Offline DRG
#1 Posted : 02 August 2012 19:53:42(UTC)
DRG
I have replaced the Märklin mfx decoder of the BR042 ( 73926 ) by an ESU LokPilot V4.0 DCC.
This is my first Märklin Loco where I replaced the decoder.
I also adapted the settings of the LokPilot according to the ESU manual.
Is there anybody on this forum who also build in an ESU LokPilot DCC in the BR042 ?
If yes,I would like to know which settings you have choosed for comparison.
Greetings
DRG
By the end of september 2014 the US Army will leave Schweinfurt after almost seventy years. This is a very sad news.
a salute to Schweinfurt http://www.schweinfurt.army.mil/infovault/salute.html
#2 Posted : 04 August 2012 13:41:48(UTC)
drg
I assume you'rer talking about HOalthoughthe number 73926 seems to be unusal, besides this what type of motor has the loco and again I assume it has a 5 pole highefficiency motor.
My settings are done via Lokprogrammer and I have to ahve a look what the settings are (CV's)
regards.,
#3 Posted : 04 August 2012 15:20:36(UTC)
The number probably is 37926 - and it has a motor with bell-shaped armature.
Offline DRG
#4 Posted : 04 August 2012 15:25:22(UTC)
DRG
number 73926 seems to be unusal,...
John,
73926 is the item number of the loco.
...what type of motor has the loco
The loco has a high-efficiency propulsion with a bell-shaped armature.
…..and I have to ahve a look what the settings are (CV's)
That would be very nice!
I am interested in your settings of the following CV´s:
51;52;53;54;55;56
DRG
Offline NZMarklinist
#5 Posted : 16 August 2012 02:43:23(UTC)
NZMarklinist
Tom, John,
A simple check of the Marklin products searcher, shows that inspite of the owners insistance or dislexia Unsure it indeed would be 37926 as this is the version ohne sounds & why would he change a sound one Confused
Hopefully he bought the Lok cheap enough to make the upgrade worthwhile ThumpUp
Please excuse me Mr DRG Blushing
Glen
Auckland NZ
#6 Posted : 16 August 2012 08:52:01(UTC)
Hi DRG,
I would be interested to know why you needed to change the decoder. Were you not happy with the performance of the loco? Was it defective? If so, how soon did it fail?
I often hear about Marklin decoders being changed to ESU in the process of upgrading to sound, but in this case you seem to have changed a decoder for an equivalent ESU one with less capability (no MFX). Please let us know what led you make the decision to change the decoder, and why specifically for a Lokpilot V4.
Thanks.
#7 Posted : 16 August 2012 10:26:28(UTC)
Hi, Ray!
Neither mfx nor MM. Just DCC. Different capability, more options (probably not need for this loco), probably better performance.
Hi, DRG,
Did you try the automatic motor configuration of the ESU decoder? ESU LoPi V4 has it and I presume the DCC only version also has it.
I tried it on a Trix loco and performance is pretty good.
Some say values will improve if you run the auto configuration several times.
This will give you some values you can compare to the default settings from the manual.
Offline DRG
#8 Posted : 16 August 2012 17:17:42(UTC)
DRG
Hi DRG,
Hi Ray,
I will make it short!
RailCom +
#9 Posted : 16 August 2012 19:22:42(UTC)
Originally Posted by: DRG Go to Quoted Post
Hi DRG,
Hi Ray,
RailCom +
Thanks, DRG.
I guess if Railcom+ is what you want then you have no choice but to change the decoder.
I always have doubts about ripping apart a perfectly working brand new locomotive. I guess you're braver than I am!
#10 Posted : 18 August 2012 03:52:08(UTC)
NZMarklinist
Hi DRG,
Hi Ray,
RailCom +
Thanks, DRG.
Hi Ray, DRG,
The only thing necessary is removing the Tender body and unplugging the factory 21 pin decoder and replacing it with the ESU V4 21 pin decoder, unless you did something different DRG Unsure and what Control Station do you use DRG ?? please enlighten us !Huh
Glen
Auckland NZ
#11 Posted : 18 August 2012 10:19:48(UTC)
and what Control Station do you use DRG?
Good question. In February 2011 it was a CS2.
BTW: Märklin decoder out and ESU decoder in does not work for all locos with MTC21 interface Cursing - works only for simple locos that don't use AUX3 or AUX4.
DRG,
did you compare the CV values from the manual with those set by the auto configuration of the decoder?
The Trix BR 042 should have the same motor, so maybe owners of the Trix model can also provide CV values for this loco.
Offline DRG
#12 Posted : 18 August 2012 11:09:41(UTC)
DRG
Glen:
....and what Control Station do you use DRG ?? please enlighten us !
I´m using ESU ECoS 2.
By the way,I know that it´s no problem replacing the Decoder of the Märklin BR042.
Tom:
DRG,
Not yet!
#13 Posted : 20 August 2012 11:57:18(UTC)
NZMarklinist
Glen:
Tom:
DRG,
Not yet!
Hi DRG,
Good choice of Controller ThumpUp
What you could have done before removing the old decoder, and you could place it back in your Lok, if you don't be chance have an ESU decoder test stand, is to read the CV's of the original decoder, then write those to the new decoder as well, usually always gets you off to a good start when changing decoders Wink
I'll have to give credit to friend Dennis, list member, drwhittle for that tip Sneaky Smile He does all my conversions and upgrades ThumpUp
Glen
Auckland NZ
#14 Posted : 20 August 2012 15:29:21(UTC)
What you could have done before removing the old decoder, [...] is to read the CV's of the original decoder, then write those to the new decoder as well, usually always gets you off to a good start when changing decoders Wink
May work when replacing an ESU decoder with an ESU decoder. But the new Märklin decoders have a motor type CV that cannot be found on ESU decoders while new ESU decoders have advanced load regulations CVs that cannot be found on Märklin decoders.
This page was generated in 1.327 seconds.
