTC)
Thanks James,
I've recently invested in a MS2 from a starter set, and the track connection box it brings, the 60113, only has three connectors, two for MS2s and one for power, so I can't see how these signals may be used with a starter set containing an MS2 and this type of connection box.
Next time I'm in a Marklin dealer who has the My World range I'll ask them about it, but for now I think I'll stick to the Viessmann signals.
#10 Posted : 05 September 2012 20:41:11(UTC)
I don't have time to translate the complete article, but will try to answer questions if you have some. I don't know from which issue the page is.
Ray, the #60113 does not have the four-pin connection for the new control boxes.
James, extension cables are available:
71054 Extension Wire (4-conductor).
71053 Extension Wire (3-conductor).
#11 Posted : 05 September 2012 23:25:45(UTC)
For the 74XXX signals there is a box available that converts them to digital signals that can be programmed for the MS2, CS2 and ecos.
I will look up the supplier later and post the name.
Found it. Ebay Seller : dr.pannek
Item :
Signaldecoder f Lichtsignale kompatibel Märklin digital or
or:
Signalmodul, Bremsmodul kompatibel zu Märklin - Digital
Nev
http://www.ebay.com.au/i...&hash=item51a08da4db
Aesthetics of Marklin hobby signals on a software-controlled layout (Digital)
by johnpatrickwack 13/02/2018 20:51:03(UTC)
This page was generated in 0.770 seconds.
