Offline HFEVO2
#1 Posted : 26 August 2012 15:07:17(UTC)
HFEVO2
I've just joined the forum because I have some Marklin Gauge 1 kit and I would really appreciate a little advice.
In HO I have two rail DCC using Lenz equipment which works really well but I seem to be having some problems with some Marklin Locos and a Mobile Station ( the first version No 60652 which came in a bargain price start set with a Br89 ).
The two locos in question are 54561 ( Br18.478 ) and 54562 ( Bayern S3/6) They are identical mechanically and, I imagine electronically and are fitted with 519093 decoders and sound ( not MFX ). I've had them as static display models for a long time but I'm now looking to semi retire and build a garden railway.
From the factory they are both set at address 18 so I knew I needed to change the address on one in order to program both into the Mobile Station at the same time. Selecting the first one from the database, the right loco name comes up and shows address 18. It moves, the lights work as does inertia but the sound doesn't. Tried the second loco, same result.
I then followed the instructions for the mobile station carefully and tried to reprogram the S3/6 to 36. The Mobile station then correctly showed it as address 36 but changing the 8 switch dipswitch panel to 1 3 6 & 8 ON made no difference : It still worked only on 18 and no sound !
Repeated the exercise with 54561 but the same result.
Irrespective of the 8 dip switch settings, the locos move only when the Mobile Station is set on address 18. With the dip switches also set for 18, the brake block symbol appears as does smoke and the whistle. Inertia is working as are the lights and both can be switched off but although the symbol changes when pressing the whistle button, there is no sound.
Sound is working fine on a T3 and Br89 so it's not the mobile station.
In the tenders both have an upper and lower circuit board, the lower one has a 10 dip switch panel and a slide switch. I haven't moved any of the 10 switches ( I assume this changes sound settings as everywhere I look including the Mobile Centre manual says there are 8 dipswitches to set the addresses ). The slide switch seems to do nothing.
Can anyone tell me what the settings should be on the 10 dip switch panel ? I can't find it anywhere on the net.
I don't have any trouble with a much more complicated Lenz setup but am I doing something really stupid with the Marklin ?
Thanks in advance !
HFEVO2 attached the following image(s):
#2 Posted : 26 August 2012 15:30:29(UTC)
Can a ms1 power a one gauge loco?
Offline HFEVO2
#3 Posted : 26 August 2012 15:35:19(UTC)
HFEVO2
Yes, it came in a start set with a Gauge 1 Br98 tank loco, two wagons and track.
The Br 18s both have only one motor so they work fine with it.
I doubt whether it would run more than two locos - or three at the very most.
thanks 1 user liked this useful post by HFEVO2
Offline Markus Schild
#4 Posted : 26 August 2012 17:28:31(UTC)
Markus Schild
I did two snips out of the manual:
What the switches do:
The adresses:
Markus
Offline HFEVO2
#5 Posted : 26 August 2012 19:36:26(UTC)
HFEVO2
Thank you very much Marcus.
I can't find the little manuals for the two locomotives but everywhere I looked, including the mobile centre manual, only showed 8 address switches, not 10. That was very misleading as naturally I thought the eight set the address, not the ten !
Your table has therefore been very helpful. Also the drawing showing what the potentiometers do.
I had already lost the settings by altering the 8 dip switches that control the sound but fortunately , a friend has just sent me these so with the help of both of you the locos are both working fine and with sound !
For completeness, as a record for anyone who needs the information, the eight sound dipswitches for both Marklin 54561 and 54562 should be set to :
1 = on
2 = on
3 = on
4 = on
5 = off
6 = off
7 = on
8 = on
Once again, many thanks !
Chris
PS
If I eventually want to convert these to DCC with sound, do I have to replace everything or just the basic decoder board ?
#6 Posted : 26 August 2012 21:32:55(UTC)
Not into 1-Gauge myself, but I suspect some things are common with H0..
Short version - all decoder electronics + speaker should be replaced.
Longer version - The sound decoder is a Märklin one and if you change the basic decoder board, the sound piggyback module will not work. So you will need a new sound module for the DCC decoder too, or use a DCC decoder with sound capabilities as eg the LokSound XL. However, the speaker may not have the correct impedance to work with eg LokSound XL and may have to be replaced too.
Offline HFEVO2
#7 Posted : 27 August 2012 00:44:59(UTC)
HFEVO2
Thanks but Ouch !
That would make it very expensive to do.
The speakers in the Br14.478 and S 3/6 are 7cm diameter, 4 Ohm impedance and rated at 3w. They look very cheap items made in Malaysia so I guess they would be the first thing and least expensive items to upgrade.
#8 Posted : 27 August 2012 04:58:04(UTC)
Views messages in topic : 18,778
Keep in mind that the booster unit that comes with the MS2 has 2 versions - 60113 is for H0 and has a 1.9 amp output current, and 60112 for 1 Gauge, which has a higher output current for 1 Gauge locos (can't remember the exact current rating). You should check which version you have, as if you have the wrong one, maybe your large 1 Gauge locos are simply not getting enough power.
#9 Posted : 27 August 2012 05:01:05(UTC)
Possibly, but you would need the 1.9 amp version as a minimum. But since some of the larger 1 Gauge locos require more than 2 amps of power to run, even that may not work.
Offline HFEVO2
#10 Posted : 27 August 2012 10:30:29(UTC)
HFEVO2
In an earlier post I did say that I bought a Gauge 1 start set which included the Mobile Station so it has to be a version built for the larger locomotives.
I haven't previously looked closely at it but I see that the transformer is rated at 3.75A ( 60VA ). Naturally it's much heavier than the HO version.
It certainly has enough power to move both Br 18s which are 4-6-2 express locomotives and the 2-6-0 Br89 from the set at the same time.
The set is number 55036 "Freight Train Digital Starter Set" and I've added a picture of the contents. It was very good value : The loco has full MFX sound and has operating couplings both ends, three goods wagons and an oval of track complete with a siding and buffers.
Two friends and I bought three sets between us and obtained a very good deal : Each cost us around €750 all in, I think. But this was some years ago !
For more than 25 years I've been buying most of my Railway items from Matschke Modellbahn in Wuppertal.
The current owner is Carsten Laag who speaks excellent English and is very happy to ship items abroad and help with repairs.
Items always arrive very well packaged. Carsten has excellent levels of new stock and well priced secondhand items in all gauges.
You can sign up for his Friday evening weekly newsletter at http://www.matschke.org/ and his email is info@matschke.org
#11 Posted : 27 August 2012 11:22:03(UTC)
Ah, OK, sorry for the mistake. I had wondered whether you had got the 55035 starter set with MS2, since you mentioned you had Br89, which I thought 55035 included. 55035 actually has a Br80, and the loco in your set has a Br91.
However, my comments about low power still stand. The MS1 in your starter set has a maximum output of 1.9 amps. The fact that you also have a 60va transformer makes absolutely no difference to the final output of the MS1, as the MS1 is limited to 1.9 amps. Feeding it with a larger transformer will not make any difference. It just means that the transformer will not run out of gas! Marklin included this controller in cheaper 1 Gauge starter sets to keep costs down, but that does not mean it is intended to or will power larger 1 Gauge locos.
I would try and see if you can find someone with a Marklin CS1/CS2 or ESU Ecos that you could borrow to try for a few days just to be sure that power is not an issue. Either that or get hold of a MS2 with 60112 booster (your 60va transformer will be great for this). Maybe your local dealer could help you out. 1 Gauge locos are notorious for using up power, which is why our Marklin club here in NZ uses 8 amp boosters on our club's 1 Gauge layout.
Thanks for the dealer link. Maybe he can offer some suggestions regarding power requirements for your locos.
Offline HFEVO2
#12 Posted : 27 August 2012 12:27:05(UTC)
HFEVO2
Thanks to David for your advice - sorry for getting the loco number wrong and causing confusion !
With Lenz, the hand held controller and processor unit provide digital instructions to overlay the power output from the transformer to the amplifier so it is these last two that ultimately dictates the power available to the locos. Each Lenz amp/transformer combo you add runs up to 5A so you divide the circuit into multiple sections, each of a size where 5A is sufficient for your needs.
I thought that the 60652 Mobile Station provides the signals to the processor and in the same way the transformer dictates the power available ( in this case 3.75A ).
Is this not right with Marklin ?
With the help of a friend and members of this forum in only a few hours yesterday we managed to get both the Br18s to work properly with the MS.
On a straight test track I ran the 91, BR18.478 and S 3/6 simultaneously, all off the MS. Admittedly it was on the flat and without coaches or wagons in tow.
I'm just having discussions with Carsten Laag on what to use to run my proposed garden railway :
For HO indoors I have Lenz divided into two sections, each with a 5A amp amplifier/transformer combination. I recently bought the computer interface and am experimenting with iPad control.
The planned garden layout will eventually have a decent run of single track with passing places but intend to keep the track plan simple so digital control is not absolutely essential. The aim is to sit, drink in hand and watch two or three trains running - no hard work like shunting etc.
I have Marklin models and PECO Gauge 1 track collected over many years and also some US motive power bought in the States from Aristocraft.
The pride of the collection is a Accucraft Gauge 1 Big Boy but that's a DC locomotive with twin Pitman 24v motors and sound. It requires a minimum of 2.5A @ 24v and, although I haven't looked, I'm not sure there is a DCC decoder that can handle the beast !
The roster consists of :
The 24v DC Big Boy
Two Marklin MFX Sound Locos
Four Marklin MX Sound Locos
One Marklin Digital Loco without sound
Three older Marklin AC locos
Five Aristocraft DCC compatible locos currently without decoders. ( But we don't necessarily need to operate US and Marklin at the same time0.
The options would appear to be :
Non Digital
Use the four Gauge 1 Marklin AC controllers I already have and separately use DC for the non-Marklin locos.
Extremely cheap but limited control. More complicated wiring needing individual sections = Less reliability outdoors in the British climate.
Digital All under DCC : Advantage : all kit can be run at the same time.
Convert everything to DCC and
Option 1
run using one of the wireless US DCC systems designed for garden railways
Quite costly as at least four extra sound decoders need to be bought to replace the MX Marklin ones.
Option 2
Buy more lenz kit : Build the Amps and transformers into a portable waterproof housing and borrow one or two hand held controllers from the indoor layout.
Easy as Lenz is familiar, but the amplifiers are limted to 5A each so might need to buy two or three. Not quite so expensive as the next two options but will not be wireless. ( iPad control with computer etc would be too complicated for the garden )
Keep Marklin and US separate :
Option 1
Run Marklin on the existing Mobile Station accepting that it's very limited but in stock.
I actually have access to a second identical Mobile station with 3.7A transformer so could divide the layout into two sections and double the capacity.
Cheapest option as it's all in stock ! Use plain DC : or buy US DCC wireless kit for the rest.
Option 2
Buy an ECos 50200 or Marklin S2 which can handle both DCC and Motorola but not at the same time.
More expensive initially but offset by not having to buy new DCC sound decoders for the four non-MFX Marklin locos.
Optional wireless control with the ECoS but at what cost ?
I would welcome some thoughts or can anybody suggest some better options ?
#13 Posted : 27 August 2012 13:01:30(UTC)
Markus Schild
to avoid any misunderstandings: The "large" MS2 cannot deliver more than 1.9 Amps regardless of the size of the transformer.
Most garden-railways I know are analogue. Analogue operation is less sensible for dirty rails and bad contact than digital-operation. If your rails shall keep outside the hole year, I would suggest analogue operation.
Markus
#14 Posted : 27 August 2012 13:38:34(UTC)
No, as Markus points out, the MS1 is limited to 1.9 amps (providing the transformer you are using with it can deliver 1.9 amps). As I pointed out, using a larger capacity transformer does not increase the MS1's power output. The MS2 has 2 options - 60113 booster is for H0 and outputs 1.9 amps, and 60112 booster is for 1 Gauge and outputs more than 1.9 amps (but I'm not sure what the figure is).
Option 2
The CS2 has a maximum current output of 5 amps (when used with the 60101 power supply - make sure you get the latest 60215 CS2, earlier versions may not output 5 amps). The 60124 booster also outputs 5 amps (when used with the 60101 power supply).
The Ecos outputs 4 amps, but the Ecos boosters come in 2 versions - 4 amp output for H0 use and 8 amp output for 1 Gauge use. Both boosters come with appropriate power supplies included in the price.
As far as wireless remotes go, you can use the Mobile Station app with an iPhone/iPad/iPod Touch and wireless network router with the CS2. There is also the Main Station app that can be used on an iPad - this has more features than the Mobile Station app.
For the Ecos, you can use the Touchcab app with an iPhone/iPad/iPod Touch and wireless network router as a remote control device. ESU also sell the Ecos Radiocontrol device, a handheld wireless remote control device.
Offline HFEVO2
#15 Posted : 27 August 2012 13:57:03(UTC)
HFEVO2
Very useful : the Gauge 1 Mobile Stations 1 come with a transformer number 60052 and a connecting box marked 60111.
If I go down the digital route, it looks like the EcoS unit with at least one booster is the better system to go for if the boosters are 8A rather than 5A.
However when I build the first section of the layout next spring, as I have two complete Gauge 1 Mobile Stations I could try testing the Marklin locos with each one on a separate section and see how they perform before spending lots of money on anything else.
I can't imagine wanting to run more than two locos simultaneously on each section and even at only 1.9A each, a MS should be able to handle two light trains on clean track.
An iPad is great for indoors but on a garden railway, at least using the Lenz system, it makes things quite complicated : With Lenz there is no Apple interface so you need to connect to your wireless router via a PC through the Lenz interface in order to broadcast the wireless signal to the iPad and that also means making sure that your wireless network extends all round the garden. ( Mine doesn't at present ).
Also, as we found trying to talk to potential customers at boats shows, an iPad screen is not really bright enough to see properly outside in direct sunlight.
The EcoS wireless option therefore looks more attractive but at a price !
#16 Posted : 27 August 2012 14:33:04(UTC)
Markus Schild
But you should consider, that the ECOS can deliver DCC and MM-format simultaneously. So you don't need any new decoders.
Markus
Offline HFEVO2
#17 Posted : 27 August 2012 14:39:29(UTC)
HFEVO2
I tried to see if it could run both together but it did not say it on the website in english.
That puts the ECoS unit way ahead.
I assume that the S2 can't do the same ?
#18 Posted : 27 August 2012 15:19:14(UTC)
Markus Schild
I think you mean the Märklin CS2. Yes: The CS2 can do that also. Also the MS2 has the multi-protocol ability, but limited to 1.9 Amp.
Markus
Offline eroncelli
#19 Posted : 27 August 2012 16:20:39(UTC)
eroncelli
Using a CS2 gives a possible advantage: you can supply boosters and these can be found up to 10 Amps.
#20 Posted : 28 August 2012 00:00:14(UTC)
Originally Posted by: eroncelli Go to Quoted Post
......... you can supply boosters and these can be found up to 10 Amps.
Confused Confused Confused Confused
Are you talking about a product Marklin makes, because I'm not aware of any Marklin built booster that can deliver 10 amps.
There may be other manufacturers boosters that can deliver 10 amps, but these will not handle mfx like the Marklin and ESU boosters do. That may not be such a big issue in this case. The other thing is if the 3rd party 10 amp booster was designed for use with the older Marklin 6021 controller (but also works with the CS2), then it will also work with an Ecos.
As for pricing, here are the Lokshop prices for the 8 amp EcosBoost and the Ecos ControlRadio
50011 ECoSBoost, ext. booster 8A, DCC/MOT/SX/mfx®, power supply 110-240V, EU+US 399 EUR
http://www.esu.eu/en/pro...gital-control/ecosboost/
50111 ECoSControl Radio handheld + receiving module for ECoS, German & English manual 259 EUR
http://www.esu.eu/en/pro...ntrol/ecoscontrol-radio/
This page was generated in 0.825 seconds.
